Question about Epson (C31C411016) Printer
Epson R300 printer
I had approx 25 sheets of paper loaded into my printer and the next time I tried to print, the printer decided to take all 25 sheets at once and caused a paper blockage, I removed all 25 sheets of paper by force as it had locked solid about 2" inside the printer, now when I try to print with fresh paper I get the message paper not loaded correctly, it is but the printer will not take it. Could I have damaged something internal when I pulled the paper out ?
Thank you
Tony Gibson
  • 55 Answers
Ok " if you look in where the paper is loaded on top there is a small switch with a finger , may be bent. tells printer when paper is low
rubber wheels that pull paper threw may be glazed , take sand paper and go over wheels to ruff up
Posted on Jan 22, 2008
New cartridges, letters in misalignment and double struck words
What Causes a Printer to Be Misaligned? ' Chron.com
smallbusiness.chron.com > ... > Setting Up a New Business Basics
A printer that has alignment problems will not print documents accurately. images and text ... Install new manufacturer's cartridges in the printer. If the cartridges ...
How to Replace & Align Canon Ink Cartridges ' Chron.com
smallbusiness.chron.com > ... > Computers
Misaligned cartridges cause poor overall print quality by producing print lines slightly... Remove the new cartridge from its packaging and remove the colored ...
PDF]Stylus Photo R300 / R300M - Product Information ... - Epsonhttps://files.support.epson.com/pdf/r300__/r300__pg.pdfEpsonEPSON Stylus Photo R300 Series - 1. Printer Parts ... asterisk (*). The printer also works with plain paper. Cartridge. Part number. Black. T048120 ... Letter. SCR1001. PremierArt Matte. Scrapbook Photo Paper for Epson. Letter ..... Unwrap the new inkcartridge. .... misaligned, align the print head (see page 11). Related ...[PDF]Epson Stylus NX430 - Quick Guidehttps://files.support.epson.com/pdf/nx430_/nx430_qr.pdfEpsonAfter you set up your Epson Stylus® NX430 (see the Start Here sheet), turn to this Quick. Guide and ..... Load letter- or A4-size paper in the sheet feeder. 2. Press ... Use the following list when you order or purchase new ink cartridges: Note: We ..
Jan 05, 2016 | Office Equipment & Supplies
Booklet printing pages in wrong order.
I believe this is going to be a software issue. Do a print preview of the booklet first to see if they are showing up in the right order. If they are, then it is a printer issues and I really can't help you there, but it they aren't then you know it might be a software issue. Check you formatting on the document before you trying printing it again.
Jun 30, 2009 | Epson Stylus Photo R300 InkJet Printer
Paper jam error
Dear Sir,
I have Epson Stylus-1390 Photo Printer. Problem is when giving photo printing option thru printer driver printer get error is paper jam..
can you give me solution for the same.
thanks
Jan 09, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson R300 Constant Paper Jam
Take it apart,as fas as you can.clean out all of the paper and chips. The print 5 pages only, twice as the Epson manual says to do , in order to clean itself out.
Dec 23, 2008 | Epson Stylus Photo R300 InkJet Printer
Fake Error Message
I am running Vista Ultimate SP1 x64 all updates and have been trying to sort out the fake paper jam on my Epson R300. I tried compressed air from my workshop compressor; believe me if anything was blocking the feed it wouldn't after I blasted it lol! anyway I also tried running some thick card through and still nothing, did some button pressing to get out of maintenance errors and all sorts of other things. I was about 5 mins away from reluctantly scrapping the printer when I happened across SSC Utility.
I downloaded SSC Utility, but there didn't seem to be much that would sort out the paper jam so out of curiosity I decided to click a few things and then test the printer.
The only thing I ended up Clicking was 'Reset Protection Counter' and that worked, it printed out fine.
so that was my solution, we'll see how long it lasts.
Aug 18, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson R300
Make sure the photo paper is not curling when it goes in. I had same problem before, with paper jam error even though the photo paper did not appear jammed. I noticed the photo paper was slightly curled, so I flattened it out and that solved my problem. Also, if you are loading multiple sheets at one time, try just loading one sheet and see if that fixes it.
May 11, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson R300 printing only in top left corner of page
Change the paper settings in the driver when you go to print. If you have it set to 10x15 it will only print a 10x15 patch in the corner.
Go to START, PRINTERS AND FAXES then right click on R300 and select PROPERTIES. Click PRINTING PREFERENCES and set the correct paper properties. Click OK all the way to desk top and the settings will be saved.
On the printer panel press ADVANCED, scroll down 3 times to PAPER SIZE and press OK. Select A4 and press OK.
Dec 01, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson (C31C411016) Printer Logo
64 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
