Question about CTX S762G (Silver) 17" LCD Monitor
SCREEN PROBLEM WHEN POWERED UP - RIGHT AWAY BLINKS OFF AND ON VERY RAPIDING - EACH SECOND - SCREEN IS THERE THEN BLANK THEN THERE AGAIN ????
  • 1 more comment
  • Anonymous Mar 26, 2008
    Ditto
  • Jwheel Apr 26, 2008
    I have two of these monitors and that is the problem that I have with them. I am about to go to radio shack and buy all the caps for the power supply. I'll update how it looks after i replace all of those. I also noticed some fractured solder on the back of the board. I am going to reheat the OEM solder and let ya'll know how that goes. I am no expert, but i've fixed many monitors in my day.
  • Anonymous Jul 21, 2008
    I have the same problem. It used to occur for a couple minutes, then show a white screen with two pink and one blue faint lines.
    Now it lasts for several more minutes. :(
My monitor screen is totally white
Posted on Jan 17, 2009
Monitor goes black
I also have a hp w1907 monitor which also powered on for a second and then go blank with the power light still on.. it was out of warranty so I had no loss so I took it apart..I found one of the wires broken at one of the backlight bulbs { becarefull they are fragile and there is four of them, two on the top and two on the bottom... and the lcd screen is very fragile } I soldered the wire back on and it all work fine... just remember where all the screen parts go.
Oct 24, 2009 | HP w1907 LCD Monitor
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
Advent 8315 Screen blank when powered up
did you check to see if that was the correct serial number of the laptop that you got back from the repair center
Aug 21, 2009 | Computers & Internet
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Samsung Q45 laptop screen blinks when used alone
Hold down the Fn key and look at the F keys for a key that looks to have a monitor screen on it, when you find it just tap that key to switch between screens.
Good luck.
Jul 01, 2009 | Computers & Internet
My FN+F6 doesnt keep my screen on the laptop open
Change the settings from the display settings panel. (Right click on the desktop and go to display settings)
You should see 2 monitors graphically represented there.
You can make the monitor that is greyed out active by right clicking on the monitor, and selecting active.
Dec 11, 2008 | Acer TravelMate 2451WLMi Notebook
Blackberry pearl 8100 blank screen & green blinking light
Try performing a hard reset: remove the battery from the device while it is still powered on, leave it out for 30 seconds, then reinsert.
Sep 28, 2008 | RIM BlackBerry Pearl 8100
Envision en 9110 lcd
More than likely bad inverter board or power boards
Nov 06, 2007 | Envision EN 9110 19" Flat Panel LCD...
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Blank scren, led stays green for only one second
Explicit enough to see that's this a a repair shop job. That also probably means a replacement- cost of which will not be much more than repair prices. One thing how ever- the power supply[which would appear to be the problem] is this built into the screen [that is does the screen have mains power direct? Or is it powered from an external 'Power Brick' If it is of the Power Brick type - then a new power supply is the answer - get on of the stabilized universal type with a fistful of connectors and a voltage selector switch.
May 24, 2007 | BenQ FP737S-D 17" LCD Monitor
CTX S762G (Silver) 17" LCD Monitor Logo
115 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
