Question about BenQ PB6100 Multimedia Projector
Benq pb6100, light bulb does not on, power ok
All 3 lights on, light bulb does not come on, no fan
  • 3 more comments
  • Anonymous Aug 11, 2008
    I have the exact same problem, the 3 lights come on, but only the power supply fan works. The two in the back won't turn and the bulb won't turn on. Did you find a solution?
  • 5679fy Aug 31, 2008
    Local power failure burnt the UPS motherboard capacitor and a few resistors. I always have the projector plugged in, and I learned the UPS is only active when there is a power failure - which meand the projector was connected to local power, but not powered on. I had the UPS fixed, but now the projector's fans do not come on, the green power light blinks for afew minutes then the red lamp bulp stats blinking. Could I have blown the bulb without the unit being turned on?
  • giorgio69er Dec 11, 2008
    I have the same problem. Projector worked like a dream, then one day, just won't come on. Power supply fan spins and green LED's come on, but lamp and cooling fans do not come on. Only about 600 hours on lamp. I'd be forever indebted to whoever can provide the solution to this.
  • Anonymous Feb 07, 2009
    Help!
  • Pipomiguel Apr 09, 2009
    First of all, sorry for my bad english
    When I turn on the projector, the "lamp" led blinks (in red) and the bulb doesn´t work. Fans do work, or al least they sound like it...
    Lamp usage hasn´t exceeded 3.000 hours so I guess there´s other problem
    Can somebody help me?
    Thanks!!
I fixed the exact same problem on my PB6200. Both back fans were not working, and the bulb would not turn on.
In my projector, the fan board had a bad capacitor. The fan board is the one where all 3 fans are connected, and which is facing upside down on top of the powerboard. The bad capacitor on my projector was coded C7302 on the schematics. It's a brown, 25v 470uf capacitor.
I recommend you to open your projector, unplug all connections to the fan board, turn it upside, and inspect the capacitors and other components. Bad capacitors have a bulge and/or a black stain or fluid coming out on the top. You can find pictures on the net.
Posted on Mar 04, 2009
  • 3 Answers
I had the exact same problem, I followed the advice of Victorbello on this thread, and found a bulging capacitor where he suggested to look.
I soldered in a new one from Radio Shack ($1.50) and the projector works again.
PB6200 symptoms: Back fans were not working Bulb won't light (but is in perfect condition) LEDs on control buttons are lit, but not three status LEDs Smaller internal fan will not turn off.
Solution:
The mainboard had a bad capacitor
The board is the one where all 3 fans are connected, and which is facing upside down on top of the powerboard.
The bad capacitor on my projector was a 25V 470uf 10mm diameter, 16mm high, 5mm lead spacing capacitor.
"I recommend you to open your projector, unplug all connections to the fan board, turn it upside, and inspect the capacitors and other components. Bad capacitors have a bulge and/or a black stain or fluid coming out on the top."
Posted on Aug 30, 2010
Thanks bobbyj, but how do I check the lamp for physical failure? The lamp was not on when we had the power failure so it could not have burnt out, but I'll check it with a little help.
Posted on Sep 03, 2008
Had the same problem with my PB6200. It now turns on after replacing the capicitor, but still can't get a picture to show. all lights show it's working. What do i do next.
Posted on Feb 06, 2010
  • Mike Huck Jun 04, 2013
    I had the same fan fail problem with my PB6200. I replaced the bad capacitor, and the fans and bulb come on, but no picture. Were you able to figure out to fix this next problem?
    Sergeant:
  • 395 Answers
Remove the lamp and check it for physical failure, also claen the air flow filters for clogs.
Posted on Jan 22, 2008
Turn on benq pb6200 with new bulb all I get is humming and no led
same problem here. checked fuse, mainboard seems ok. nothing looked blown.
Jul 15, 2010 | BenQ PB6200 Multimedia Projector
Everything is yellow, is it the bulb, but no error message has come up?
Hi....
It's not the bulb...It's what the light passes thru to pick up the colors
See who fixes BenQ on the web
Apr 21, 2010 | BenQ (200NSH-LAMP) Projector Lamp for...
No Picture
Ok. It still might be the bulb, if not make sure it is plugged in to a working outlet. Also, if that doesn't work unplug, wait 1 hour, push the power button (with it unplugged) then plug it back in. If nothing fixes your problem, it is the power supply.
May 24, 2009 | BenQ PB6100 Multimedia Projector
My Benq pb6100 projector needs a ''shake'' on switching on to run
Hi I am Vortash possibly a loose plug or the bulb housing is not secure and the cut off switch is not contacting .. loose fuse .. dry joints o loose component .. one thing is for sure keep shaking it
and your going to kill your bulb ?. During the arc on the lamp it builds up carbon deposits if they break loose they get hot in the bulb under working conditions against the glass and sometimes fracture it ?. don't shake your your unit unless you can afford to replace this at between $400 and $800 i bet that repair would be a more economic solution hope this helps Regards Vortash
Apr 10, 2009 | BenQ PB6100 Multimedia Projector
BenQ MP612c projector has three orange flashing lights
you can go to the BenQ website and download a manual for your particular projector. It should tell you what the lights indicate.
Feb 01, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
No power
Bulb is definitely not cause of your problem.Normally lamp light will blink when it's defective.Dead means PSU problem .Some projectors have a overheat switch which switches off supply till manualy reset,you need to open the projector.
Samir
Oct 30, 2007 | BenQ PB6100 Multimedia Projector
LCD shutting off automatically
The problem comes in the Lamp unit generally. check the condition of Lamp.
Viren
Oct 01, 2007 | BenQ PB6100 Multimedia Projector
BenQ PB6100 Multimedia Projector Logo
1,578 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
