On a standard Qwerty keyboard the Caps lock or hold down the shift key to get a capital letter.
Touch screen keyboards are a bit more complex - mine starts with capitals and after the first letter reverts to lowercase and the shift key has to be touched again for another upper case letter.
your answer to this problem is easy. First take the batteries out of the camera, then open the camera ( screws should be in the back) the screen should just pop out of the cover and there is a ribbon cable that connects the screen to the circut board. Gently un-hook that ribbon where it plugs in to the board there might be a slid lock to hold the ribbon in place, it should unlock when you pull the cable out (memorize what position the ribbon is before unplugging). Now the fun part, do the same thing to the other camera, (carefully). To install the new screen, plug the ribbon back into the slot and it should be snug, if not there is a lock on it, gently push it back away from the ribbon ( a little finger pressure). Now, simply put it back together the same exact way you took it apart and don't forget the batteries. Have fun taking pictures...
There is a "quick" button located on the back of the camera just for flashes. It is the first button to the right of the power button and it looks like a crooked lightning bolt arrow that points down. If you are in any picture taking mode, push this button and it will toggle you through each flash option, auto, red eye (eyeball symbol), flash (same symbol as the button, this mode will make the flash work everytime you take a picture), red eye and flash, and no flash (careful, in this mode you have to allow for the camera to focus, the lens will stay open a long time in a dark atmosphere -- if you don't hold the camera still you will get a blurry picture).
well it's not a wide screen tv show it won't really matter but if it is H/D you will find a red/green/blue connection in the back for picture and red/white for sound
