Question about Emerson EWV601 S-VHS VCR
Vcr taping on the programming menu, when I try to set the channel it will not go past 02, L1 or L2. Can you please help?
  • tionne Apr 20, 2008
    well, everytime i turn on the vcr, it starts blinking on the "tape in" part. I really need help because i need to record soon.
  • 579 Answers
You need to run the autotuning feature on the tuner setup page. It doesn't yet know what channels are available to it and is defaulted to the minimum.
Hope Ya Fix it!
Posted on Jan 22, 2008
I was able to connect a dvd player to old tv with a rf is there a way to hook up a vcr on same rf modulator so as not to change connections each time you want to watch the vcr with instead of...
well...the reason its sooo hard is that this modulator is not intended for this use. its used for BIG jobs. you can normally do what you want with a simple rf modulator you buy at walmart or radio shack as it has a cable in and cable out, but
You dont even need a rf modulator.
The VCR can do it for free simply; hook the yellow , white if your vcr has red as well (depending on how old )...BOTH or all Three color to color from VCR(INPUT) to DVD
then use a piece of coax cable from the vcr out to tv.
test vcr by making sure that it work on either channel 3 - or 4 on tv. (leave VCR on)
Then to test your DVD connection first turn DVD player on.;.Then on front of VCR press channel down ON VCR until it says L1 or L2 this is under channel 2 when channel downing.
you should now see the dvd player on screen on either L1 or L2 depending on vcr.
now buy doing this your vcr must be on the L1 (L2) anytime you watch a dvd but when you want to watch a tape you just put it in and press play since TV itself is never changed.
when you want to go back to dvd,...stop tape and should still be right on the L1 or L2 again.
Aug 05, 2011 | Channel Vision E-1200 Video/audio Rf...
I cannot record from tv ? how do you get the channel on that you want to record ? i can dub, play tapes or dvd's, but can't record ?
This model does not have a tuner so you will not be able to record off of tv unless you run your cable box or dish satellite's audio and video outputs through the dvd recorder's front or back inputs(L1 or L2) and record from those sources. Even then the cable box or satellite box would have to be tuned to the channel that you want to record. If you choose to do this you must go to your on screen menu and under setup/general settings/video/video input you will need to select the video input source(L1,rear or L2, front).
Sep 21, 2010 | Magnavox ZV427MG9 DVD Recorder VCR
How do we set to a/v mode?
Most you channel down until below channel 2 and it says L1 or L2.
Apr 18, 2010 | Symphonic SL2860 VHS VCR
I can't manually setup the Channels on my Panasonic PV 9451 VCR
In the Menu go to manual channel set-up not auto. When you're in manual set-up change channels until you get to to L-1 and L-2 (should be below Ch 2) and save both to memory. On some TV's the L-1 and L-2 are selected with a separate button labeled "input".
Aug 15, 2009 | Panasonic Televison & Video
Panasonic PV-9451 VCR, When setting up the VCR to record a channel, the only channel options are Channel 02 thru 25 and L1 And L2. What has to be reset with the digital cable input??
You will need to use L1 or L2 (one is probably on the front of the VCR, and the other on the back, they should be labeled).
YOu need to plug the digital receiver's output into L1, or L2, and set the VCR to record the one you're using. Then set it to the time you want, and then set the channel on the digital box tho the one you want.
One Channel, One time. (or recurring daily, if your VCR allows daily recording from L1,2)
Jun 13, 2009 | Televison & Video
How do I record a TV Program.
Video & Left,Right audio go out of Comcast cable box to L1 input on DVD recorder,Video & Left,Right audio go out of DVD recorder to a line input of your TV.  Record L1 input on DVD recorder.
Jan 10, 2009 | Panasonic DMR-E80H DVD Recorder
Dvd/vcr combo
I'l make sure, but I beleave L1 and L2 are inputs. You need to select the one where the show comes from, Its it coming from the L1 connector or L2.
Your device doesn't have a tuner input jack. To record TV programs on your DVD/VCR, you need to connect this DVD/VCR to an external tuner device (e.g., set top box, cable box or satellite receiver) that has audio/video output jacks.
Il confirm this and reply to you in a moment.
May 18, 2008 | Televison & Video
go to the menu and select auto find or auto program channels.
good luck
please mark the post with a fixya!
Feb 06, 2008 | Emerson EWV401 S-VHS VCR
Recording from cable
L1 and L2 are different inputs on the VCR.If you have red, white and yellow input on the front of the VCR then when you put the VCR on L1 it should pick up a signal from the front.To get more channels on your vcr you want to do an autoprogram make sure the cable from the wall is plugged into the input in the back and go to the menu on the VCR and look for channel search or auto program and start the search.usually you can find this setting under something like SETUP, Programming,settings on the main menu of the VCR.You may have to search in the menu of the vcr for a little bit until you find it.Youll know when you got it when the channels automatically start scanning from 1-98.GOOD LUCK and rate me if this fixesya or is helpful.
Nov 16, 2007 | Lands Phones
Emerson EWV601 S-VHS VCR Logo
79 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
