Question about Miele Novotronic Premier 500 Front Load Washer
Miele novo w526
Inlet light comes on after 1 min. machine cannot start but sounds like it is trying. have cleaned and checked hoses and filters twice . too top of machine checked wires . everything looks good. what is problem please?
  • 16 Answers
Can you hear the drain pump running??....If so the WPS system has been activated and there is water in the base.
If not, please post back if any water is going into the main wash compartment once it's started. No water, then faulty inlet valve.
Posted on Feb 08, 2008
My LG dishwashing machine model LD 2131 SH displays a F error. What does it indicate?
LG DISHWASHER ERROR CODES AND DESCRIPTION MODELS LD 1420W2 D1420WF LD...
ERROR CODES; FAULTS & REMEDY ERROR DISPLAY [IE]
Inlet error.
Condition: Not reached to the normal water level in spite of 10 min. water supply.
Possible causes:
  1. The Water Tap is not opened.
  2. The Inlet Hose is twisted.
  3. The Filter of inlet valve clogged by impure water.
  4. The Inlet Water Valve is normal ?
  5. The water pressure is very low. ( below 0.5 kgf/ )
  6. Inlet valve is blocked by safety device for leakage sensing.(In case of Inlet Valve).
Remedy
    • Open the Water Tap.
    • Repair the Inlet Hose.
1.Close the Water Tap.
2.Unscrew the Inlet Hose (Inlet Valve side)
3.Clean the Filter of Inlet Valve.
> Replace or repair the Inlet Valve.
> Check the water remain on the base.
1.Check the point of damages and repair or replace the related parts.
2.Disconnect the inlet hose to dishwasher to unlock the safety valve.
ERROR DISPLAY [OE]
Drain error.
Condition: Not fully drained out in spite of 5 min. drain operation.
Possible causes:
  1. The Filter clogged.
  2. The Drain Hose twistec or blocked.
  3. The Drain Pump/Motor or circuit is troubled.
Remedy
    • Clean the Filter.
    • Remove the cause of twist or block.
    • Replace the Drain Pump/Motor or repair the Circuit.
ERROR DISPLAY [E I ]
Leakage error.
Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
ERROR DISPLAY [ F E ]
Excess error.
Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.).
Possible causes:
  1. The Inlet Valve is troubled.
  2. The Air Break is troubled.
  3. The Sensor Assembly is troubled.
  4. The Controller is troubled.
Remedy
    • Replace the Inlet Valve.
    • Replace the air breaker.
    • Replace the sensor assembly.
    • Repair or replace the controller.
Jul 09, 2017 | Washing Machines
Washing machine drain problem
Here's a few instruction's How to Diagnose Washing Machine Problems
Step 1:
If the washer won't start, check the power cord or reset the circuit breaker depending on the issue. It may be overheated and shut off temporarily. Let it cool for 30 minutes, and if it still won't start, call a professional.
Step 2:
If the motor transmission failed or the drive belt has broken, these need the assistance of a professional.
Step 3:
If the washer won't drain, clean out the drain hose and straighten any kinks. If the drain hose fits too tightly in the standpipe, adjust it to allow for a minimum of 1.25 inches for airflow so water can drain.
Step 4:
If the washer won't fill or fills slowly, turn the faucet handles counterclockwise as far as possible. This is usually the result of partially open faucets.
Step 5:
Call a profession if the washer overfills. This means the water-inlet valve or switch is defective.
Kindly regards,
-micromaster
micro & yakman unltd.
Mar 09, 2008 | Washing Machines
I bought an older 842 washing machine. It has been sitting for awhile so I cleaned out the filter. At first I did not get the plug back in and water ran out and the inlet fault light came on.
Sounds like either the small filter at the inlet solenoid valve or the solenoid valve itself. Either way you are going to have to get inside the machine to get to the inlet valve.If no water is coming through the soap draw then it can really only be at the valve OR the inlet to the soapdraw is blocked (again - need to take off the top to look) Make sure power is disconnected before you do. The flashing red light after 30 seconds or so is just letting you know that the drum has not reached certain water level in the appropriate amount of time.
Good luck
Aug 28, 2015 | Miele Washing Machines
Bosch f17 falt
Your machine is taking to long to fill
Check your water supply is turned full on
also check the filter in the water inlet hose
check to see if your hose is kinked
if all above is ok then it could be a faulty inlet valve
Mar 07, 2015 | Bosch Washing Machines
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
Mar 24, 2013 | AEG Dishwashers
Have just tried to install a secondhand dishwasher which goes for about 5 mins and then shows UE. Could you please tell me how to fix this? Thank you Nancy
UE- means an unbalanced load in a washing machine.
le- means make sure water supply inlet hose is on. check inlet hose for any kinks or bends in the line
that could prevent the machine from filling properly, check and make sure the water supply is on
completely and not partially. check inlet filter for buildup of mineral deposits. clean filter with small
brush. make sure that machine can drain properly. good luck!
Apr 09, 2011 | LG Dishwashers
My machine will start all programmes but only run for less than 10 seconds and then do nothing else at all. I have cleaned the filter and checked all connections at the back.
If you open the Soap box when you turn it on, does water come out in it? If not, check the following:
1) Is the tap open
2) Remove the inlet hose, and clean the filter between it and the connection.
3) If still not working, open the Top Panel, and you'll see that the inlet hose pipe goes to a solenoid connected to the outer soap box. Remove this solenoid, and connect live power (usually 110V or 220v, depending which country you live in). You should hear a clicking sound. If not, replace the Solenoid Inlet valve (Cheap)
The reason why I am saying to check these things in particular is because the first process your Washing Machine will go through when starting, is to let water in. If it doesn't it will stop and hang.
If water does come out in the soap box, then let me know and we will ponder away more :-)
Kind Regards
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Apr 06, 2011 | Washing Machines
You can turn the washing machine on and it starts shooting out water for just a couple of mins and then it quits. The machine will not do anything.
does it spin? if no check you lid switch
if it fills for 5 seconds or so and never reaches full and just humming sound heard. check you inlet valve
i would turn each hose off and take them off the back of the washer. get a bucket and put hose in it and turn one on at a time.
do you have good flow comeing out of your house if yes check the screens in the inlet valve. are they clogged with sand? if yes clean them. try these things and let me know how it goes
Aug 24, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Water can't fill up
Check and clean out filter inside the connector to the washer
If that is clean
Switch the water off and then start the machine cycle , you should hear a buzzing sound from the area where the inlet hose connects to the washer
If there is no buzzing and the inlet filter is clean you need a new fill valve
Apr 01, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Hotpoint WF250 - clothes largely dry and covered in powder
check to make sure the water inlet filter is not clogged with debris.
turn off water and disconnect at washer , look in opening is filter screen clear, some are removable to clean others you have to brush etc....
there are two more places to check but they are inside the washer at the water control solenoid and the inlet , the water pressure sensor may have something to do with this issue.
best to open the top and listen and watch. (3 screws in rear top)
Apr 06, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Miele Novotronic Premier 500 Front Load Washer Logo
649 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
