Question about Canon PIXMA iP90 Mobile Printer
Canon ip90 printer
I had a paper jam. After removing paper. and attempting reset. printer spools but will not feed paper
  • 5 more comments
  • Allen B May 22, 2008
    My iP90 won't feed paper. I've tried the cleaning procedure suggested. The paper feeds about 1/2 inch, then, rotates about 10 degrees and stops. Canon support isn't heplful.
  • lillianll Aug 25, 2008
    I have the same paper feed problem. My printer had been working fine, but now it's useless. I tried the solution offered (cleaning the rollers), but it still won't feed paper. Aaaaaaaaaaaaaah!!
  • joebrigham1 Aug 25, 2008
    Paper shifts 10% right in printing process
  • dbengali Dec 06, 2008
    I have the same issue. tried cleaning the rollers as suggested and it did not help. paper sill feeds a little, then rotates 10 degrees and jams. if i help it through it feeds but roughs up the right edge. any other solutions? is this just what happens to this printer after a while? is there anything i can open it up to fix? it is beyond its warranty.
  • pjnied Mar 25, 2009
    My IP90 feeds paper about 1/2 inch and then stops. A small dimple is left in the middle of the leading edge of the paper which seems to be the jam point. HELP!!
  • Anonymous Mar 16, 2014
    how to remove paper jam in printer canon mp 287
  • Anonymous Mar 21, 2014
    how do I reset
  • 24 Answers
The printer should be on,remove the paper from the printer(if there is any),press and hold the down arrow/cancel button, release the button when the power light blinks 3 times ... The printer will rollers will automatically revolce and clear all the jams.. When the power light is green then repeat the same step 3-4 times.. To confirm the paper jam is cleared then feed 8 1/2 * 11 paper in the printer and again press the down arrow button and release the button once the power light bliks for 3 times and then release the button. If the printer feeds properly it confirms the hardware of the printer is fine.
Software issue: Go to printer and faxes in computer and check the icon. If it says.. 0 paper jam then, delete the icon and chcek in the device manager if there is an entry of usb printing support under Universal Serial Bus controller .. if the entry is there then delete it. Insert the printer cd in the computer and unplug and replug the usb cable from the printer. If the setup screen comes up then exit out of it and the printer drivers will get updated. After that tried to print another tets page from the computer. It will definately print. Thank you.
Posted on Jan 22, 2008
This problem was driving me so crazy I started to shake my printer and heard a little rattling sound. I turned it upside down and a little bead fell out (a pony bead, the kind you use in arts and crafts). Somehow it must've fallen into my printer in the last day or so. Anyway, voila! The problem is fixed!!! So others having the problem may want to try that very primitive method of turning your printer over and shaking it a bit to see if anything accidentally fell inside...
Posted on Aug 25, 2008
Canon ip90 has error message 1300- there is no paper jam- have tried to reset- no luck -help
Hello there Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 03, 2010 | Canon PIXMA iP90 Mobile Printer
Paper will not start feed in on it own
Probably no paper jam, but put a ruler across the top across where the switches are, if it's bowed down some the frame has been bent. Any weight, luggage,etc placed on top can bend the frame and that restricts the paper path and you need a shop repair.
Jan 08, 2010 | Canon PIXMA iP90 Mobile Printer
My Ip90 won't feed paper when I try to print a job.
If the paper does not feed properly it could be due to the follwong causes.
Cause 1 : Inappropriate paper type used
Action : * Check to see if the paper you are printing on is too thick or curled.
* Check if the paper exceeds the load limit mark, if it exceeds, load less paper.
Cause 2 : Paper Feed Roller is dirty.
Action : Follow the steps described below to clean the Paper Feed Rollers.
If envelopes or post cards do not feed properly, even after correctly any paper curl, clean the Paper Feed Roller.
1) Ensure that the printer is turned on and there is no paper loaded in the printer.
2) Hold the RESUME/CANCEL button down and release after the POWER lamp flashed there three times.
The paper roller rotates as it cleans.
3) Repeat this cleaning operation one more time.
4) Load a sheet of plain paper in the printer.
5) Hold the RESUME/CANCEL button down and release after the POWER lamp flashes three times, then feed a sheet of paper.
Cause 3 : Paper jams.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Output Slot Cover, whichever is easier.
* If the paper tears and a piece remains inside the printer, open the Print Head Cover and remove it.
Caution: Be careful not to touch any components inside the printer.
* If you cannot pull the paper out, turn the printer off and turn it on again.
The paper will be ejected automatically.
2) Reload the paper into the printer and press the RESUME/ CANCEL button.
If you cannot remove the paper or if the paper tears inside the printer or if the Paper Jam error continues after removing the paper, contact the Customer care center.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 03, 2009 | Canon PIXMA iP90 Mobile Printer
Paper jam in Canon PIXMA iP90
one of your feed gears has poped out of placeor one of the teeth is broken,check the paper path with a flashlight you will probably see one loose.
Good luck
Aug 28, 2009 | Canon PIXMA iP90 InkJet Printer
I have a Canon mp450 also jamming paper after about 1 inch.
Jun 15, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper does not feed in straight.
most printers have a back door that some paper jam is in place.
May 24, 2009 | Canon PIXMA iP90 Mobile Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Paper jam
May 10, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
HOW DO i FIND THE PAPER THICKNESS LEVER SO CANON S330 WILL NOT JAM?
Oct 14, 2008 | Canon S 330 InkJet Printer
Printer
Aug 08, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Paper Jam Error
check the paper feed section of the printer. it may be item stuck in the paper path. causing the paper jam senor to stay on. also it know for these printer to have a waste in full. this will stop all workings of the printer. as these printer only have small waste ink pad in them. Need to know if the printer is flashing just green or if it flashing green led then a orange one.
Sep 23, 2007 | Canon PIXMA iP90 InkJet Printer
Canon PIXMA iP90 Mobile Printer Logo
1,063 people viewed this question
old marine
old marine
