Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
GE Refrigerator Compressor Inop.
My G.E. refrigerator (Model #PSI23MGMABB) will not get cold. The condenser fan runs but the compressor will not.
  • I checked the 4TM overload (Klixon #319NFBYY- 53BBB1L) which has continuity across the terminals.
  • I checked the compressor (left to right terminals = 12 ohms, left to top = 6 ohms, right to top = 6 ohms).
  • How do I check the capacitor (JSU21X126AQC 210VAC 12 mF)?
  • How do I check the PTC relay (Klixon #8EA8B3)?
Thanks,
Al
  • 10 more comments
  • Iwantoknow Jan 22, 2008
    Tech17,
    Yes, the evaporator fan is running.
    the dr,
    I checked for and got continuity (cap to terminal #2 of PTC at the compressor) with all wires connected.
    Tech 17,
    Yes the evaporator fan (inside the freezer) is running.
    The Dr,
    I checked for voltage (incoming) to the PTC. ' 0 ' volts at all three terminals.
    TECH 17,
    The PTC relay is brown, I shook it, no loose pieces.
    The overload is white.
    Does anyone know where the defrost timer located?
    Tech 17,
    I found the circuit board. Phew! It's fried! (burned a hole on the board right at the top of the fuse. ID numbers all over the place!
    (bottom right front) EBX1005G01 REV L also, GEA151 (top left front) 200D2260G005 (bottom right back) GEA0756 EC539474 What do I need to do to keep this from happening with the replacement board?
  • Anonymous May 16, 2008
    I have the exact same system board for my fridge and it has a burn mark in it too.. any idea where to buy a new one?
  • ahmsallam Feb 08, 2009
    The lower fan and the freezer both work but the compressor does not start. I have the same capacitor and relay models.
  • lyric2009 Feb 15, 2009
    Hi, I have the same problem with the capacitor measured only 4uF instead of 12uF for my GE ESS25LGNAWW. Mine frige condenser also stop. It it means the PTCR relay and the overload are bad also? I also saw a BURNED hole on the back next to the fuse. Please help!
  • Anonymous Mar 01, 2009
    hola amigos disculpe como se comprueba si la pieza jsu21x126aqc 210 vac 12 pf sirve se puede checar con el multimetro??
  • robert samples May 11, 2010
    first is the evaprator fan running in the freezer
I found this post by searching on the capacitor number, JSU21X126AQC. My 2001 Kenmore refrigerator (don't have model# here) compressor didn't run, but I heard it hum for a few seconds and then a click. That's the Klixon overload doing its job. I measured resistance of the compressor leads same as original poster. This lead me to determine that the windings were not open or shorted. The wiring to the compressor also fed the condenser fan, and it was running, so power was at least all the way to the compressor.
What I did find was that the 12uF capacitor was only 4uF. My digital volt meter has a capacitor check range. This compressor circuit is a permanent split capacitor type. Without the proper capacitance, the compressor can't start. I replaced it with a 10uF, 220v AC capacitor I had, and now it runs fine. I wonder how many refrigerators are scrapped because of this inexpensive problem?
Posted on Jan 07, 2009
  • 447 Answers
Al are you sure you are getting voltage to compressor??? It may have a low voltage fan motor that is not supplied with compressor voltage. Check the relay by checking for continuity from spade to inside of where terminals go into. The cap is fine its only for energy efficiency
Posted on Jan 22, 2008
  • joey  shearer
    joey shearer Jan 22, 2008
    I believe your refrig doesnt have a timer......It has a computer that does all that.. Is the a rectangle steel panel on rear that has computer inside??
    President:
  • 1,314 Answers
What the good doctor is saying is check for voltage where the wires come into the ptc reley thats a great idea
  • 3 more comments
  • robert samples Jan 22, 2008
    by the way is your ptc reley white by chance if it is take it off and shake it if black stuff falls out or it rattles go get a three in one reley from appliance store
    chech for voltage coming from the defrost timer to compressor bet thats where the promblem is you already know you got voltage coming in because the evap fan is running one of my instrctores once told me find out where the power starts find out where it stops inbetween is the promblem
    look at the bottom by the door hinge or underthe panel in the fridge section if there is a panel at the back of the fridge compartment look there
    sir is this a sxs because its posted as a top mount if its the model you gave then it doesnt have a defrost timer it has an adc automatic defrost control (dr) its one of thoose electronic control units .There is a panel on the back of the fridge or freezer section with for screws in it remove that panel and you will find a control bd look for a burned resister there and let me know what you see the adc is there also locate the panel facing the back of the fridge like your looking at the compressor
    the new boards have been improved cotact ge for a replacment and pay close atten to the instalation inst i mean close if you need assistance me or the dr will be here doc is good
I have the same problem with my fridge i think my cap is not working ineed to be replace i call GE the send to me a wrong parts my question for you where i canfine that cap modell# is jsu21x126aqc please can some one help me
Posted on Dec 21, 2009
I have no cold air in my refrigerator or Freezer. It defrosted everything.
