Question about Sanyo PLC XF45 Multimedia Projector
How to check lamp hours on xf-45 or xf-35?
How do you check lamp hours on xf-45 or x4-35 projectors?
  • opticus Jan 22, 2008
    Actually it is a little more complicated than that. One can DL instructions on the LC-XT3 (the eiki version of the XF-45) link here:
    http://www.eiki.com/Support/Article.aspx...
    Problem Solver:
  • 18 Answers
On the XF-45, you push the "UP" button and then the "Menu" button and hold both of them for approximately 20 seconds. After that you will see a bunch of numbers in the top left hand corner of the screen. Using the Left and Right arrow keys, move the "Group" number until it reads 111. Then using the Up and Down arrow keys to scroll through each lamp (0-3).
If you move the "Group" number to 110, you can see total number of hours that socket has run.
Posted on Apr 09, 2008
How do I check lamps hours on a Sanyo PLC-XP51
Posted on Apr 10, 2008
  • 55 Answers
Go to hand controller push menu button, go to tools , in tools should be lamp time
Posted on Jan 22, 2008
Lamp hours on christie LX120
VIP300W X4 lamps
Original unit lamp ,USD120
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Jan 31, 2014 | Christie LX120 Lamp
Where can I find the lamp counter-menu on a PLC-xf-46, I just want to check how many hours are on. I do find the counter-reset menu, but that's not what i'm looking for. many...
hold down the UP button on the keypad for 30+ seconds, a pop-up menu will appear on the screen indicating the lamp hours. if that doesn't work, hold down the POWER-ON/OFF button for 30+ seconds. it's one of those 2.
May 26, 2011 | Sanyo PLC-XF46 LCD Projector
Will not coming on ,standby light is orange temp and lamp light not on
hi,
Just try to reset the lamp hour of your projector. For resetting the projector do the following.
While simultaneously holding down MENU/HELP, ENTER and Down arrow button on the projector, Press STANDBY/ON on the projector.
Remember one thing lamp hour reset is recommended only after the lamp replaced. Before going to buy a new lamp just reset the lamp hour and confirm that the projector doesn't have any other problem.
If these doesn't help then check the lamp of you projector chances for lamp became faulty.
ok
Mar 19, 2011 | Sharp XR-10SL DLP Projector
I have a model and swapped the T45U projector lamp, the projector turns on, but in a few seconds it shuts off, and turns on the LED "Temp" what can this be?
hi,
First of all check the lamp hour . Reset the lamp hour and try again. It is recommended that reset lamp hour only after replacing the lamp. No matter, just reset the lamp hour. If problem doen't repeat the try to replace lamp.
Another possible problem is the faulty lamp cooling fan. Check the lamp cooling fan of your projector. maybe its has some problem.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector.
ok
Feb 12, 2011 | Toshiba TDP-T45U DLP Projector
Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
that model has a history of bad ballasts. you'll need to replace it.
Mar 03, 2010 | InFocus LP350 Multimedia Projector
NO POWER
sounds like a heat sensor or fan problem. How old is the lamp, lamp hours etc.
http://www.youtube.com/watch?v=HvZ2DlVJ790
http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
Sep 09, 2009 | Eiki PowerHouse LC-X4LA Multimedia...
Temp warning
Clear the air flow and replace or clean air filters. that will solve.
Nov 02, 2008 | Sanyo PLC XF45 Multimedia Projector
Infocus LP725 Replacement Bulb
if you don't know exactly how many hours are on the new lamp, you can't be sure it works. since it's a mercury lamp, there will be no contenuity. check the lamp for cracks or clouding, not just burn marks.if the lamp is actually good, you may have a ballast issue.
Nov 02, 2008 | InFocus LP725 and LP735 Replacement...
Toshiba Projector TLP 651 lamp problem
yes resetting the lamp hour might be the issue but not necessarily. It could also be a temperature issue as the fan (s) might have stopped or a temp sensor issue is faulty. check your manual for resetting lamp hours. Regards Kevin Andreassend www.iceav.co.nz iceavtech@gmail.com
Oct 28, 2008 | Toshiba TLP450, TLP451, TLP650, TLP651,...
Sanyo PLC XF45 Multimedia Projector Logo
2,288 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
