Question about E-Machines eMachines Desktop PC
E-Machine T2984 the power light is flashing.
When I shut down my machine and turn it back on later it has a flashing power button. I turned off the hibernate option, no difference. Possible power supply problem? Sometimes on reboot, the system will not turn on at all, I have to reboot again to get it to work.
    Genius:
  • 1,226 Answers
There something problem in your PSU, you need to check the power supply of your system, if hard for you then you can let repairman do it, or replace that with a new one.
Posted on Jan 21, 2008
My Toshiba c-55 wont turn on the white button light flashes 4 or 5 times and then stops but it never turns on.
I heard of many power issues with these models. Mostly concearning the battery, it sounds like this may well be the case from the 'light flashing' issue.
The other problem involving slow start up/ being laggy could be down to the machine running hot and Windows is using passive cooling in the power options, or a failing hard drive can also cause software problems.
Dec 25, 2014 | Toshiba Satellite Computers & Internet
My Pfaff model 1211 machine won't come on. The power switch has been replaced but no light and no power for stitching
Sounds like a bad connection somewhere as the power seems intermittent. Consult your repair man to check the electrics.
Apr 06, 2017 | PfaFF Sewing Machines
The error message "door" is displayed and the machine won't start. I can I reset it.
I have Blomberg WM87120 NBL00 Product code 717518110 and had flashing Lock in display. Bought and installed new lock and no change. Display still flashing lock. Used following procedure and every is working now.
Press pause button and hold down while turning off machine.Continue to hold pause button and turn power back on. If numbers come up on display make note of them for future reference. Release pause button and all lights on display will light up. Turn power off again and then turn back on. If machine was in a cycle it should end it and then return to normal operation. .Dont know if new lock made a difference. Try the reset procedure first.
Dec 08, 2012 | Blomberg Washing Machines
How can i reboot my computer.
If you are using Windows operating system then click on the lower left "Start" button, click on "Shut Down", and then let the machine shut itself off. Hit the power on button on your pc and turn it back on. That is the reboot. IF for some reason the Start button is not allowing you to turn off the machine, you are in other words "hung", then Hold Down the power button of your pc until the machine turns off. You should power back on your machine and choose to boot as normal.
Sep 13, 2010 | Computers & Internet
Power light and extra rinse rapidly flashing
Sounds like a cold water supply fault which could be the solinoid valve, the water turned off, a kinked or twisted cold supply pipe or a wiring fault. Check out the error code sequence here. You never said what make or model you have (the error codes are only for Hotpoint, Creda and Indesit machines)
Mar 20, 2010 | Washing Machines
After descaling le Cube two flashing buttons won't stop so can't
I had the same issue. This is what a did:
Turn off the machine
Remove the tray/container and leave it outside
Turn on the machine and this time the power button should be flashing (preheating) then hold both cup buttons for 3 sec and it will be back to normal opertion....
For some reason the sensor needs to read that the tray/container is out of the machine...
May 16, 2009 | Nespresso D290 Espresso Machine
Will not turn on.
Did you try bypassing the switch?
To do so:
  1. Remove the case
  2. Follow the wire from the power switch to the motherboard
  3. Remove the wire from the 2 pins
  4. Use a screw driver and touch both pins at the same time, creating a connection
That would be the equivalent of switching the computer on, if it powers on then you know the switch is bad and just need to replace it. If it does not turn on I would be 99% sure it is the motherboard as you already swapped the power supply.
Feb 24, 2009 | E-Machines T2984 PC Desktop
Washer powers down during wash cycles
It is most likely a very slow fill problem ,either the cold or hot water supply is restricted and the machine cannot sense the right water temp. and will shut down .
Machine cannot wash properly with a small amount of water.
Ckeck ,the screens in the water valve or at the hoses at the top where the faucets are ,clean them or replace them but never leave them out .
Dec 17, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Whirlpool ADG 957. Light for rinse programme on but start light flashing intermittently. Cannot change programme, cannot start machine.
Mine was doing exactly the same. I turned off power, held down the 2 black buttons on right, switched back on and the start button flashes intermittently. It then allowed me to change programs, just testing it now!! It started, this was more then it was doing!! lol
Aug 17, 2008 | Dishwashers
Want shut down
Click Start, then turn off computer, and make sure that your computer is not set to standby or hibernate. This works if you are running Windows XP or Windows 2000. Hope this helps!
Sep 11, 2007 | E-Machines eMachines Refurbished EMA...
E-Machines eMachines Desktop PC Logo
722 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