Condenser Coils are Dirty
If the refrigerator is not cold enough the condenser coils may be dirty. The condenser is like a radiator and must stay clean in order to dissipate the heat which was removed from the inside of the refrigerator. As the coils get dirtier the refrigerator becomes less efficient, which makes it work harder to cool down. If the coils are dirty enough, the unit will never be cold enough and will not be able to cool the inside of the refrigerator to the proper temperature.
Evaporator Fan Motor
If the refrigerator is not cold enough, the evaporator fan motor might have failed. Every refrigerator has a set of coils called an evaporator. The refrigerator may have one or more evaporator fan motor(s) depending on the model and evaporator locations. The evaporator fan motor circulates the cold air from the coils thru the compartment. If there is only one evaporator it is in the freezer side. If the fan is not working, no cold air will get to the refrigerator compartment. The freezer may still get cold.
Condenser Fan Motor
If the refrigerator is not cold enough there might be something caught in the condenser fan motor blade, or the condenser fan motor might be defective. The condenser fan motor draws air over the condenser coils to cool them. The condenser fan motor is located underneath the refrigerator near the back. Pull the refrigerator out from the wall and remove the access panel to access it.
Start Relay
If the refrigerator is not cold enough, the start relay may be defective. The start relay is a small device mounted to the side of the compressor. It provides power to the run winding along with the start winding for a split second at start-up to help get the compressor started. If the start relay is defective the compressor may run intermittently or not at all and the refrigerator will not get cold enough. The start relay should be replaced if defective.
Temperature Control Thermostat
If the refrigerator does not get cold enough the temperature control thermostat might be defective. The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
Start Capacitor
If the refrigerator isn't cold enough the compressor might be having difficulty starting. The start capacitor serves as a battery to give the compressor a little boost during start-up. If the start capacitor is burned out the compressor might not be able to start and run as often as it should. Test the start capacitor first with a capacitance meter, they don't fail often. If it's defective, replace it.
Thermistor
If the refrigerator is not cold enough the thermistor might be defective. The thermistor is a sensor which monitors the air temperature. It is connected to the control board. If the thermistor is defective the refrigerator does not cool or may cool continuously.
Temperature Control Board
If the refrigerator is not cold enough the temperature control board might be defective. The temperature control board provides the voltage to the fan motors and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Compressor
If the refrigerator is not cold enough, the compressor might be defective. The compressor is a motor which compresses the refrigerant and circulates the refrigerant through the evaporator and condenser coils. There are several other components which are more likely to be defective if the compressor doesn't work. If the compressor itself is defective a licensed professional will need to replace it.
Main Control Board
If the refrigerator is not cold enough the main control board might be defective. This is not common. Check the defrost system, cooling fans, and cooling controls first.
Jun 28, 2017 | Refrigerators
Condenser fan runs but he compressor does not. this is on a GE Model GSS25LGMF. Serial # RD426977
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | GE Profile 23.1 Cu. Ft. Side-by-Side...
My GE refrig. Model dss25srdss runs but does not get cold at all I opened the back panel the compessor runs and so does the fan but the fan seams like its runing slow.
heatman101
May 24, 2011 | Refrigerators
GE SELECT STS16ABSERWW, FRIDGE NOT COLD FAN MOTOR RUNNING COMPRESSOR NOT SURE WHAT ELSE COULD IT BE
heatman101
May 02, 2011 | GE Refrigerators
Not getting cold fan is not running check compressor and is working
heatman101
Apr 27, 2011 | GE GSS25LGM Side by Side Refrigerator
My GE side by side TFX20 is not cooling on Refrigerator or freezer. Hear the fan running but not the compressor. Is it a bad Run capacitor or compressor? How do I test?
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 27, 2010 | GE Refrigerators
My refrigerator will not get cold the compressor will run and you can see the refrigeration lines get cold then they defrost shortly after they got cold but i do not see the condenser fan run at all.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Nov 16, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
NOT GETTING COLD-COMPRESSOR SEEMS INOP
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 06, 2010 | GE Refrigerators
Started leaking water out the freezer door and ice was melting last nite... bad timing we just got a snow storm here in NC last nite. Seems to be running but food is defrosting. Its a GE Side by Side about...
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jan 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator external fan - air flow?
This really depends on the manufacturer and their preference on design. First, the fins at the compressor are part of the condensing coil. Most all makers have air pulled into the condenser coil and blown across the compressor. You should be moving room temerature air across the condenser and the air from that is usually then moved across the compressor.
Hope this helps clear it up .
May 08, 2009 | Refrigerators
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
7,691 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
