Question about Toshiba e-STUDIO 16 Printer
Network printing issues - Toshiba e-studio 16s
Having problems printing to Toshiba e-studio 16s copier. I have setup an IP address on the printer and able to ping the ip address from all my workstations running XP.
Setup the printer and pointed to the ip port. in the printer list it shows as ready. But when i send a test print it sits in the print queue on the workstation and eventually comes up saying it had problems printing to the printer.
I can use the web interface and can go and look at the setttngs too. I am using the right driver too.
Regards
Raman
  • gamaliel8008 Jan 09, 2009
    my toshiba laptop will not add a printer from my slave pc.It will only open windows player on slave but will not print.help
    Problem Solver:
  • 10 Answers
Try this:
start, printers and faxes
right click on the print driver , go down to properties click
click on ports
click configure port
click lpr in protocol
Lpr queue name PRINT
LPR byte counting enable
SNMP enabled
Try this and make sure your ip address is correct
Posted on Feb 06, 2008
    Problem Solver:
  • 4 Answers
Do you have the print enabler? These printers have to have a special usb thumb drive type deal that enables certain features like network printing and scanning. If you don't have one, its not going to print. Do your research before buying one if you do need it because they are not generic, they are specific for each printer module and even firmware version.
Posted on Apr 30, 2010
How i print and scan with pc?
Make sure printer & scanner kit is installed on the machine, then connect network cable, setup ip address, install printer driver
Jun 30, 2015 | Toshiba e-Studio 355SE Copier, e-STUDIO355...
Hi All, I am trying to connect Toshiba e-studio 207 via local network but unable to make it work.
Best way to Check is getca status page from your printer ,check the IP address that’s been assigned to your printer via dhcp from the router ,then just add the printer manually by creating a tcpip port with that op address
Oct 28, 2017 | Toshiba e-Studio 232 Black and White...
Toshiba studio 350 network printer setup
I can send you the Networking Manual if you send an email to LBrown18062@hotmail.com. Please put 'Toshiba e350 network' as the subject or you can go to the link that I have included here. http://www.eid.toshiba.com.au/Downloads/manuals/230-280_350-450_3511-4511/eS230_350_3511_NetworkAdminGuide_Ver.00.pdf
Jan 27, 2012 | Toshiba e-Studio 350 Copier
Driver for Toshiba e-Studio 16S printing for Win 7 computer
pls go doenload page of toshiba. then u can easyly find out the driver for win7.
Jul 24, 2010 | Toshiba e-Studio16S Copier
Cannot set IP address on Toshiba e stuido 16s copier
In order to set IP address, make sure printer kit/NIC is installed. Plugged network cable, Press Program button--> Initial Setup-->Network-->TCP/IP to configure IP address. Once finish, back to Network-->Complete to save the settings.
*Machine need to initialize network during startup, once finish initialize network then only u're able to access network settings. A status page will print out by default after finish initialized network.
Jan 10, 2010 | Toshiba E-Studio167 Copier
HOW TO RESET NETWORK INITIALIZING LIGHT TOSHIBA E-STUDIO 350 COPIER
Press User Functions>Admin>then enter 123456 (password) then go to the TCP/IP section and clear all the IP addresse/s out of the fields then hit enter.
Press Back>Back>Copy>User Functions>Shutdown. then turn the machine back on.
Oct 13, 2009 | Toshiba e-Studio 350 Copier
No IP address was set
Turn off DCHP after setting the IP address
Sep 21, 2009 | Toshiba E-Studio167 Copier
Xerox Phaser 8550 Won't Print
I was having the same problem. Turns out the IP address in the printer was incorrect. Once I changed the IP address the printer works just fine through our network again. Find your IP address off your server and follow these steps:
1. Choose Info on display menu, press okay button
2. Choose Info pages, press okay
3. Configuration pages-printer info, press okay
4. IP address should read: Correct IP Address number should be displayed on screen.
If not follow these steps to change it:
1. Find printer setup on display menu, press okay
2. Go to connection setup-press okay
3. Network setup-press okay
4. TCP/IP setup-press okay
5. Auto should show as “Off”
6. TCP/IP should show as “On”
7. DHCP/Boot should show as “Off”
If any of these are not listed on display correctly press ok, reset to either On or Off and then enter correct IP address.
Press okay button and follow steps on display menu to exit back to main menu display screen.
Mar 12, 2009 | Xerox Phaser 8500/DN Printer
Compatability issues with Toshiba e-studio 350 copier and Windows Vista
This copier must have the latest firmware installed, a print enabler and you must have the latest print driver in order for Vista to be supported. All of this is available from a certified Toshiba dealer. Also, you can check to see if the copier is working by inserting the Cat5 cable to the copier from your network and typing in the IP address (found under the Administrator tab on the touch panel of the copier) into the URL bar of your browser. A web page will pop up showing the machine is active.
Oct 21, 2008 | Toshiba e-Studio 350 Copier
Toshiba e-STUDIO 16 Printer Logo
1,550 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
