Kenmore Washer Leaking from underneath
Washer is used. Didn't leak before.Was transported appx. 15 miles. After 2nd load leaks from underneath on right side of washer. Can you help?
  • 2 more comments
  • Anonymous Feb 10, 2008
    My washer is leaking from underneath and when I moved the washer it was dark dirty thick liquid...any idea's? I checked the hoses any them seemed fine
  • freebiebean Sep 22, 2008
    Hi - My front load washing machine is leaking from the bottom right hand corner underneath and it also appears to have a black gooey substance to it. It is not near where the hose connects to the washer and the back bottom right and that area appears dry - please help.
    Thanks, Nancy
  • robert samples May 11, 2010
    check to make sure its not coming from your hose connections then give me the model number
  • Anonymous Mar 28, 2014
    water leaking from underneath
Check the hose from the bottom of the drum to the drain. it probably slipped off. its held on by a tension clip. Someone must have pulled on the hose at the back.
Posted on Jan 22, 2008
  • Anonymous Jan 22, 2008
    the off-balance light stays on.It comes off when the lid is closed,but the drum will not fill nor work. When the lid is opened the light comes back on. I tried turning and twisting the drum,no luck.Help
6ya staff
SOURCE:
Kenmore 80 didn't drain during the spin cycle and leak underneath machine. Makes buzzing noise in the wash cycles.
The pump is likely damaged if it was leaking. Look for a ring of melted plastic on the face side of the pump. Check to make sure the hole is not rounded where the motor shaft enters the pump.
I'd replace the pump just to make sure the washer doesn't flood some time in the future even if the pump turn out to be ok now.
Vlad,
First Choice Appliance Service. Sacramento, CA
Jul 05, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My washer is leaking from underneath the machine. What is the cause?
It could be a few things, a hosehas a hole in it, the water pump is leaking , or the cenbter seal on the transmission is leaking. Best way to check is to put some water in it, have someone help you lean it back and look underneath to locate the leak. If the water is leaking only in the agitate cycle and not as its filling then its your center seal.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Nov 03, 2010 | Kenmore 23822 Top Load Washer
I transported my frigidaire front load washer.water leaks.
Check your pipes /drain and sump hose sounds lie something has came off in transit
Apr 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer kenmore leaking water out bottom
Its very possible it could be one of the tubes that run to the fabric softener or detergent.
Dec 30, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer leaks water in the back of the washer but i cannot see any signs of the leak. this is a front load washer . model 970 ca0042 00,
I have a Kenmore front loading washer HE2 Plus.
Started leaking only 6 months old from the back over the spin motor.
I found a bolt had come out of the motor bracket causing the motor to crack a small hole in the plastic outer drum. I've been down for about a month waiting on the part and service. This is under warranty and we cant get any help any sooner from sears, not even a loaner.
Will not purchase Kenmore products again, 2nd front loader from Kenmore, 2nd problems.
Oct 14, 2009 | Kenmore Washing Machines
Kenmore washer. leaking brown oil like substance
Oil leak can be bad, can be gearbox on top loaders / or bearing fault..
Oct 01, 2009 | Washing Machines
Kenmore Series 80 Washer leaking oil underneath
TRY TO CHECK THE RUNNING CAPACITOR MAY BE THE OIL THAT YOU SAW CAME FROM THE DAMAGE CAPACTIOR.
Aug 21, 2009 | Kenmore 22642 Top Load Washer
Kenmore 80 series. Leaking from front under washer. Can hear standing water under agitator/basin
Usually with this situation its a pump leaking, does it leak mostly during use.if you lean appliance back, should be able to take a peak underneath at pump. will just need to be replaced if leaking.
Jun 08, 2009 | Kenmore 22422 Top Load Washer
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Washing Machines Logo
742 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
