Akai LCT3285TA 32 in. LCD Television Logo
Posted on Dec 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Im having trouble hooking up my desktop computer up to my Akai LCT3285TA tv? what am i doing wrong? I have both VGA hookups connected and screen says not supported?
Anonymous
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Mar 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
1666
Points
13
One other problem is that if you use a VGA to HDMI cable then you may need a (HD) converterbox (Set top box) to send the single threw... at least mine does...
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Dec 16, 2009
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3368312
Points
33650
The screen indicates 'not support' because the resolution you are try to feed the TV exceed the maximum it can display, you need to set your computer video out put resolution the TV native resolution, which you need to find out by download the user manual here: http://www.retrevo.com/support/Akai-LCT3285TA-TVs-manual/id/741bh147/t/2/
So I was trying to get my Shuttle cube computer to work with the TV by VGA to RGB connector/converter. I get it all hooked in and everything but it won't show up on the screen. I take it out, hook it up to...
sometimes you need to have the computer off before hooking up such a connection so the video card can identify the screen being used when the computer is first turned on.... also maybe incompatible with the adaptor
MY PC DOES NOT HAVE A HDMI PORT CAN I USE MY PC MONITOR CONNECTION CABLE TO CONNECT TO MY AKAI LCT3285TA 32 PLASM [THERE IS A PORT ON THE BACK OF THE TV BUT I GET NO SIGNAL...DO I NEED TO MAKE SETTING...
Look at the function keys (F1 to F12) in your computer since there is a shortcut key in it. Look for a key with an icon resembling like a TV and a PC Screen with a slash. It's like TV/Monitor icon.
Now with the PC (laptop?) hooked with the TV, (the tv showing no signal), hold down the FN key and press that function key with the TV/Monitor icon.
2helpful
IS THE AKAI LCT3285TA A COMPUTER MONITOR TOO
check on the back side if they got the vga connector to the cpu
Power supply board needed from a Akai LCT3285TA 32" LCD TV
Go to partsstore.com this is where I found the power supply board for this TV.
Im trying to program my remote for Cable...
Target sells a GE Universal Remote Control, 5 Device with learning feature. Its code for the Akai LCT3285TA is 1139.
Other remotes may use different codes, or have none that will control this TV.
AKAI LCT3285TA static noise
Which input connections are you using?
2answers
Universal TV remote control
Target sells a GE Universal Remote Control, 5 Device with learning feature. I can't say if it works with your Verizon DVR, but its code for the Akai LCT3285TA is 1139. If you have the Verizon's remote, you should be able to use the learning function to make the GE control it - that's if the GE doesn't have a built in code that will work for this DVR.
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
1helpful
3answers
Screen powers up then goes blank after 2 seconds
Hi, was there a resolution to this? I am experiencing the same problem with LCT3285TA purchased at Radio Shack in Media, PA. Radio Shack has refused to service the unit and has put me over to Akai for the manufacturer's warranty. I'd like to know what to expect and if this problem with the Logo coming up and the unit shutting off/restarting can be easily fixed, thanks.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
