Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Futura 200ce trouble
I have a new lap top computer with window's vista. It will not download my AutoPunch or HyperPunch into it....when I do it shuts down the embroidering machine all together. Without this on here the machine works fine....but I purchased this and it works on my old desktop computer so I would like it to work on this new one the only difference is, it has window's vista! Is there a patch for it?? Any help would be terriffic!!
Thanks
Emmy's Mamaw
    Problem Solver:
  • 17 Answers
It may be possible to run the Autopunch software in Compatability mode rather than the native Vista.. If you right click on the shortcut to Hyper/Auto punch and choose properties and left click on that. You should then see a tab at the top of that screen marked Compatibility. There should be a check box and a pulldown for Various versions of Windows. Check the box and select Windows XP Service pack 2. You MAY also need to check the box for Run as an Administrator. If this fails , then Im afraid you need to contact Singer to see if there is Vista Driver. If nothing is forthcomming, then downgrading to XP is the final option, (System will run faster too -) ) Cheers. Pete
Posted on Jan 22, 2008
COMPUTER CRASHED I NEED TO RELOAD CD BUT I DONT HAVE ACCESS CODE
There are now several versions of the basic Futura software and AutoPunch available on the market. The most current is version 1.0.0.2. To determine what version of either software you have, you will find this information around the inside rim of the CD at approximately 4 o'clock. Before loading any of the Options into your computer, check the version and then follow the steps below. The following steps will update your software so that you will now have the latest 1.0.0.2 version of the basic program and all options.
To load base software 1.0.0.0 with AutoPunch 1.0.0.0 or base software 1.0.0.1 with Autopunch 1.0.0.1
  • You must use bobbin part number 085128. This bobbin is specifically designed for the Futura CE-100 and CE-200.
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Turn on Futura machine and double left click on Futura icon to open program
  • Close program and turn off the machine
  • Install Autopunch and leave the CD in the tray
  • Download appropriate update for Windows Version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop download icon to install update
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program
To load base software 1.0.0.0 with AutoPunch 1.0.0.1 or base software 1.0.0.1 with Autopunch 1.0.0.0
To load base software 1.0.0.0 or 1.0.0.1 with Autopunch 1.0.0.2
  • Load Base software (have machine set-up for embroidery with USB connected to both machine and computer- machine turned OFF)
  • Close software and turn off machine
  • Install Autopunch using Installation Wizard - leave CD in tray
  • Turn on Futura machine and double left click to open program
  • Type in Access Code from Autopunch jewel case and then left click on check mark to open program
To load base software 1.0.0.2 with Autopunch 1.0.0.0 or 1.0.0.1
  • Close program and turn off machine
  • Place Autopunch CD in tray but CANCEL Installation Wizard
  • Turn on Futura Machine and double left click to open the program
To load base software 1.0.0.1 with Autopunch 1.0.0.1 with Hyperfont 1.0.0.2 or Photo Stitch 1.0.0.2
  • Load Base software (have the machine set-up for embroidery with USB connected to both machine and computer - machine turned OFF)
  • Close program and then turn off the machine
  • Install the Autopunch program and leave the CD in the tray
  • Type in the Access code from Autopunch jewel case and then left click on the check mark to open program*
  • Download appropriate update for Windows version from the Futura-Support.com updates and save to desktop
  • Double left click on the desktop icon to install update
  • Install HyperFont program - leave CD in tray
  • Type in Access Code from HyperFont jewel case and then left click on check mark to open program*
  • Install PhotoStitch program - leave CD in tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark to open program*
* Must open the program after installing each Option with CD in tray and type in Access Code before installing next Option.
To load base software 1.0.0.2 and adding all Options - Hyperfont 1.0.0.2, PhotoStitch 1.0.0.2, Autopunch 1.0.0.2 and Cross Stitch 1.0.0.1
  • Install Base software (have machine set-up for embroidery with USB connected to both the machine and computer- machine turned OFF)
  • Close program and then turn off machine
  • Install Autopunch program and leave the CD in the tray
  • Type in Access Code from AutoPunch jewel case and then left click on check mark*
  • Install Hyperfont program and leave the CD in the tray
  • Type in Access Code from HyperFont jewel case and then click on check mark*
  • Close Program and turn off machine
  • Install Photo Stitch program and leave the CD in the tray
  • Type in Access Code from PhotoStitch jewel case and then left click on check mark*
  • Close program and turn off machine.
  • Install Auto Cross Stitch program and leave CD in tray
  • Download appropriate update for Windows version from the Futura-Support.com updates (Fut_sp2_Options.exe) and save to desktop
  • Type in Access Code from Auto Cross Stitch jewel case and then left click on check mark*
Dec 11, 2010 | Singer CE-200 Quantum Futura Computerized...
Futura ce 100. Changed computers and can't get past the ''cops''
If you have upgraded to Vista, there have been considerable troubles with all makes of machine in the last few years.
You will probably need to find an upgrade to the software (generally free), so contact Singer in your region.
Here is their Global Site Link if you need to find a contact locally to discuss your needs.
Sep 07, 2009 | Singer CE-100 Futura Computerized Sewing...
Install autopunch
Go to www.futura-support.com , click on Service Updates in the left hand column, and then click on: Click here to read detailed installation instructions. Print it out and follow the procedures. You also need to download the patch at the top of the screen.
Good Luck!
Nov 12, 2008 | Singer CE-200 Quantum Futura Computerized...
I just purchased a new lap top and how do i run my singer embordery programs
The singer website has a patch and instructions to use the software with Vista. It works great.
Feb 14, 2008 | Singer CE-200 Quantum Futura Computerized...
Vista unable to install Futura software
I found a solution that seemed to work for my setup (Vista-Futura 200): Go to the Futura support site www.futura-support.com . Choose "Service Updates" from the left-hand Menu. Choose "Quantum® FUTURA™ (CE-200) Owners running Windows XP Service Pack 2 operating system WITH one or more of the Options (AutoPunch, CrossStitch, PhotoStitch, and HyperFont) installed". Look for the bullet-point list in the explanations. It says there: "If you own the AutoPunch Option and you could not successfully install it, download the Service Update by clicking here." Select the highlighted link, download the patch and install it. Worked fine for me, I hope it helps you, too.
Nov 03, 2007 | Singer CE-200 Quantum Futura Computerized...
Futura CE 200 Software Installation Media
Yes, from here: Driver Update Software for XP Vista 7 8 Install this software and make the update. Wish you best of luck.
Peter
Nov 02, 2007 | Singer CE-200 Quantum Futura Computerized...
Autopunch Installation - Vista
Check the Futura website.  There are specific instructions for how to setup the software to run in WIN XP mode and then after that is set, you have to install the WIN XP patch for Autopunch before it run.
Sep 26, 2007 | Singer CE-200 Quantum Futura Computerized...
Autopunch installation problems
Hi quackquack I was having the same problem with windows vista. If you go back on the futura website there is a patch to download which will install autopunch. Linda
Aug 27, 2007 | Singer CE-200 Quantum Futura Computerized...
Help!!!!!!
IF YOU ARE RUNNING WINDOWS VISTA YOU HAVE TO DOWNLOAD FROM FUTURA SITE. HAD TO TAKE MY MACHINE AND COMPUTER TO COMPUTER SHOP TO GET SOFTWARE DOWNLOADED BECAUSE SOFTWARE IS FOR WINDOWS 98,2000 AND XP
Aug 25, 2007 | Singer CE-200 Quantum Futura Computerized...
Autopunch....
http://www.futura-support.com/ Go to this site and download a patch that allowea autopunch to work this is the singer site
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
77 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
