The lockout keeps activating, sometimes 4 or 5 times a day. servicing is up to date, what can i do The appliance is a Stanley super star oil range cooker which also acts as a central heating boiler, I am at my wits end, please help and advise
regards DAVID JONES
My stanley oil fired range fires up then cuts out
i have the same problem. turns out the pump is not kicking in in time so the boiler keeps knocking on and off. it should not until all the rads in the house are heated up to the temp set on the dial. think it may be a simple wiring problem as the pump needs to be on as soon as the boiler fires up and not turn off until water is up to temp.
I have a problem with mine too... had a new pump, and a new motor, and now it keeps cutting out. When it is stone cold it will get reasonably warm, then cut out, if I ush the reset button after that, it'll fire u for a few seconds and then go out again. I don't trust the engineer I have who jsut kees getting new parts and charging me a fotrune.... can anybody advise please, he now tells me I need a new white box which he reckons is the 'brains' of it...
Hi, I have had the same problem with our range, what I done was change the nozzle and give all the fuel line and parts a good cleaning starting outside at the tank's filter through to the holder for the burner nozzle. The burner on my machine is a Ecoflam and I got some info here http://support.reznor.co.uk/attachments/Ecoflam%20Burner%20Instructions%20(LB193%2007.10.02)-GUID2d8401238de54242be4e8be4e5644ee6.pdf.Hope this helps.
how to replace leaking boiler in stanley 100000 btu oil fired range
