Question about Gateway M305CRV Notebook
Reinstalling Windows How do i go about reinstalling my computer.  I have the three CDs that came with the computer(Applications and Drivers, InterVideo, and operating systems).  I don't need to back anything up.   I have received directions over the phone before and was fairly simple, i just forgot the process.  Is there any way i can get directions on how to do this.  Thank You
    Problem Solver:
  • 42 Answers
Here is how to go...............................
  • first make sure that your computer boots first from CD.
  • insert the operating system into your computer.
  • restart your computer
  • on restarting there will be a message that says PRESS ANY KEY TO BOOT FROM CD................... You just press any key as the message instructs.
  • files will be loaded to your machine
  • the press F8 when a message comes
  • hit Esc key and select the partition that you want to install the OS using arrow keys.
  • hit Enter key
  • using the arrow key select the upper option in the message that you see.
  • from there you better be patient and the system will later restart. dont press any key when the message PRESS ANY KEY TO BOOT FROM CD ........ comes.
  • late the the process proceeds until you see the dialog that rewuires you to fill in your name and company.
  • click Next or Press Enter to proceed
  • then enter the 25 cd key character found on the envelope of the cd.
  • Press Enter or Next until the installation proceeds
  • at the end the system will restart, click OK to all the messages
  • select the options that you see, click Next. do the selection according to what you see then click Next till to the end.
  • the system will now be ready for use.
  • run the drivers cd to install the necessary drivers.
hope this will help you most, good luck
Posted on Jan 22, 2008
  • Salehe Kungule
    Salehe Kungule Jan 22, 2008
    has this helped you?
    New Friend:
  • 44 Answers
Make sure you start with the OS disk. Restart your computer with that disk in and then boot from that disk. If your computer doesnt auto boot from the disk go into the bios and set the boot order to cd first. Then follow the on screen instructions. Onces your done installing windows you can use the application and driver cd to install all the drivers.
Safeboot corrupted error 92h message
run the receovery again and wait for the process to finish before removing the cds.
Sep 26, 2012 | Toshiba Satellite M55-S325 Notebook
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
I have a spywhere infection on my advent laptop how do i resore to factory settings?
Using the HDD Recovery System
Your Advent computer uses the latest recovery system that doesn't require any CDs or DVDs to restore your PC to it's original factory condition.
There are two ways to start the recovery -
Restart your computer. Then Press F10 repeatedly until the message "Starting System Recovery" is displayed.
In Windows by clicking: Start / All Programs / System Recovery / System Recovery.
The recovery will load and display a box with one option:
Non-destructive recovery: this option will restore Windows, supplied applications, and drivers. This option will not destroy your documents or programs. These will be backed up along with the registry. These are restored at the end of the recovery process.
To access the recovery options below that erase all data from the computer, click the Advanced button.
System Recovery - No format: this will reinstall Windows, supplied applications and drivers. It will move your files to a folder called "My old disk structure". Any applications (except those supplied) will need to be reinstalled.
System Recovery - Quick format: this option will erase your hard drive including your personal files. Windows, supplied applications and drivers will be reinstalled.
Select the Non-destructive recovery option and press Next.
You will be informed about System Restore in Windows, click Yes.
The recovery will begin. Once this is complete click Restart.
Feb 28, 2011 | Computers & Internet
I cant find the webcam
here you go My Computer -> Manage -> Device Manager -> Imaging Devices
if you find webcam driver, then you webcam is ready to use
Dec 29, 2010 | ASUS Systems K50IJXD1B Notebook
Laptop wireless work, was reinstalling windows
Check among the CDs you got when you bought your laptop. You'll see one called 'drivers'. Inside your drivers CD you'll find a Network Adapter driver. Install it and your wireless should work.
Oct 05, 2009 | Computers & Internet
Reinstalling windows on desktop
you will not be able to get the drivers for the packard bell computer, especially for windows XP. the computer was discontinued way before XP came out, as well as the company going out of business. There is a new packard bell company, but based in Europe only. In addition, when you use the HP cd, it will probably say not compatible with non-hp computers.
your best bet is to download you important information and store it on a new unit.
Aug 18, 2009 | Computers & Internet
I want to clear my computer want to take everything out and reinstall install everything
Back up your data.
First and foremost, it is absolutely necessary to backup any data you want to save. Usually, reformatting and recovering a Dell system will result in the complete loss of any data added to the hard drive after it shipped from the factory. The usual place for personal data to reside in the My Documents folder. You can burn this info to CD/RW, or if you're on a LAN network, you can transfer the data from the Dell PC to another computer nearby. Do not forget to backup your Favorites folder and your Outlook or Outlook Express files--otherwise your address book and contacts will be lost
Locate the Recovery Media
Most Dell computers will also have shipped with a software box that contains several types of media. This is the Windows CD and the various application CDs you will use to revert the system. If you cannot find these CDs, you'll need to visit the Dell website and navigate to the support section. Drivers are normally stored on their online database for quick recovery.
Installing XP on a Dell System
When you reboot with the Dell XP CD in the drive, you will come to this screen. It gives you the option to repair the installation or continue reinstalling a fresh copy of the Operating System. The repair will generally preserve your data and attempt to fix any corrupt or missing data. If you decide to proceed with reinstalling the Operating System, all data will be wiped from the drive.
To perform the repair, simply press R and the system will attempt to replace those corrupt files.
To install a fresh copy of Windows on your Dell computer, press the ESC key.
Once the install is complete, you will need to add the the driver disks one at a time until all hardware has been successfully installed.
You will then need to use the application CDs to recover any applications that came preinstalled on the system--such as MS Works, MM Office, Quicken, etc...
Jul 29, 2009 | Dell Computers & Internet
I have lost my recovery disc supplied with my advent 7000 laptop can you help please
advent 7000 recovery system that doesn't require any CDs or DVDs to restore your PC to it's original factory condition.
  • There are two ways to start the recovery -
    • Restart your computer. Then Press F10 repeatedly until the message "Starting System Recovery" is displayed.
    • In Windows by clicking: Start / All Programs / System Recovery / System Recovery.
  • The recovery will load and display a box with one option:
    • Non-destructive recovery: this option will restore Windows, supplied applications, and drivers. This option will not destroy your documents or programs. These will be backed up along with the registry. These are restored at the end of the recovery process.
    • System Recovery - No format: this will reinstall Windows, supplied applications and drivers. It will move your files to a folder called "My old disk structure". Any applications (except those supplied) will need to be reinstalled.
    • System Recovery - Quick format: this option will erase your hard drive including your personal files. Windows, supplied applications and drivers will be reinstalled.
Nov 05, 2008 | Computers & Internet
System recovery
Yes. Using the cds supplied by dell, boot the operating system cd. Delete the active partitions, then quick format it and proceed to reinstall windows. Once windows is installed, use the supplied application and driver cd to reinstall the applications and drivers that came originally with your computer, again following the onscreen instructions.
Jun 30, 2008 | Dell Inspiron 2200 PC Notebook
Sound is not coming from the note book
Computer CD-ROM drive help and technical information. CH000214, CD-ROM Tray not opening. CH000215, Getting no sound from audio CDs.
Good Luck, Please dont for get to Vote, Thank You.
Dec 22, 2007 | Acer Aspire 5610-4648 Notebook
Gateway M305CRV Notebook Logo
65 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
