Question about HP Pavilion a1410n (ER890AA) PC Desktop
Dvd drive drive is detected under my computer but when you put "any" type of cd or dvd in nothing happens except the green light flashes about 8 times and then nothing.
  • coldwatr Jan 22, 2008
    windows xp ..i have tried all of that ..I can hear the drive trying to turn but its like when it doesn't detect a dvd or cd....
    nothing...
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
Hey, now, sometimes your burning software just gets corrupted. If there are no error checks in device manager, you need to try to download the burning software that came with your computer. If it came with the computer, you will need to go to HP for it, not the software burning site, as the programs are slightly different. Seems odd, but the CD/DVD drives DO NOT NEED DRIVERS. In order to work, they DO need a good functional burning program (not microsoft's). You can find out which burning program came with your computer with an excellent freeware program called Belarc Advisor--it will list all hardware and software, versions, codes, etc. Then go to HP and redownload it--they may have an upgrade. Bet that will solve it.
Posted on Apr 05, 2008
    Guru:
  • 55 Answers
Sunil Panem is correct if this does not work u can go for the reload of the o.s......hp send u an original version of the o.s with the system
to go on for a recovery u can reload the o.s
can do this
restart the computer and keep tapping F11
u will see recovery manager
click on the advance option
click on system recovery
then click on next and so ojn
after the progress is over u ca click on finish
then enter the setup
and see if it works if it still doesnot work then u can go for the replacement of the cd/dvd drive
Posted on Mar 13, 2008
    Scholar:
  • 80 Answers
Hi
Pls uninstall and reinstall the drivers for the cd/dvd drive and check in device manager if the driver for the cd/dvd drive has any red X mark or an exclamation mark.
If this doesnt work, then delete the filter from the registry.
Click Start , click RUN and then type "regedit " into the open box in the Run window.
The registry editor window appears.
Select Computer in the main window.
Click File , Export , type a filename that is easy for you to remember, and click Save .
A copy of the registry has saved for back-up purposes to the Documents folder. If problems occur after using these steps, browse to the file and double-click it to restore the registry.
Click the plus sign (+ ) next to the following items in the list: HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Select 4D36E965-E325-11CE-BFC1-08002BE10318 . Make sure you have selected this exact key name.
Select the LowerFilters value and press the Delete key. Confirm the deletion by clicking Yes .
If an UpperFilters value is also listed, select UpperFilters in the right window and press the Delete key.
Delete all other UpperFilter and LowerFilter values within the 4D36E965-E325-11CE-BFC1-08002BE10318 key if they exist.
If this doesnt work, then you ll have to reinstall XP
Posted on Feb 04, 2008
    Problem Solver:
  • 17 Answers
You Dont specify the O/S but it could be the Autoplay option is turned off.. Try browsing to the Drive via My Computer and double clicking on the CD/Dvd Rom. It should have the name of the DVD or CD as its name. If it doesnt, then there may be a read problem with the drive, If you can manually start the move or drive via the above method, the you need to browse to My Computer, Right click on the DVD drive and you will see an Autoplay Tab at the top. There is a Reset Defaults button if you dont fancy experimenting with the settings, All this is assuming you have some software to play DVDs in the 1st place. Cheers. Pete
Posted on Jan 22, 2008
PC will not boot up. Almost did once but screen went black. Reboot doesn't help. No green light on monitor and PC makes a long slow beep over and over. I have recovery discs but when put it nothing...
Based on your description of your problem, my educated guess is that you have a problem with the system board or motherboard. Checking Compaq support site, it says that beeps are generally heard when a hardware device is not connected properly or has failed.
First thing to try is disconnect the keybaord and mouse and try to start the computer again. What we are trying to do is find out which hardware device might be involved. So start with the keyboard an mouse. If the computer still does not start, remove any periferal drives, like floppy or cd drives.
