Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Sony KDF55WF655 tv will not turn on, red light blinking on lamp
I have a sony wega Energy SRS Tru Surround and when you turn it on the stand by light blinks 10 times and when turned off blinks 5 times no pitcher or sound
Posted on Jul 08, 2011
    Problem Solver:
  • 15 Answers
TURN TIMER OFF OR, The STANDBY light is flashing on the television and there is no picture or sound. Solution
sony KDF55WF655 - sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Posted on Jan 16, 2009
  • Sony Master
  • 8,617 Answers
Your lamp has burned out. You will need to replace the lamp.
If your not sure how to go about this you can get the service manual for your set for 10.99 at the following link. They will email it to you if you return to the site and request they email it instead of mail it. Hope this helps. Here is the link
Posted on Jan 22, 2008
I have a Sony kdf55wf655, just replaced the lamp, acts like it wants to turn on then clicks. and still on standby mode. It will blink 3 times pause then blink 3 more time. Did I get a bad lamp? or what...
Ur hear alots clicking,but no picture come on?Yes,than the tv Ballast board is also dead.This tv Ballast board,job is to help to ignite the tv projection lamp.Tries websites like, to buy a new tv Ballast board for the replacement.
Nov 18, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony grand wega KDF55WF655 6 red blinks
you can try these steps if this doesn't work I suggest replacing IC8002 on the power supply
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks
Jan 24, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Lamp light started blinking. No picture Model
If you're getting your lamp from a online store, most of those sites give you some kind of ditailed procedure on how to replace the lamp when you buy it from them, the price varies according to the what ever you are going to replace, either just the lamp or the complete lamp cage.thanks!
Jan 09, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
I replaced the bulb in my tv sony kdf55wf655 its not works i have 6 red flashing 5 green lighte
If you have replaced Lamp and you still have no picture or Lamp is not Lighting then its the Ballast Board Call Encompass Parts 1-800-638-3328 Make sure your Fans are running this too will cause set not to come on.
Nov 30, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Sony KDF55WF655 TV ready green light blinks 30 times
Could be a bad lamp again. If this TV uses the XL2200 lamp, they are known for this intermittent behavior. If its not the lamp, a tech can access the self-diagnosis screen to see what's causing this failure.
Feb 18, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony grand wega model kdf60wf655 cycles on and off.
My kdf55wf655 did this for about a week until I put in a new Lamp. Working fine since then. Got it through Amazon from
Dec 15, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
tv turned off black screen and red light flashes 6 times over and over again
Feb 28, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Green standby/power light bilnks and pic goes out
you have defective power supply! at the hot side section!
Oct 08, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
211 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
