Question about Oasis Industrial Strength Dehumidifier
Won't shut off
Very old Oasis D2000 stays running . on rare occasion it shuts off, it does so with CLUNK sound
An old D/H like that might be low on refrigerant so it takes much longer for the humidistat to be satisfied so it shuts off. The loud clunking sound when it shuts off might also indicate low charge. A refrigeration serviceman can add refrigerant but if it's an old model, the refrigerant used at the time might be really expensive and therefore might be cost effective to buy another one. Can't buy the old Oasis models made in Ohio anymore however. Offshore has won out with low price.
Posted on Jan 29, 2008
  • 63 Answers
Sounds to me like the hemostat is sticking or our of calibration, unfortunately it would have to be replaced to fix this problem
Posted on Jan 25, 2008
I have a Frigidaire dehumidifer model FDL70S1 that wont stay running for more than 3 minutes and then it shuts the fan off, but still has power to the unit.
Hi lynn crisp, thanks for your post!
From my understanding you are having a challenging time with your Frigidaire dehumidifier shutting too quickly. It sounds like a possible problem with your sensor or control panel. Are you currently under warranty? I would contact your manufacturer for assistance to a proper resolution. -Matt
Oct 20, 2014 | Frigidaire Dehumidifiers
Why is my dehumidifier very noisy?
I would guess that some rubber anti-vibration mounts have aged. If so this may allow the cooling fan to move and grate on the fan housing. It is unusual for the hermetic compressor to give trouble but having just said that, on rare occasions the big-end bearing can fail. This would cause a very obvious knocking noise coming from the compressor. Its just a case of carefully opening up the dehumidifier housing and looking to see what is happening. As an aide-memoire one can tape all the screws to a piece of cardboard adding notes as to where they came from. Take care and good luck!
Aug 21, 2014 | Kenmore 54501 Dehumidifier
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
When turn off. makes a humming sound. compressor seems to be running.
Have same issue with 3 year old Frigidaire dehumidifier purchased in 2012. Must unplug to stop compressor running with power switch turned off. Unit gets hot and smells. Unplugging creates arcs at outlet since unit is pulling a lot of power. Plugging back in after some hours will make it appear to run normally and again remove moisture but it will not shut off when the fan goes off (humidistat bad?) and the set-point is reached. Cannot leave plugged in due to safetty/fire/overheating concern. Have not found answer on this forum or any other so far.
Sep 15, 2013 | Frigidaire FAD704TDP Dehumidifier
I have two of these dehumidifiers. They won't go on automatically. I don't understand the settings. One of them won't stay on at all. It runs and then shuts off.
As per your problem, that the dehumidifier shuts offautomatically - If yourdehumidifier froze, the compressor will shut off automatically. Allow the iceto melt before emptying the tank and restart the dehumidifier. Hope this will help you. Good Luck.
Jul 08, 2011 | Haier 65-Pint Dehumidifier
My dehumidfier won't shut off. I check everything out and it's good but it just won't shut off it keep running.
It may be, that you have it running in continuous mode, rather than timed mode. Also, most dehumidifiers fans will run almost continually, to keep the air moving, so the humidity sensor can pickup and increase in humidity, if there is one.
If the above doesn't seem to be the problem with your unit, turn The Master ON/OFF Switch to OFF and unplug the unit for 12-15 minutes. This will give the electronics time to reset themselves, if necessary.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 23, 2011 | Fedders A7DH45B2A Dehumidifier
I have a FDL70S1 Dehumidifier. Unit runs for just a couple minutes and shuts off-blinking bucket full even though no water in bucket. Unit won't stay on
Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end.
May 17, 2011 | Frigidaire FDL50R1 Dehumidifier
Crosley dehumidifier does not collect water.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 13, 2010 | Crosley 40-pint Dehumidifier
Oasis Industrial Strength Dehumidifier Logo
314 people viewed this question
Top Oasis Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you an Oasis Dehumidifier Expert? Answer questions, earn points and help others
