Question about Samsung DVD-R155
"Recorded" or "Blank"? this is the Problem!
Hi All
I bought a R155 DVD Recorder & a blank DVD-R (4.7G - 120min - 8X) yesterday.
I Recorded some minutes of my TV shows on that blank DVD and it played successfully in my R155. so i have a DVD-R with some recorded scenes on it now. i saw this scenes by R155 successfully...
but when i put this DVD-R in my laptop DVD Player, it detects as a Blank DVD!!!
what is the problem?
thanks for any HELP...
  • swtwtroses Mar 25, 2008
    m not getting a promt to finalize. at the end of recording it just says updating info.
Probably you have not finalised it after recording is completed. I had the same problem but after finalising,, I am able to play it in any dvd player.
Posted on Mar 20, 2008
    Sergeant:
  • 280 Answers
Check to see what format you are able to play on you Laptop
Sometimes they only work on some formats. Also make sure you are not recording in progressive scan
Posted on Feb 22, 2008
Unable to play recorded dvds (standard 120min) on my dvd player. format issues?
toshiba is very rough and demanding with dvds ....it must be Maxell (I find dynex /memorex and panasonic works too) the speed must be 16x/8x (not 4x) and this is the killer dvd (+) or dvd( -)...i had to take many gifts back to mall and exchange...so read your manual carefully and get what baby toshiba ask for...some times we cant get that sale our players will send us back to out for the correct....hope this helps you too
Jul 05, 2010 | Toshiba DR4 DVD Recorder
LG DVD recorder will not recognise any blank dvd's
The lasers do burn out, if nothing is reading, then perhaps the laser did burn out
Nov 02, 2009 | Electronics - Others
When I put a DVD-R into the DVD-R 155 recorder to copy a TV program after a few minutes of the blue disc at spinning at the top right of my TV screen the disc is ejected with the message 'disc cannot be...
This is a Samsung DVD recorder - I've had the exact same problem - By the way, don't you mean "this disc cannot be recorded" ? These DVD recorders are known to reject certain type of discs.
* Have you updated your Samsung with the latest firmware ?
http://www.samsung.com/ca/support/download/supportDown.do?group=&type=dvdplayers&subtype=recordable&model_nm=DVD-R155&disp_nm=DVD-R155&language=&cate_type=all&dType=D&mType=FM&vType=&prd_ia_cd=03010300&model_cd=&menu=download
Follow the instructions carefuly and please understand the risks involved in flashing your drive - Do not interrupt the process, it can take long.
* here are the brands of DVD-R I have used successfuly with this recorder int he past:
Taiyo Yuiden DVD-R 4x / 8x (the optical drives used in those recorders are outdated, their writing strategies are never up to date and may not recognize some type of discs)
Maxell DVD-R 4x / 8x
Verbatim DVD-R 4x / 8x
Try another blank disc - maybe it will accept it - if it keeps rejecting all your blank DVD-R no matter what brand, you have a bad drive inside your recorder - the samsung recorders are **** - I have ever since gotten rid of that piece of **** and now use a Sony HDR-780 HDD/DVD recorder, uses pioneer components and is great !
Avoid those lens cleaners - they can do more harm than good!
I hope this helps.
Try different brands of DVD-R, avoid the cheap generic **** - drives like best Taiyo Yuden & Verbatim media id codes - they should recognize Maxells, verbatims, sony, taiyo yuden, ritek. if it keeps spitting out all discs you use, you have a defective unit. The latest firmware on that drive should also help !
Good luck :)
Aug 22, 2009 | Samsung DVD-R155
Can't watch show while recording
It doesn't do. No can do.Whatever channel you SWITCH ON TO AFTER you started recording be it timer or manual GETS recorded. Whether you switch onto inputs on your TV remote or cable remote IS the one getting recorded.
Jun 15, 2017 | Sony Televison & Video
Samsung DVD Recorder R155
Sounds like you recorded from a camcorder attached to AV2 (front of DVD player). Press the STOP button, then open the menu and finalize the disk.
Mar 04, 2008 | Samsung Televison & Video
Bush recorder no longer finds blank dvd
Owing to the fact that it works with the original discs, the set is probably ok. BUT it's not very compatible with the blank discs you've purchased. You'll have to experiment with various brands until you find those that work. I find my Cyberhome deck is not only particular with some brands, but with different batches of the same brand disc. Ask some of the big box stores that sell blanks and you'll find they get a lot of returns for the same reason, they don't work in the customer's machine. Bush doesn't sound very competent in the customer support dept, so I would look to replace your Bush recorder with something more main line, and probably more expensive and compatible.
