Question about Dishwashers
BLINKING LIGHTS ON fURNACE
MY GIBSON FURNACE BLINKS RED 4X AND BLINKS YELLOW 7X? WHAT SHOULD I DO?
Had same problem, first you need to find the location of ignitor double black wires from plug on board and flame sensor.single red wire. 4 red flashes means ground fault, I removed ignitor, cleaned with some scothchbrite, cleaned around screw holes(2) to reestablish ground, I even ran a wire from one of the mounting screws to a ground elsewhere. then I went on to the flame sensor witch will give you flashing yellow light. single red wire to sensor that has one screw holding in. Remove sensor carefully and do the same as the ignitor, clean with scothbrite. I did this a year ago and is still going!
Posted on Jan 26, 2009
I have a trane xl90 furnace that won't fire up. It runs through cycle and then the red light blinks. Ignitor is good but doesn't get red hot at all know.
look on the wiring diagram on the furnace blower door cover. it,ll show u the fault codes according the amount of blinks u are getting. trhat furnace is self diagnotic. ex2 quuick blink plus one slow blink mean code 21. look up 21 and it might say, igniter, so on so forth
Mar 17, 2016 | Heating & Cooling
I have an Olsen furnace. It's not running and there is a red light blinking. What's wrong?
Count the blinks in between pauses. On the door of the furnace will be a legend that tells you what that number of blinks mean. For instance 3 blinks may mean open limit switch or pressure switch failed to close, something like that. Post here what it tells you then we can help.
Mar 23, 2015 | Heating & Cooling
RV FURNACE
It's hard to answer your question without the age and brand of your heater but the blinking of the red light can be a heartbeat, which indicates all systems are ok and there is power or the blinking is like 2 blinks, pause, and 2 blinks, pause repeating. That would indicate a failure code. In that case Google the model and serial number to get the failure code.
Oct 26, 2014 | Heating & Cooling
HK42FZ034 status code light blinks in pattern
Located on the schematic on the inside of the furnace door should be a key for the blink sequence. 2 short blinks then 4 long ones would be a code 24 on that data plate
Apr 13, 2014 | Carrier Furnace Control Board Bryant...
Red light blinks 6 times on winchester furnace
should be a code chart on the inside of door.
Apr 01, 2014 | Winchester Heating & Cooling
Furnace quits with 4 blinking lights on panel
Most likely it's a sensor triggering the unit off. You need to have someone determine which lights are blinking (there is a code to them) and then find out what the code refers to. Could be a simple as dirty filters.
Mar 07, 2014 | Heating & Cooling
Protech 62-24084-02 troubleshooting
62-24084-02 LED CODES
POWER LED - GREEN
ON - Normal
OFF - No power to board
OK LED - GREEN
One Blink - One hour retry delay
Two Blinks - Pressure switch failure (remains open)
Three Blinks - Limit switch fault
Four Blinks - Pressure switch failure (remains closed)
Five Blinks - Twinning fault
FLAME LED - YELLOW
ON - Good flame
Rapid Blink - Flame present with gas valve de-energizing
Slow Blink - Marginal flame
Jan 01, 2014 | Protech Rheem/62-24084-82-1PK - Integrated...
Gibson LP gas furnace red light flashes 2 blinks
You need to lok up the code for that unit, propane requires a 100% safety pilot and also may have induced draft and proving devices as pressure switches, sail switches or centrifigual switches.
I would suspect a safety or proving device.
Oct 31, 2012 | Heating & Cooling
Gibson LP furnace flashes 2 flashes
should be a chart on unit that will tell you what this is then you can test the part to see if that is the problem, but most of the trouble codes are roll out switch or main lemited switch on two blinks.
Oct 31, 2012 | Rinnai RHFE-431FAIII 16,700 BTU Direct...
My gibson furnace is about 8yrs old and it was working fine heat was on yesterday morning but last night it stopped. Changed batteries in thermostat which in new(thermostat) but no heat. Checked the vents...
Look on the back of the bottom cover... it should tell you what the blinking means...
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
Feb 03, 2011 | Gibson Heating & Cooling
Dishwashers Logo
346 people viewed this question
Top Dishwashers Experts
