Question about Whirlpool Dryers
Whirlpool dryer - element heats, then shuts off quickly
I have a Whirlpool electric dryer, model # YLED4634EQ2 (apparently the Y is unusual in the model #??). When I try to dry a load of clothes, the element heats up (looking in the drum, I see it glowing orange in the back, through the metal screen), then shuts off after a very short time. Probably around 1 minute, if that.
It does not come back on, unless I open the door, and leave it open for a little while. If I leave the door shut, and let the dryer complete the cycle on its own, the clothes do not dry.
Should the metal grid where the heat comes out, inside the drum, get so hot in the matter of a minute that it can not be touched?
Any idea what the problem might be, and how to go about fixing it?
Thanks for any help you can offer,
Kim
    Habit-Forming:
    New Friend:
  • 76 Answers
Sounds like you have a stopped up vent on your home, when the vent gets stopped up the dryer can't circulate the air properly in the dryer and causes it to get to hot which causes the high limit thermostat to kill power to the element. If you need more help with this visit the link below:
Appliance Repair Guides
Posted on Mar 27, 2017
SOURCE: whirlpool dryer (electric) model:LER5620KQ1
might be a blown thermal fuse in the exhaust channel
Posted on Dec 15, 2007
SOURCE: Intermitten Heat up
I would like to thank the ones who responded to giving me a 'hand' in repairing my dryer. I did like you said & changed out the coils & now the dryer is working like it should.
Posted on Apr 12, 2008
  • 686 Answers
SOURCE: Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Posted on Mar 12, 2009
Sea Breeze
  • 4655 Answers
SOURCE: dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
Posted on May 22, 2009
  • 10865 Answers
SOURCE: My dryer heats up, but the clothes dont get dry w/o 3 full cycles
Hello. sorry for your trouble, let me help you. Let me begin by saying that the most common cause for what you describe is lint partially blocking the exhaust, either in the pipe, outside where the pipe exhausts, or when you remove the pipe from the back of the dryer, in that hole.
that being said, here is a detailed explanation of all of the possible causes
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Posted on May 27, 2009
My Whirlpool clothes dryer model GEW9200LW0 stopped drying completely. The drum turns but no heat. It began slowing down the heating process approx. 2 years ago. Any suggestions?
Electric Dryer Does Not Heat
  • If your Whirlpool electric dryer is having trouble heating, you should check all of the thermostats, the thermal cut-off, all fuses and the electric heating element for continuity and proper connection.
Apr 18, 2011 | Whirlpool GEW9250 Electric Dryer
My dryer wont heat up or shut down
It's not heating up because the heating element is broken and should be replaced. It won't shut down because the thermostat isn't sensing heat and continues to run while expecting heat. So replacing the heating element should get it running properly.
Mar 23, 2010 | Whirlpool LER5636P Electric Dryer
Electric dryer doesn't heat.
Probably a bad heating element. There are a few different styles, you'll just need to lookup your model number on an appliance parts website, find the right part, and then do a quick search on replacement. There are probably ten or fifteen websites that have instructions to replace heating elements.
Here's one where you can buy the part, the element is part number 17.
http://www.appliance-parts-warehouse.com/whirlpool-parts/Whirlpool-Dryer-Parts/Whirlpool-Parts-LER3624EQ1/Whirlpool-Parts-81777.cfm
Jan 15, 2010 | Dryers
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
The dryer is heating on air fluff.
Good Afternoon,
Is this dryer Electric or Gas?
Mar 27, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Jan 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
ELECTRIC DRYER WILL NOT HEAT
Can you verify model number, it usually starts with WE
Jan 21, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Duet Dryer is scorching clothes
there is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Oct 27, 2008 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
431 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
