Washer-Kenmore front load belt drive model #417.40042990 (Won't final spin on any cycle.)
O.k. guys here we go again...had to take a break and rest my brain.
So, posted the other day about our Kenmore front load washer that doesn't seem to want to gear up for that final spin speed.
1. Pump and drain lines for blockage. Found nothing blocking and the impellers were fine.
2. Checked drain line to ensure that it wasn't to far into the stand pipe.
3.Checked the shocks for oil/grease or broken mounst or bolts.
After all of these great suggestions...we still have yet to conquer the problem. so any other ideas would be great.
  • 4 more comments
  • Icem Jan 22, 2008
    Hey tech17, Here we go again hu?
    I would happy to tell you which company made this Kenmore if you could tell me how or where to find it. But if this helps it is a stackable waher dryer combo and the controls are at the front.
    When I pulled the water pump out to check for blockage I did take off the rubber boot and clamp.
  • Icem Jan 22, 2008
    Got to the pump from the front. It's right up front in the lower right hand corner if your facing the front.
  • Icem Jan 22, 2008
    No worries...We have a regular knob that turns clockwise to select the cycle and yes we have another seperate knob that allows you to select normal or fast "Final Spin Speed".
  • Icem Jan 22, 2008
    Great suggestion...have been back there already with the same thought when I first eperienced the problem last week. I unhooked both clips and inpsected the bd for burns. (By the way the control bd I found is in the right rear if your looking at the machine from the front. Unless I'm messing with the wrong bd. I think theres only one. So I accesed it from the back.)
    So..while I was waiting...just for the hell of it I ran the washer empty on the normal cycle final spin, and it did run at high speed in the final spin fase but the timer knob would not advance. It stayed in the same position for about 3 full high speed spins. Weird? What do you think...timer knob or still tacho generator. Or is there a chance it could be the spin speed control switch?
  • Icem Jan 22, 2008
    Thanks alot 17. Helped a ton.
  • robert samples May 11, 2010
    two companies make kenmore whirlpool and Frigidaire is this a tall unit with the controls on front are a short unit with the controls on a back panel
    and is it displaying any fault codes when you cleaned the pump did you unscrew a white piece and pull it out or remove a rubber boot and clamp
  • 1,314 Answers
Frigidaire did you get to the pump from the front or back
Posted on Jan 22, 2008
  • 4 more comments
  • robert samples Jan 22, 2008
    ok got it yes i dont know how to quit just hang with me ok does your have a knob or electronic controls and does it have a spin speed switch
    look pull the bottom panel and look to the left hand side of the washer you will see an electronic board there that's your speed control bd check for loose wires or bad connections there just plug and unplug the connectors if that doesn't get it then the other test have to be done under the control panel also look for any damage like burned resistors etc the stuff i told you earlier was the simple common stuff now you have to go deeper if you have a meter we can check the motor and tacho generator with out having to get under the control panel
    the tech manuel mentions the speed switch you seem like a bright guy email me at will give you a gift
    save you a lot of time just say tech 17 washer
    that should do it for you
    het if you need to consult im still here
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
Sep 6, 2013 - Uploaded by
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from
Nov 05, 2015 | Kenmore Washing Machines
This may well be the drum drive belt in the back of the washing machine. This belt transfers drive from the motor to the drum for both wash cycles and spinning. If the belt is slipping slightly on the pulley then a squeal may well be heard on the spin cycle and will change in pitch as the speed of the drum increases. At lower speeds (wash cycles) the belt probably won't slip. I don't personally know of this model but there is usually a tension adjustment nut/bolt near the motor to tighten the belt and stop it slipping.
Dec 26, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Spinning cycle is not spinning.
It could be belt or transmission. I would tip back the washer to check. Some times the belts are under the whole washer. depending on your model, it may be inside the housing. It's only a few screws to take off the front panel. They are pretty self explanitory. Let me know if this helps.
May 04, 2009 | Kenmore 22422 Top Load Washer
Kenmore front loading washer/NOT SPINNING in cyle
replace your door lock switch it will run fine till you git to final spin then stops if i not missing the point the model no. will start with a 417 even door locks the switch is bad
Feb 24, 2008 | Washing Machines
Kenmore model 41743142200
Un plug washer remove belt by lossing the tensioner , bring to appliances center and assemble again /
Jan 07, 2008 | Kenmore 45081 Front Load Washer / Dryer
Washing Machines Logo
470 people viewed this question
Top Washing Machines Experts
