Question about Casio Exilim EX-Z750 Digital Camera
Blurring/grainy pictures, and lens error
My camera has recently started showing lens error, and all my pictures are blurry and grainy looking and have a yellow tint to them
  • 871 Answers
Hi
here are some tips that may be the reason why you are having those blurry, grainy and yellowish pics.
It is important to keep your lens away from excessive heat (i.e., hot car in summertime or a heat source in a home). This will help prevent the greases, used in most lens barrels, from breaking down into an oil that can run inside your lens and cause overexposure by slowing down the diaphragm.
Use rear element lens caps on your lenses when they are not on the body. Wide angle lenses, by design, have rear elements that extend out farther then the lens barrel and are susceptible to wear, which can ruin sharpness.
Always use a filter or lens shade (hood) to protect the front element.
Never, ever, oil your lens. A minute amount of oil on the diaphragm blades will cause them to operate slowly.
hope this helps
Posted on Jan 22, 2008
I have a blurry image distortion in the center of the picture only- everything else looks fine- a solution to my problem?
is the central of lcd divice bumped ?
1-are your lcd device show the correct image without any blur before taking the image ?
2- or this blur shown after taking the picture ?
for the first : your device lens should be clean through inner side.
for the second : the lcd should be checked , since the center of lcd may be bumped.
please let me know your checking result.
good luck
gorbesia
Jun 14, 2011 | Nikon Coolpix 4600 Digital Camera
When I take a picture with my Logitech Quick Cam, It shows fuz. How can I get the fuz out of my camera to where it takes pictures like it should?
There's a few things you can do to make it look clearer:
Make sure there is no dust or dirt on the lens, you can clean it with rubbing alcohol and a q-tip if needed.
Make sure the bundled software isn't sent to a filter that causes blurriness.
Try taking the pictures in situations with increased lighting. The sensors in webcams are generally cheaper ones and perform poorly in low light situations.
Please note that unless you have a HD model, the camera is probably taking a relatively low resolution photo that can cause it to look grainy or blurry when viewed.
Please leave feedback if this was helpful. Thanks.
Apr 04, 2011 | Logitech Webcam
Got no picture all blurry
No picture or one that is all blurry? If blurry,
Clean the lens and make sure it is not loose or damaged. The camera cannot produce blurry pictures at distances greater than around 0.3m ish as it has a fixed focus lens. If it really is blurred either you are too close to the lens, the lens to sensor distance is wrong (mechanical damage) or the lens is dirty.
I hope that helps
Jan 26, 2011 | Microsoft VX800 Webcam
BLUR PICTURES
Memory cards don't cause blurry pics. Is your lens clean? Is the lens extending properly?
Jun 23, 2010 | Panasonic Lumix DMC-FX50 Digital Camera
Canon Eos Rebel SLR (non-digital) takes blurry grainy indoor pictures, even with flash, even when I put a lot of lights on. I use Fujifilm 400. I have used my 300mm telephoto and my regular short lens,...
Sounds like the shutter is making long exsposure and you are actuallly getting blur- this can even happen with flash if the shutter stay open too  long.  without film, look in viewfinder and see what shutter speed the cmaer awants to use- it may be set incorrectly and is set on manual shutter speed- the shutter speed numners are actually the bottm part of a fraction, so 30 is 1/30th of a second- to prevent blur you want the numbers to be 60 or higher.
Aug 23, 2009 | Canon Photography
Blurred pictures
If it's from moisture then once that dries out it will clear up. Otherwise if it doesn't then you will have to send it into repairs and they can clean the internal lens for you.
Jul 31, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Blue screen and lens error
i think its in the flix of your lense,
coz the flixible wire of your lense and motor are one
try to test it!!
there is something wrong in the FW i think!!
Frank!!
Oct 07, 2007 | Olympus Stylus 700 / 700 Digital Camera
Blurred Pictures
1. What is the focal length of lens you are using? 2. Is the blur occurring with lens with a lower focal length than the telelens? 3. Do you still get a blur when you use the telelens with a tripod or a firm base? Regards Raman
Oct 01, 2007 | Fuji FinePix S602 Zoom Digital Camera
Blurry pictures with Pentax K1000
It may be the equipment or it may be the way you are holding / taking the picture.
Here are suggestions on how to take better zoom lens pictures (this also applies to any camera) before you start diving into the equipment.
1) Use the fastest shutter speed possible. This reduces the amount of time of exposure, this limiting the amount of motion blur that can happen.
2) Don't hold the camera by hand. Either use a tri-pod or rest the camera on something stable, like a wall, rock, bench, etc. This makes it less likely that the camera will move when you are taking the picture, thus reducing motion blurr in the image.
3) If you have to hold the camera by hand, hold the zoom lens with your left hand (because it is more towards the center of gravity than the camera is) & try to slow your breathing & take the picture between heart beats.
4) Also, another thing that helps is to use a remote shutter release (such as that rubber bulb or plunger attached to the shutter release). I would also say using the self-timer would help, but the K1000 doesn't have that. This is so the camera doesn't shake from you pushing the shutter release button.
5) Make sure the lens is clean! Even get one of those lens pens from your local camera shop.
If you have tried all (or most of these) then its time to start looking at your equipment, such as . . . is your shutter getting stuck when exposing, thus lengthening the exposure and making for a blurring shot or do you need glasses? <grin -- which is why I find it really difficult to use manual focus equipement now, because my eye sight is really bad!>
Take care & Happy Imaging!
Glen
Sep 06, 2007 | Pentax K100D Super Digital SLR Camera
Blurry/grainy image in viewfinder and resulting pictures
This is not going to get repaired at a sensible price. Check out Kodak Technical support but I think you are looking at replacing the camera
Dec 19, 2006 | Kodak EasyShare V550 Digital Camera
Casio Exilim EX-Z750 Digital Camera Logo
140 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Ron Grant
Level 1 Expert
Are you a Casio Camera Expert? Answer questions, earn points and help others
