Question about HP OfficeJet 6310 All-in-One Printer (Printer/Scanner/Copier/Fax) w/USB Printer Cable , Retail
Black line on my fax copies!
My fax copies are coming out with a black vertical line down the center; the other copies--from the glass--come out perfectly! Can I get rid of the line for faxes?!?!
  • Joe Don May 16, 2009
    When faxing or copying get lines on copy.
  • Anonymous Mar 17, 2014
    brother mfc93400
  • 181 Answers
You sure can - the issue is that there is something on the thin strip of glass where the copy goes through from the feeder at the top - follow these directions and you should clear the problem right up.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00671260&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Posted on Feb 28, 2008
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
On a copy or fax there is a black vertical lineI
does line appear from both adf and flat bed? clean glass does line show up on print jobs? try cartridge then fuser
Jul 29, 2010 | HP Laserjet CM 1312NFI Color Printer
We have a black line down the center of all copies...
If the problem only happens on copies or sent faxes then no it is not your drum. There is something on your scan glass. My guess is you are getting the line on your copies when you run the original through the document feeder. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on
May 20, 2010 | Office Equipment & Supplies
Black line down paper
Pull the doc feeder open and clean the scanner glass
Feb 11, 2010 | HP 1040 Plain Paper Inkjet Fax
When copying or printing a fax, a vertical black line 2-3 mm line
try cleaning the rollers with water in the feeder at the top check the glass too too see if it's dirty
Jun 27, 2009 | HP Officejet 6310 All-In-One InkJet...
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Black vertical lines on the sent copies when faxed on Sharp UX 510
Lift the document feeder cover, and clean the scanner glass.
Please rate solution
Mar 31, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
Black line while scanning and copying
Open up the document feeder and clean the scanner glass
Jan 25, 2009 | Brother Multi-Function Center MFC-240C...
Copies have black vertical line down center of the page when fed through automatic feeder, but it doesn't happen if you place them inside manually.
Check your glass and rollers where the paper feeds through the machine. Most like they just need to be cleaned. Can be done with a q-tip or tissue and a little rubbing alcohol.
May 09, 2008 | Office Equipment & Supplies
I have problem with a quality of fax
Make a COPY and see how the copy comes out. If you see the same black vertical lines that other people are seeing, then you probably have something like whiteout on the scan glass.
Open the fax top cover where you feed your originals, and then look inside for a piece of glass about 10" long by 1/2" wide. Then I would try cleaning the glass with rubbing alcohol and also go over it again with windex.
After cleaning the glass, try making another copy to see if it has improved. If it has, but still has more lines, then try re cleaning the glass.
Hope this helps.
Good luck.
Mac
Mar 08, 2008 | Brother FAX-575 Plain Paper Thermal
Open Questions:
See all HP OfficeJet 6310 All-in-One Printer Questions
1,139 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
