Question about Matsonic MS9087C Motherboard
Board power I'm getting power from the power supply but yet my motherboard has no light? I have put a meter to my power supply and everything is reading great. How do I kow if the board is just bad?
Do you have any components compatable with the broken motherboard spare or in another desktop? try booting the motherboard with just a power supply, monitor, RAM and CPU. You may also need a video card if your motherboard does not have an integrated one.
If it shows no signs of life with other components that are know to work connected to it, then its a fair bet its dead.
Most hardware fault diagnosis especially with desktops is just a proccess of elimination.
Let me know if you have any luck chashole.
Posted on Jan 22, 2008
Dell 2400 desktop pc will not turn on. Mother board flea led light does turn on.Tested power switch and wiring okay.I did swap power supply pack from a good working 2350 Dell pc same problem any...
Try to remove all components all drives (hard drives, cd/dvd roms, floppy drives, etc), all additional cards (modem, video card, sound card etc), remove the memory. Just leave the motheboard, proc and power supply. Before disconnecting everything completely discharge power by holding down the power button while the computer is unplug from the power. It should clear the flea light on the motherboard.
Test it again with just the motherboard, processor and the power supply. If still no power then most likely it is the motherboard since you already put a known good power supply. Motherboard has higher failure rate than the processor. You can swap a known good processor if there is.
Jul 25, 2011 | Computers & Internet
Hi hope someone can help with my power problem. Motherboard is L7VMM3, so far tried 2 different power supplies, 2 different power leads, 2 different on/off switches, 2 different RAM modules, and 2...
After reading your description and the tests you've done, the problem may be coming from the board itself.
If possible test another board with your power supplies and others...... If other board works just fine, the problem is with your current motherboard.
To be sure about it, you may test the board with another power supply/RAM, etc....
If problem persists, the best option is to replace the board.
May 10, 2011 | Computers & Internet
Asus P5 GC-MX Board proccessor does not get power what parts should be changed
First, check if the connection from the power supply to the motherboard is properly inserted. If it's loose, that may be whats causing you to receive no power from the supply. Check the wall socket to make sure it works, as well as checking if everything is plugged in properly. If you are still getting no power, then it maybe time to buy a new power supply. If there is some indicator of power to the mother board , such as an LED or light that turns on when plugged in, there may be a problem with your power switch.
Mar 29, 2011 | ASUS P4PE-X Motherboard
My unit won't power up - power supply is good and not sure about the on switch any help would be appreciated -- motherboard is in an old HP Pavlion 700 case
Remove the little watch type battery from the mother board check the voltage with a meter should be about 3.5 volts. Then replace the battery on the mother board. This battery holds memory within the Bio chips on the mother board, if there was a problem that it sensed for turn on it will be in the Bio's memory, and maybe not allowing the computer to turn on, by removing the battery for a few minutes, the Bio's forget they had a problem, if you will. and the computer might turn on.
If you have all the voltages to the mother board from the power supply, it should turn on.
unless there is some reset circuit interfearing with it turning on. Or you might have a blown fuse on the mother board, I would check everything I could, and try everything I could, and if you still cannot get it to turn on take it to a computer shop and spend a few bucks for them to fix it.
Nov 11, 2010 | Mach Speed Matrix P4MSD-800 (P4MSD-800 D2)...
I have a foxconn p4m800p7ma motherboard everything is connected but it will only blink the lights twice when i hit the ON switch and the cpu fan spins for a second then stops.is this a dead motherboard?or...
There could be many things that could stop the board from turning on, Determining what is wrong is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drive, make sure you set your pin setting correctly on it. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four with another to see if you get any change. Also, on the drive, try a different cable to make sure it's not that, If no change, then I usually get another board that I can test the first four, and make sure that they work. If after that and you have tested all of the components and they all work, then it's save to say you have a Dead Board
Good Luck and don't forget to leave a rating.
Thanks
Mark
Dec 19, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
I plugged in the power cord and I get no power at all. No lights/nothing? Thanks.
HI
ITS PROBLEM OF COMPUTER SMPS (SWITCH MODE POWER SUPPLY) REPALCE IT ..
TNKS
RABBANEES
Nov 05, 2009 | Dell OptiPlex GX260 PC Desktop
Installed new Mother board and cannot get the power supply to turn on computer. How can I tell if the Power supply is bad or something else is wrong?
First off is the power supply powerful enough for this new mobo? is it new, old?. Is the motherboard securely earthed either in the case or on test bench?
If you have it in a case already strip out everything leaving just the motherboard and graphic card in. Power up now.
If this works put the memory back in.
Then hard drive etc until you have everything you need installed.
If it doesn't work you should try another graphic card if you have access to one. Also make sure the graphic card is seated properly.
If none of the above works then there is a good chance you have a faulty motherboard so best to replace it.
Oct 16, 2009 | Gateway Computers & Internet
D845epi mobo has flashing green light after power supply replacement
Unplug the power then unplug the 24 pin power connection from the mother board and take paper clip bend it so you can insert it into the holes where the green and the black wire are next to each other, Next you will need a multi meter. Set the multi meter to read dc volts 20 take the red lead and put it into the purple wire hole of the 24 pin connection and the black lead in to the hole with the Black wire on the 24 pin connection. the reading on the Multi meter should read 5.0 volts if it does not and you get a reading of 6.01 or higher then the Mother board has been burnt out and you will need to replace the motherboard and power supply I have been a onsite tech for E-machine for the last 5 years and this has been an ongoing problem with the power supply.
Nov 02, 2008 | E-Machines eMachines Desktop PC
NO POWER
if it does not respond at all......i mean no fan no lights no anything.....then double check that your power supply is good.....if it is and you are sure your chasis connectors are placed on the proper pins then you could have a bad motherboard or cpu.......of course more troubleshooting should be attempted before drawing this conclusion (removing one part at a time, etc.) but no power is never a good thing.
Dec 11, 2007 | Gigabyte GA-8I945GZME-RH (0818313003041)...
Matsonic MS9087C Motherboard Logo
Top Matsonic Computers & Internet Experts
David
David
Computer Links
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
