Question about Sylvania 6727DF TV
Connecting surround sound system
I have a Sylvania 6727df 27 inch combo. We have ATT Uverse. We have connected our tv and cable box to our surround sound system. It works great except for one thing. When we play a dvd or video it does not come tbrough the surround sound. Can you help us connect it so the dvd will work. Thanks
  • shajas52 Jan 22, 2008
    I have a reciever already.....and the cables but it still is not coming out through the surround sound. Is there a setup option that I have to use so that the sound is transfered to the back (coax audio out jack).
    Sergeant:
  • 259 Answers
The surround system has to be set to bitstream or pcm(pulse code
modulation) digital formatted audio. go into menu options audio output format and chane it to either one. And good success.....Meder's TV Service
Posted on May 17, 2010
    Problem Solver:
  • 13 Answers
Get a reciever and then get componet cables then hook it all up through the hdmi cables
Posted on Jan 22, 2008
No signal in all 4 hdmi ports on th new samsung 6050. Tried running from Sony receiver and then direct format uverse cable box. Still no signal. It is as if there is a compatibility problem. Help!
I would try connecting a dvd player to one of the HDMI input on the tv to be sure the tv is the problem.Try new HDMI cable 1.3 version. ATT uverse boxes are alway a source of problems and I would assume it was bad before I would condem the tv. If the tv is bad and it is under warranty an authorized servicer will replsce the main board.
Jun 08, 2011 | Samsung Televison & Video
I cannot get the surround sound to come on tv mode on my friends RCA DLP. Any suggestions? is this a t.v. issue? DVDs and Ipod connections are fine.
The tv must have a stand alone audio output that you would connect the audio composite cables to going to the aux or audio input of the surround sound system. You may need to switch the surround sound system to aux mode or av input 1 or 2 and etc. If you are connecting a cable box or satellite tv box to this television instead of connecting the audio composite cables between it and the tv, connec them between it and the stereo surround sound system.
May 05, 2010 | Zenith XBV441
I'm having trouble connecting the tv to my surround sound system. The surround system says to connect the cables to the "audio out." There doesn't seem to be an "audio out."
I checked Amazon, it says "For connections, you get 1 each composite- and S-video inputs for your DVD player, VCR, or other audio/video device, and a set of component-video inputs for your progressive-scan DVD player or DTV set-top box."
Your TV does not have a audio out since it is a smaller TV. You need to get a tuner and route the sound system through there.
Oct 09, 2009 | Sylvania 6620LE 20 in. HD-Ready LCD...
Sylvania ld320ssx remote code for att uverse
Try 1864. It worked for a Media-Com remote, when none of the other codes worked.
Oct 06, 2009 | Sylvania LD320SSX LCD TV
No volume
Things to check,
1. are you using an external cable/satellite box.
if the answer is yes , verify if you have the audio out of the reciver connected to a surround sound system
If you do have it connected to a surround sound system , verify the surround sound systems volume is up and on the correct source input on the surround sound system
2. if you do not have a external cable/satellite box and and or your not using a surround sound system, and the cable line is connected directly to the television via a coax cable.. then verify that in the audio settings configuration of the telivision you have not accidentally disabled the internal speakers, some tvs have this option , please consult your manual.
Sep 24, 2009 | Philips Magnavox 27MS343S 27" TV
Sylvania Picture on and off
it could be the mainboard is causing the trouble.
Jun 11, 2009 | Sylvania LC420SS8 LCD TV
Att uverse sound quality.
http://www.hdtvsupply.com/gefen-ext-homets-home-theater-scaler.html
The link above is how I fixed mine, because I love the way the functions of Uverse works. Here is the problem HDMI and Optical Dolby 5.1 are delivered in digital packets. The DVR at about 48000. These newer HDMI TV and surround sound receivers are processing the sound packets faster than the DVR can deliver it, and hence, when the TV speakers, (HDMI Source) or surround sound receiver optical source, run out of packets or only get 47999 packets from the DVR instead of 48000, there is a momentary drop out. This is either bad chipset in the DVR, or a sync problem with the software. Dish, Direct TV, and almost all of the cable companies have also had this problem. I had dish, and not only would the sound drop out on the HDMI, but I had to turn off the TV and turn it back on to get sound back. It took Dish about 2 years to fix this. Me I am going to ride it out, because I love the way the Uverse features work, and the honesty of the techs that mad my home visits. They told me that they were working on a software push and shooting for August 2010 to fix this. I am going to write ATT Corporate offices by certified mail RRR, and show them what I had to do to fix their false advertisement, and see if they will credit all or some of the cost of this scaler back to me. In the meantime, if you're not using anything but the TV, set your digital audio on the Uverse DVR off of surround back to stereo, and the dropouts will stop, or buy the scaler. It is an excellent workaround, and it also up converts the DVR's 1080 i signal to clean clear and crisp 1080 p, something ATT will never do. It will also convert the component stereo out into dolby digital sound to the HDMI and optical ins on your TV and receiver. THAT IS THE ONLY SOLUTION I HAVE.
Feb 09, 2009 | Audio Players & Recorders
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Wiring problems
Not certain if HDMI can be used in a setup like this. I'd try it from the home theater (HT) to the TV, and other wiring for the other components.
For video:
All of these should have component connections (Y/Pr/Pb). You'll only need the video cables for each device:
  • Video out from cable, HT, and combo player.
  • Video in to TV. Your choice of inputs.
For audio:
Hopefully, the two output devices (the combo player and the cable box) have digital audio (fiber optic, or RCA coaxial). Otherwise, you'll only get stereo sound. VHS is stereo only anyway.
  • Audio out from cable box and combo player.
  • Audio in to HT.
The TV won't have anything to do with audio in this setup. Alternatively, you could try hooking up all inputs to the TV, and connecting audio out from the TV to the HT. Works best if this connection is digital, for surround.
Jan 01, 2009 | Sony BRAVIA DAVHDX275 Theater System
Connecting receiver/dvd and vcr combo and TV
do u have rca outs form the tv to the aux in of any dvd system sterio unit
Jan 10, 2008 | Sony DAV-FC8 System
Sylvania 6727DF TV Logo
238 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
