Question about Sony HT-5100D System
Receiver displays a protect sign and will not send any sound
  • Anonymous Aug 27, 2008
Mine does that 2, you have a speaker that cant hold that much power being put in it. Get some bigger speakers. Or look at you wires and make sure there are not any crossed.
Posted on Aug 14, 2008
Marantz 4220 Power Switch Dear experts Some time ago when unit switched on cracking noises in speakers started. But now exept ligting up no sound is comming just little when volume turned up.What could...
The Amplifier was failing and that's why you were getting the crackling noise.
Most receivers have an Auto Protect that shuts the system down and goes into Protect mode at the first signs of failure or overheating, usually indication by 'Protect' on the display.
I'm presuming from your post that you never got any indication that the unit was shutting down to protect itself and has just failed, so I'm presuming that this facility isn't fitted on this model.
Depending on you Technical ability it could be an easy repair (replacing the complete PCB or some PCB components). Your only other solution is a visit to a service engineer.
Jun 04, 2011 | Marantz Audio Players & Recorders
My Maratnz SR4200 is coming up with a protect sign on the digital display. I have tried cutting off the ends of the wire to ensure dust hasn't tripped it and also am sure the wire has been entered...
Unplug all of the speaker wires. Switch it on. If it still says "protect" then the problem is internal within the receiver. If it stops going into protect mode with speakers disconnected, then the problem is possibly blown (shorted) and or incorrect speakers causing it to trip.
Feb 26, 2011 | Marantz SR7500
Sound went off,says 'protect'
need replaced power output
transistor amplifier short
Nov 15, 2009 | Sony STR-DE475 Receiver
Suddenly switch off
Friend, G is for GPRS and is displayed only when you are using GPRS. It means that when you poweron the phone is either sending/receiving emails thru GPRS. Switching off could be more serious than sending/receiving emails.
Sep 20, 2009 | Nokia 6300 Cellular Phone
Sound goes off in a few seconds
p mean protection mode, something is not right to send the reciever into protect mode, check wiring
May 05, 2009 | Audio Players & Recorders
This generally means you've got a short somewhere, and the received is trying to protect itself.
My suggestion is to disconnect all of your speakers at both ends, and reconnect them.
Most times this happens because a speaker wire is lose, and the positive and negative connections are touching each other, causing it to short out.
Mar 24, 2009 | Sony STR-DE485 Receiver
MX 308 do not give the fax receive tone
to enable sound/tone check the settings in the fax section in the software
Feb 26, 2009 | Canon MX300 Office All-In-One Printer
Power On Displays Flashing "Protected"
The audio amplifier IC´s are on short circuit.
Jun 15, 2008 | Sony STR-DE535 Receiver
Amplifier/receiver switches off systematically after a few second of use
Sounds like a bad output channel is causing it to go into protect mode. Time to see a repair tech.
May 01, 2007 | Harman Kardon HK 3480 Receiver
Vollume trouble
the system protect is usually displayed when a condition of short or shorting is occurring in the speaker wiring or the voice coil of any of your speakers.... thte circuit of you reciever is trying to protect itself and you from a very costly repair,,,so it you have another set of speakers try to use them and see if the condition still exists and if it does the problem is in the output section of the receiver,,,and if the protect no longer exists you have fixed your problem,,,good luck
Apr 07, 2007 | Onkyo TX-8211 Receiver
Sony HT-5100D System Logo
177 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