There are several beep codes, below are a few examples listed:
Beep codes common to HP and Compaq Desktop PCs The following beep codes are common to many HP and Compaq desktop computers. Use these codes first before referring to the other code lists. NOTE: Not all codes are shown. Beeps Description 1 short beep and 1 long beep Memory problem 2 short beeps and 1 long beep (repeats 5 times) Unable to initialize video or video card required but not installed 3 short beeps and 1 long beep CPU configuration error or CPU type is not compatible The following beep codes are common to many HP and Compaq desktop computers that can occur while restoring, flashing or updating the BIOS : Beeps Description 1 short beep Legacy floppy drive or CD/DVD drive not detected 2 short beeps Floppy diskette or compact disc not detected 3 short beeps Unable to start flashing (such as when missing a utility or BIOS image) 4 short beeps Flashing failed (checksum error, corrupted image, etc.) 5 short beeps BIOS recovery successful Try working on this solution and see if you can get the computer to start. Below is a link to a troubleshooting page from Compaq for your computer. This can be a good reference as well.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00899280&tmp_task=solveCategory&lc=en&dlc=en&cc=us&dest_page=solveCategory&tool=solveCategory&query=pavilion%20m8200n&product=3548185
I hope that this information was helpful.
Brian
Jan 05, 2011 | HP PAVILION M8200N PC Desktop
My acer aspire 5100 has stopped detecting cd / dvd drive. When i insert a CD the Orange light blinks instead of Green, it appears as if the drive is reading CD but nothing happens, also the CD Drive is not...
Try the following:
  • Use a CD Cleaner (Or try with a soft cloth with a spirit)
  • Worse case scenario, you will need to take it to repair shop to change leaser head.
Jan 02, 2011 | Acer Aspire 5100 Notebook
My cd/dvd burner won't work. i put in a cd and a green light blinks a few times and nothing happens. My Dell is a dimension E520. thanks!
In MY Computer, check to see if the DVD drive icon is there.
Try a different DVD or CD brand
Check the sata or IDE cable connection to the rear of the drive and also the security of the power rail
Dec 28, 2010 | Dell (M6790) DVD RW Burner
When I put in my DVD nothing happens. I'm not
Your computer may not have a DVD drive, it's only a CD drive.
Nov 26, 2009 | Dell F3534 Touchpad
When I put a CD in the DVD drive, it does not read.
1. If the CD/DVD drive tray not open.
Open "My computer" windowsand select the CD drive . "Right click" onthe CD drive.You will get apop up windows with the "Eject" option.
If it open that's means the power supply is ok
2. If the DVD drive is not showing on my computer windows or the DVD is not detect the CD/DVD disk
Tofix the problem we need to delete the UpperFilters andLowerFiltersregistry key for more details about the troubleshootingstep please follow the below link.
No longer access the CD drive or the DVD drive
3. After follow the above steps if you still face the same problem then need to contact the local hardware vendor.
Aug 06, 2009 | Dell Dimension 3000 PC Desktop
I couldnt watch any DVD movies in my LG X NOTE RD405
Hi
> Go to my computer check for the dvd drive
> Check in device manager under cd/dvd drive for the dvd icon if it is not showing
> Go to run -type - regedit
Search for the upperfilter and lowerfilter registry through find option and delete the registry and reboot the system and check for the status
> If dvd drive shows the optical drive uninstall by selecting the optical drive from the device manager
Apr 02, 2009 | Computers & Internet
Dvd-cd rw drive
This means that your CD-rom drive does not read the CD, it could be that the CD is a different format (DVD, for example) or the lens is dirty or Your drive is faulty. see if your drive is compact or dvd and try the right formats. Try clean your CD-drive lens. If all this does not fix the problem, your drive is faulty. And needs repair.
Oct 31, 2008 | Compaq Presario s4020wm (DK214AR#ABA) PC...
Audio cd and DVD
it is mainly due to two reasons
  1. your operating system don't detect your drive
  2. its data or power cable is not properly connected
In the first case, if you are using xp, open my computer, select control panel, click add new hardware icon
  1. read and do as follows
  2. the computer automatically detect your drive
  3. if it don't detect, using manual method and add the drive
In the second case, only do if you are little technical minded
  1. open cpu cover
  2. check the data and power cables attached to the drive
  3. refix the cable some time it may in loose contact
  4. replace cable if it may contact problem
Jan 20, 2008 | NEC ND-2510A DVD±RW Dual Layer Burner
HP Pavilion a1410n (ER890AA) PC Desktop Logo
56 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
