Question about Dell W1700 17 in. HD-Ready LCD Television
Dell W1700 no video no audio
My TV died today - the power light is on but no one's home. The screen goes black after 1 second of flashing the LCD test screen when it's in PC mode. Absolutely no reponse in the TV mode. The speakers crack when I switch from PC to TV but they've always done that. I've reset the TV by holding down the remote's power button for 20 seconds. Also unplugged everthing and replugged one at a time and still nothing. Any suggestions? Dell won't touch it - out of warranty, and I've found some shops who may be able to fix it (Dell's recommendations). I don't know if it's an inverter problem since I also have no audio. Thanks.
  • 2 more comments
  • metta08 Jan 22, 2008
    Thanks for the condolences and possible hope, ikenfixit. I might be interested in sending it to you if you can provide more information.
    Thanks again.
  • Anonymous Mar 24, 2008
    how to disassemble dell w1700 lcd tv
  • st620 Feb 05, 2009
    Dell W1700 17" lcd TV The power light is on but no one's home. The screen is blank. Absolutely no response in any mode. I can heart the speakers crackle when I put my ear up to them. I replaced the screen illumination PC board after hearing that would fix it. Any suggestions? Dell won't touch it - out of warranty,
  • preludedez Mar 05, 2009
    Today I went to repair this for a friend. I noticed on the board one the far left had 2 220uf 25v caps. One was swollen to I replaced both of them. I now see the faint red blue green white box floating around but it does not iluminate the entire screen. I didnt notice anything else on the other boards gone. It sucks cause these things take so many screws lol. Any input thanks
    Problem Solver:
  • 9 Answers
It would probaly cost more than its worth to him to send out to get fixed. but thanks
Posted on Apr 19, 2009
    Scholar:
  • 163 Answers
We may be able to help if you cant get factory results.. Need to see the unit however.. Sorry as these have multiple issues..
Posted on Jan 22, 2008
SOURCE:
When I turn on my tv the screem keep black but I lisent the audio.
the issue here is with the back light on this LCD TV.
What you can do to check this in most cases is hold a flash light to the screen to check to see if there is a image, if so then your back light is the problem and another one would need to be ordered for your tv.
1. Check back light
worse case scenario is the inverter that controls the back light as well that might not be firing.
Thanks for using fixya.com I hope this information is Very helpful to you.
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 27, 2010 | Dell W1700 17 in. HD-Ready LCD Television
Dell w3000 has green power on no video just audio only
Firstly i would suggest you to perform Self-Test Feature Check (STFC)
Your LCD TV when used as a computer display through DVI and/or VGA connection provides a self-test feature that allows you to check whether your LCD TV is functioning properly. If your LCD TV and computer are properly connected but the LCD TV screen remains dark, run the LCD TV self-test by performing the following steps:
  1. Turn off both your computer and the LCD TV.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital(white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the LCD TV.
  4. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the LCD TV cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually
This box also appears during normal system operation if the video cable becomes disconnected or damaged.
Turn off your LCD TV and reconnect the video cable; then turn on both your computer and the LCD TV.If your LCD TV screen remains blank after you use the previous procedure, check your video controller and computer system; your LCD TV is functioning properly.
OSD Warning Messages
A warning message may appear on the screen indicating that the LCD TV is out of sync range.
See Specifications for the Horizontal and Vertical frequency ranges addressable by this LCD TV. Recommended mode is 1280x 768 @ 60Hz.
_____________________________________________________
Thanks for using fixya technical support. You have a wonderful day
Jun 03, 2008 | Dell W3000 30 in. HD-Ready LCD Television
Today I noticed that when turning on computer, after 1-2 mins the screen goe black and I cant see anything. I noticed in the past month that occasionaly I get lightening flashes in the background. this...
To determine if the LCD screen is faulty ot the video card, connect an external monitor to the laptop's video port. Power up the external monitor first and the boot up the laptop. The video image should automatically switch to the external monitor. If you don't get flashes on the monitor then the video card is OK and the fault lies with the LCD screen. Flashes coud be caused by a faulty inverter or a faulty CCFL lamp. A fault is usually easier to diagnose when it is not intermitten.
Jun 08, 2009 | Dell Inspiron 6000 Notebook
LCD TV PICTURE STAYS ON FOR 45 SECONDS THEN GOES OFF FOR 3 MINUTE
video board is shot, providing u still have sound. must replace.
Jan 27, 2009 | Dell W1700 17 in. HD-Ready LCD Television
Dell W1700 LCD TV static audio and b/w picture
Hi bsut96,
Check the cable between the monitor and the box for damage. Try a new cable. It may be a problem with the input board but it sounds like a cable problem. Let me know what you find and please rate this solution. Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jan 20, 2009 | Dell W1700 17 in. HD-Ready LCD Television
Screen blackout
I had the same problem and fixed it with a new backlight inverter board. It was a pretty easy install. The part is available on eBay. http://cgi.ebay.com/New-Inverter-for-Dell-W1700-17-inch-LCD-TV_W0QQitemZ400017456720QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116
Nov 07, 2008 | Dell W1700 17 in. HD-Ready LCD Television
Dell 17" lcd tv monitor
Follow the link below for solution.
http://babelfish.yahoo.com/translate_url?doit=done&tt=url&intl=1&fr=bf-home&trurl=http%3A%2F%2Fangelitodiaz.blogspot.com%2F2007%2F10%2Fmonitor-dell-w1700.html&lp=es_en
Oct 11, 2008 | Dell W1700 17 in. HD-Ready LCD Television
Dell w1700 power and no sound or picture
The inverter is out a very common problem on that unit. www.lcdrepair will fix the unit for $59
May 25, 2008 | Dell W1700 17 in. HD-Ready LCD Television
Black Screen on W1700 LCD TV
As i said early ther should be an problem with your power card or ram...please upgrade it...
Dec 31, 2007 | AOC LM729 17" LCD Monitor
Dell W1700 HDTV ready problem
I had the exact same problem. Another thread on this site recommended replacing the inverter from www.lcdpart.com
I ordered the replacement inverter from their San Francisco office this past Friday. I received in less than 72 hours later and I live in Tampa. AND THIS IS THE HOLIDAYS.
Anyway, they have a tutorial installation instruction on their website for the Dell W1700. I have never worked on a tv, but with their tutorial it took me about an 1.5 hours to disconnect, disassemble, repair, and test the tv. Everything now works again... and for only $90 including shipping.
Nov 25, 2007 | Dell W1700 17 in. HD-Ready LCD Television
Dell W1700 17 in. HD-Ready LCD Television Logo
581 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
