Question about Trendware TRENDNET 10BT/100BTX KVM (KEYBOARD/VIDEO/MOUSE) 2-PORT SWITCH KIT W/TWO CABLES TK-205I/TK-205K (TK205K) KVM Switch
Xbox 360 trouble
Help. I just bought a Tk-205K KVM switch and am having some trouble. I am using it to connect my computer to port 1 and my XBox 360 to port 2 via VGA cables. I am able to use both computer and Xbox as long as the Xbox is on. If it's off I can not use either. I do not wish to leave my Xbox on all of the time. Is port two what powers the switch? Should it work even if nothing is plugged into port 2. Also when I did have the xbox on and was using the device, my monitor turned a green color. Everything was green. As soon as I unplugged the device it was fine so I know it was not the settings on the monitor. Has this happened before to anyone else?
    New Friend:
My problem is fairly similar to the first. When both xbox and computer are turned on the KVM switch works fine, it lets me switch back and fourth between the x-box and computer with no problems at all. IF i turn off my computer, the xbox will continue to run through the KVM switch without need of the pc. BUT when i turn off the x-box with the pc on, the kvm switch will not display anything. at all.. in order to use my PC with my x-box turned off, I have to hook the monitor directly to the pc. If there's a solution to this nonsence I'd like to know it.
Posted on Jan 20, 2010
Whenever i turn my xbox on the light around the power button turns from red to green and nothing happens.
Posted on Feb 03, 2008
6ya staff
SOURCE:
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
Trying to connect to xbox
hack cheat repair and unlock xbox 360 yourself in less than 1 hour
http://3redlight.tk
Apr 27, 2010 | Video Game Consoles & Games
Have one ethernet for computer want to use xbox live so i take out the ethernet from computer and put it in xbox unplug wait plug back in turn still will not connect red x for modem
You should get a cable/dsl router/switch or wireless cable/dsl router/switch and put it between your Modem and network nodes (IE your computer and xbox 360)
So it is modem to router wan port
Xbox 360 to router lan port
Computer to router lan port
You can purchase one cheaply at best buy
look at this link
http://www.bestbuy.com/site/olspage.jsp?skuId=8741365&type=product&id=1202648529130
Jul 29, 2009 | Microsoft Xbox 360 Console
Connecting xbox 360 live
if you plug the computer into the usb port a box will come up and you register it as for the adapter get the one for the xbox plug it in and go to the dashboard then console setting then xbox live connection then test connection and if it doesnt work try the linksys one or the wired one.
Jul 12, 2009 | Microsoft Xbox 360 Console
Dynex 4 port hub xbox 360 IP address error
Here is a link to their Support site: http://support.xbox.com/support/en/us/nxe/default.aspx Select "Troubleshooting/Connection" errors page. On the LEFT, select "Network Help". That should put you in the area you need.
Jun 12, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
Nokia multimedia terminal Nokia DBOX Programming
a repair is wise if this is a constant issue. Some people tackle this problem by opening up their Xbox 360 and finding the problem themselves. Those who do report a small magnet that holds the disc in place, loose or not connected. They simply glue this back on; however, opening the Xbox 360 renders the warranty invalid, therefore future repairs may be denied and a fee may be placed.
Nov 29, 2008 | StarTech.com StarView SV211K 2-port KVM...
Unable to switch to other comp
See belkin.com for switching software update. Also you should have an icon on your desktop to switch back and forth.
Nov 23, 2007 | Belkin F1DK102U 2-port KVM Switch
Connect to wireless
I believe the X-Box does NOT have Wifi built in? (sic)Surprisingly, the Xbox 360 doesn't have wireless networking built in. If you don?t fancy using the wired Ethernet method, you can invest in a wireless networking adapter. Microsoft has its own adapter specifically designed for the Xbox 360, but third-party Wifi-certified devices will work just as well.(sic) From the below site. http://72.14.253.104/search?q=cache:d7LlkY7Zo1sJ:www.vnunet.com/personal-computer-world/hardware/2147007/microsoft-xbox-360+xbox+360+wifi+is+built+in%3F&hl=en&ct=clnk&cd=2 So that may be ya problem?
Aug 12, 2007 | Microsoft Xbox 360 Console
Open Questions:
See all Trendware TRENDNET 10BT/100BTX KVM Questions
Trendware TRENDNET 10BT/100BTX KVM (KEYBOARD/VIDEO/MOUSE) 2-PORT SWITCH KIT W/TWO CABLES TK-205I/TK-205K (TK205K) KVM Switch Logo
179 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Jeffrey Groves
Jeffrey Groves
Duncan Mutch
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
