Question about Haier HTQ18JABRSS Top Freezer Refrigerator
Leaking water INTO fridge
My Haier fridge/freezer is leeking water INTO the fridge. Every day or two we will find a puddle of water on the top shelf in the fridge. Any advice?
  • Jay49 Jan 24, 2008
    Thanks a tonne, Bob! With a little thawing and a little bleach, the drain hole is flowing smoothly again.
  • Anonymous Mar 13, 2014
    I was taking something out of the freezer & the motor sound stopped. Can you tell me if that's usual for this brand. Thanks
  • 833 Answers
Your problem is a blocked drain which prevents melt water from the defrost from getting out. You'll have to expose the coils and find the drain hole. It is possible that the problem can be on the other end of the hose...where it hits the evaporation pan in the bottom of the unit.
Posted on Jan 22, 2008
Water seems to tsand in refrigater
Posted on Apr 03, 2008
Puddles of water collect on the top shelf on a daily basis
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 14, 2011 | Estate TT16TKXKQ Top Freezer Refrigerator
Water is leaking onto top shelf of fridge. It is a top freezer.
Sounds like you have a frozen drain in the freezer. You can remove the back panel of the freezer and take a turkey baster and run hot water down the drain line to clear it. Once its cleared you will want to dump an additional cup of water down to make sure that its clear. This will stop the defrost tray from overflowing when the unit goes into defrost. This is where the water is coming from.
Hope this helps _MJ_
Feb 16, 2010 | KitchenAid KSRA25ILSS Side by Side...
Whirlpool, water puddles on top shelf of fridge
If it is not from a plugged or misaligned defrost drain tube, then it is always from air leaking into your refer section. Check you door gasket to see if it is sealing correctly all around your door. Make sure your door is shutting tightly every time. Good Luck, Appliance Specialists.
Jan 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Water inside refrigerator
Even though it doesn't seem like it's coming from your freezer, morre than likely that's where it's coming from. At the back of the fridge there will be a drip tray that actually catches the water from the thawing freeze. One way to avoid access water is to simply turn down your freezer and fridge. Usually if they are number 0-10, both frigde and freezer should be set on the 5 level.
Aug 31, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Smelly Ice and water leaking into top shelf
Does water in door dispenser taste bad? If not, Try arm and hammer fridge deoderizer. It will help to absorb fridge odors which may be clinging to water molecules in ice maker tray. Ice maker tray is open to freezer area.Water is very medium to infiltrate with odors. Try this first
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Freezer Noise. Water leaking in Fridge.
you need a repair man.you have a defrost problem and your drain is clogged.
Mar 09, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Top Freezer Whirlpool
THERE IS A PROBLEM WITH THE DRAINAGE. iTS BLOCKED. YOU NEED TO DEFROST THE FRIDGE PROPERLY FOR A DAY TO REMOVE THE ICE THEN APPLY PRESSURE (BLOW) IN THE PIPE SITUATED ON TOP OF THE COMPRESSOR.THIS WILL CLEAR THE BLOCKAGE. RESTART YOUR FRIDGE.
Aug 14, 2007 | Whirlpool ET8WTMXK Top Freezer...
Haier HTQ18JABRSS Top Freezer Refrigerator Logo
436 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