Oh, and make sure you are getting the same type of disc- DVD-R and DVD+R are not the same.
Feb 17, 2008 | Televison & Video
Samsung R155 Recording from VHS Issues
The reason why you are having this problem is because you haven't finalized the disc. In able for you to play that Burned DVD that you have you need to Finalized the disc. Finalizing a recordable optical disc means writing the disc's lead-in (the Table of Contents or TOC) and lead-out information (blank data that fills up the unused space at the end of the disc) so that a DVD player will know where the various tracks begin and end. Without the TOC, a conventional DVD player will not be able to read the contents of the disc. Once the disc is finalized, no more information can be written to it. Finalizing takes about two or three minutes. To finalize a DVD-RW/DVD-R: 1. Press the Menu button with the disc stopped. 2. Select Disc Manager and press Enter or the right arrow. 3. Select Disc Finalize and press Enter or the right arrow. You will be asked twice if you are sure that you want to finalize the disc. Select Yes and press Enter. Once the disc is finalized, you cannot delete entries from the record list. After being finalized, the DVD-R/DVD-RW (video mode) operates in the same manner as a DVD-Video. Recorded discs must be finalized in order to play back in non-Samsung DVD players. A DVD-RW disc that has been recorded by DAO (disk-at-once mode) in a PC cannot be unfinalized. A DVD-RW disc that has been recorded in Video Mode on a non-Samsung recorder cannot be unfinalized by a Samsung recorder. A DVD-R disc cannot be unfinalized. Note: Finalization does not apply to DVD-RAM. If you cannot finalize a DVD-R or DVD-RW disc, make sure that Disc Protection is turned off. If you are still having difficulty, you may try calling technical support of SAMSUNG. Note: Do not turn the recorder off while it is finalizing the disc. Data on the disc will be damaged if the finalization process is interrupted.
Sep 17, 2007 | Samsung DVD-R155
Downloading from hdd to dvd+r ?
When you recorded your "footage" was the dvd recorder set to 2hr (sp), 2.5hr (spp), or 3hr (LP), etc.?Because for example, you downloaded (recorded to your hdd)your "footage" that is say 3hrs long, and your recorder is set to record at 2hrs mode(sp), then when you put a blank dvd in recorder to transfer from hdd to blank dvd, the 3hrs of your "footage" has been recorded in 2hr mode on your hdd, and will only record in 2hr mode onto your blank dvd. Solution is to set your recorder to the record mode in which your "footage" length is. For example, if your "footage" length is 3hrs, set your recorder mode to LP then when you insert your blank dvd should be okay. Or, set your recorder mode to 2hr (sp) and make two recordings of your "footage" onto hdd, splitting them up: 2hr on one, and 1hr on the other.When you burn to blank dvd you will have to have 2 blank dvds, one for 2hrs, the other for 1hr. I had to same thing happen to me. I hope this works for ya.
Jul 28, 2007 | Philips DVDR3455H/37B
Recording on DVD-R with Samsung DVD-R155
Heating issue. If you remove the cover and touch the processor chip - you will not be able to keep your finger there for more than a second (that is if your really want to use this crude method to test the temp).
I have taken measurement and its around 50C. Thats a lot for no heatsink or cooling fan.
If you have the unit in a cabinet with no air flow - you will not be able to use this unit for more than 3 months and up to a year. Best to have it on top of a cabinet or in one with an open front and back to allow some airflow - or just anywhere where its in the open.
Samsung has another unit - the AR650, which I believe is discontinued - which for some strange reason has realized this concern. My guess its a whole different team of designers (or at least some folks with some brains) and added a cooling fan into the unit. Its the same exact case and motherboard as the 135, and 155. There are absolutely no issues with it rejecting disc's - even after a year of use for some users.
In Summary:
Solution 1 - Place it in the open
Solution 2 - Remove case and drill holes to the topside
Solution 3 - Remove case and add a fan
Solution 4 - Remove case and add a heatsink over proc (will still need to drill holes over heatsink..
Solution 5 - We can all complain to Samsung and have them recall the units
Jul 10, 2007 | Samsung DVD-R155
Samsung DVD-R155 Logo
154 people viewed this question
Jerry Greenberg
Jerry Greenberg
