Question about 2wire (1000-100052-000) 802.11g/b Wireless Adapter
Unable to install hardware 2 wire wirless pci card
Win xp sees the card but when i go and try to install the drivers it says "unable to install hardware." Please help
  • 2 more comments
  • Anonymous May 11, 2010
    does your card appears under the network adapter on the device manager? does it have any yellow/red mark on it?
    does it do this with all hardware you try to install or just the wifi card?
  • foamesh May 11, 2010
    is XP detecting the device and then asking for the driver? Can you look at the Event Viewer and see any related errors in the 'System' section?
    Have you tried installing without the card in place?
It has a yellow question mark
Posted on Feb 19, 2008
6ya staff
SOURCE:
Win xp will not shutdown installed new Nvidia Geforce 9300GS PCI
hello sir
u need to do two things
*deactivate the onboard vga adapter from the bios
*and install the official lates driver for ur card
if u can't find it tell me wht's ur operating system i will provide u a download link
Feb 13, 2013 | Nvidia Geforce 9300GS, PCI Express Video...
P5PE-VM with Win7 has no display on PCI video cards-EVGA 2600 or EVGA gt 220. Both cards ran fine with Win XP. What do I need to do?
Hello here is the mainboards homepage:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
Are you running 32 or 64 bit system ???
Make sure the video driver supports windows 7, 32 or 64 bit.
The video card can sure run fine on windows xp but not in windows 7 as it is a totaly different system.
The mainboard has a 1 x AGP 8X slot.
So now you maybe has to find a video card that supports windows 7
Try also to download a manual.
Good luck
Dec 04, 2012 | ASUS P5PE-VM Motherboard
PC TV PCI Internal Card w/ Phillips SAA7130 PCI TV Card
You don't need to do anything with the modem at all, other than remove it. Uninstalling the modem drivers will not affect theTV Tuner. Removing the card will disable the feature automatically, so dont worry about that. As far as the TV tuner is concerned, just pop it in, and install the software. If the software is giving you troubles, try going to manufacturer's website and search for drivers.
Aug 06, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Trying to install a logitech rj45 network adapter (ethernet card). I have xp. BUT (a) the computer does not list it under network adapters (i already have one which i think is integrated on the motherboard...
Dear sir,
Welcome to once again Fixya support
According your problem it seems to be your try to install faulty Network card. So better is check with new good card.another possibility is some time pci slots fail to recognise a hardware, so try it with another pci slots of mother board.According to you onboard network card is dead, means motherboard fails to work when connect to a network,after successfull installation of network card also the possibility of motheboard not allow you to work with new network card ,same situation may arise,i am also managed same problems in several customer place while working as an computer hardware engineer.So try with new network card it may solve your problem
good luck
Jul 23, 2009 | Computers & Internet
This card freezes the system
Hi and welcome to FixYa,
Two possibilities:
  • IRQ conflict - try installing the TV card in another slot or switch the other cards. Normally, the PCI slot right after the AGP or video card is shared. Preferable location would be where there are no immediate cards already installed right next to the TV card;
  • hardware fault - only solution is to replace the card.
Good luck and thank you for using FixYa.
May 28, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Motu MK2-2408 PCI-324 WIN-2000 and XP/ no conection to interface
check in control panal, check the following folder:
default programs, network and sharing center, problem report,
realtek hd audio m, sound,serity center, system, windows firewall,
last check windows updates
after that if you conitunueing to have these issues i will help you fether on this problem
rod is the candymangandy
Jan 26, 2009 | Gigabyte GA-6VTXE-A Motherboard
Intex sound card driver for win vista bit 32
1.connect to the internet
2.Go to Device Manager
Look what your driver is missing
3.Update.
enjoy!
Nov 22, 2008 | Microsoft Windows Vista Ultimate Edition
H D Audio Driver fails to install
Have you checked to see if the driver is already installed, and the volume is just turned down? (Start> programs > accessories > entertainment > volume control) If so, try going into Device Manager (right click My Computer > properties > hardware > device manager) See if the sound card is showing up there as a yellow question mark or other error icon, it will stand right out. If it's there, right click, and uninstall it. Now (still in device manager) press the button that looks like a computer screen with a magnifying glass on it, that will scan for hardware changes and pick up the sound card, which windows includes the driver for automatically. If this still doesn't work, try downloading from realtek here, and installing that. Hope this helps.
Jul 17, 2008 | Microsoft Windows XP Professional With...
Windows XP SP3
Hello, Lore.
Did you mean DWL-6510 or DWL-G510?
I have some comments for the last one; if it is not your PCI-card, I hope the solution is alike, at least.
My PCI-card is G510 version C and I recently posted a comment on a certain Internet Forum. See what I wrote:
First of all: D-Link simply mistreated all the costumers who bought version Cx.
The best thing to do:
1- Get the latest drivers from Australia site - www.dlink.com.au - (look for SUPPORT and not "quick find").
2- Specially for Win XP-SP3, try the USA site; you will need to follow this path because the update file is very hidden on the site: click support / FAQ / search for "G510 SP3" and see the answer for the only question that is there (so far); download the newest driver for SP3; this driver has no installer; you will have to use it as an update if you have already a driver installed (click "properties" and "update driver" on the device located at control panel / system / hardware); if you have no driver already istalled, you will have to do the opposite of DLink directions: install phisically the card before installing driver, click start / control panel / system / hardware and search for a "?" sign, click on it and provide it the downloaded driver.
Good luck!!
Jun 20, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
PCI adapter did not install
I don't know how you could have installed the drivers BEFORE you installed the hardware... Shut down and UNPLUG the system; REMOVE the new PCI card, then hook up the power and boot the system back to the Desktop. Check the Device Manager to be sure you're not showing any problems; if everything seems back to normal, shut down and unplug the system a second time, then install the PCI card again, restore power, and prepare to reboot the system. Be SURE that ALL of the PCI cards are fully seated in the slots, and that the main power cable (from the PSU) is fully seated in the connector; IOW, check the system just to be sure that nothing has come loose while you've been working inside the case. Next, boot the system again; Windows SHOULD detect the new PCI card during bootup, though it might NOT request drivers, if they are already embedded within XP itself... Once you get back to the Desktop, open the Device Manager and check to be sure that the new card has been detected and properly installed. If you see any question marks, error messages, or exclamation marks, take detailed notes, and post that information here, so we can help you troubleshoot the problem... Good luck; I can only give you general advice about this, because you didn't provide any specific details about your new hardware, but with a little luck, you'll get everything working without any more heartburn...
Mar 31, 2007 | D-Link DU-520 - 5-Port USB 2.0 PCI Adapter...
2wire (1000-100052-000) 802.11g/b Wireless Adapter Logo
115 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ekse
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
