Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Green light flashes 7 times on power-up then turns red (off).
This problem just started. When I turn the set on the green power light flashes normally about 7 times as if warming up but then turns red and the unit shuts off. Repeated attempts have the same result.
  • 3 more comments
  • lakeman Jan 22, 2008
    Thanks, but I don't think that's the problem. The light simply turns from blinking green to red (with no blinking) just like when the set is powered off. I had the same problem several months after I first purchased the set but the problem was so intermittent that I never called service. Back then when the set wouldn't start,I was always able to get it to stay on after four of five restart attempts. Now after dozens of tries no success.
  • lakeman Jan 23, 2008
    I am still looking for a viable solution. I would like to have "ctf1800" weigh in on my issue. One of his solutions to a similar problem with the same model Panasonic TV was to replace the thermal fuse. I would like to have a bit more detail as to where this fuse is located, how to identify it and where I could get a replacement? Thanks.
    Thanks for your comments but my online research suggests that the poor-bulb problem is pretty much isolated to the "13" model and that the bulb in the "14" model which I have was much improved.
    Be patient with me - I'm not trying to trump your experience but rather apparently am not doing a very good job of explaining my problem. The "red" replacement error code indicator lamp located beneath the screen has never come on. When I say the green light flashes 7 times and turns red, I am talking about the light on the power (on/off) button that shows green when the unit is on and warmed up and that shows red when the unit is turned off.
    Sergeant:
  • 226 Answers
Re-seat the Bulb about 5 times of nothing happens try to replace it with a new one and re-seat again. My final and last suggestion is send your tv to the service center for repair. hope this works.
good luck
Posted on Jan 23, 2008
  • 48 Answers
There's a problem with the power connections inside your tv.. there might be some ICs that are burnt out that's why it turns off after starting up... you can have it fixed by a technician just to make sure.. they have the gadgets for that...
    Genius:
  • 1,067 Answers
Ya thers class action law suit on that bulb your talking about it will go out after 3 mo pp say its reall bad
http://www.consumeraffairs.com/home_electronics/panasonic_lcd_tv.html
I read in the various forums that frequent lamp failure can be caused by a defective ballast. I have not seen the schematices for the TV but typically a ballast controls current flow in a lamp. If I understand your post correctly it sounds like you have had a lamp failure per month for three months. I would recommend that you contact Panasonic 800-211-7262 and see what they propose. I think there is a design flaw with this model and they may be taking care of the problem. I would expect that a repair to the ballast would be a shop repair. Please post what response you get from Panasonic.
call them alot pp say they give u free one cuse they knw better ok
Posted on Jan 22, 2008
  • 2 more comments
  • nick helpap
    nick helpap Jan 22, 2008
  • nick helpap
    bliicking green to red is bad bulb all over online sorry to say this is the tv that has big issues and class action closed nov 2007
  • nick helpap
    nick helpap Jan 23, 2008
    ok ill look for more info on fuse see if we can get it out for ya ok ill look all over today
  • nick helpap
    but uslay is that bulb and balest on your model thats what breaks dont matter if its 2 weeks 1 week 1 yr 6 mo those bulbs are junk ok they dont last right all over insternet bad design
  • Panasonic Master
  • 8,617 Answers
You may want to check the airfilter for being clogged. That can cause the setto shut down. Clean the air filter then try it again.
    New Friend:
  • 44 Answers
You are going to need a new lamp for the tv.
No picture even if the power is turned ON.
LAMP indicator blinks red.
Please replace lamp with a new one.
Follow this link
http://service.us.panasonic.com/OPERMANPDF/PT43LC14.PDF
pages 80-82 will explain how to replace the lamp!
Thanks so much!
  • 2 more comments
  • Phil Taul Jan 22, 2008
    Also on page 82 there is a list of error or warning indicators... So that can be a big help in finding the problem if there is more then what you first described.
    Hey man can you change what you rated me because I did tell you how to fix the problem.
  • Phil Taul Jan 23, 2008
    I am 90 percent sure your problem is the lamp. I mean the error codes even line up with that issue. If you wanna know where the fuse is check out the manual I provided a link too. But its not a fuse problem its a lamp problem.
    Ok if you want your online research to trump my years of experience working on tv's go right ahead. This is actually a simple fix, error code says its a bulb... so you replace bulb and tv is fixed.
  • 871 Answers
Hi
i dont know specifically whats wrong but the way you describe it as if warming up reminds me also of my moms tv back in 2000's
normally we had to had it checked out by a technician and found out that it was a busted chip inside the board.
i might say you are having that same problem since it has the red light indication that something is wrong.
i would suggest you do the same too. bring it too a service center and have it looked from an expert repairman. althought it may be a pain in the wallet, but the outcome overweights the issue.
hope this helps.
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
When i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked...
when i turn the printer on the light flashes amber several times, then green then repeats flashing amber, and back to green etc. turning it off and back on made no difference. last time it worked normally after being off for a couple of days, but now it is doing that again.
Amber light flashes 7 times, then green for a couple of seconds, then amber 7 times etc.
Jun 02, 2010 | Canon BJ I6500 InkJet Printer
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
On off light blinkinking from green to red and I
Canon IP3000 INK counter reset
Can gave it a go may work
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Dec 14, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Apr 22, 2009 | Televison & Video
Hbh-pv705
I had this problem. I fixed it doing follow: hold volume keys together, so the indicator is flashed red and green (reset to default settings mode). Then press power button to turn the headset off. Then turn it on again and try to find the headset again from my phone. Then select "pair" from phone menu and typed "0000". The led stopped flashing and headset was connected. Before this my phone couldn't see the headset at all. Hope it will help you! (sorry for my English, I'm from Russia =))
Nov 27, 2007 | Sony Ericsson HBH-PV705 Headset
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
279 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
