Question about Proview PL926WBi 19" LCD Monitor
Proview monitor problem
The problem that I am now experiencing intermittently is an image on the LCD screen that has "ghosting" (lines and objects repeating fainter and fainter- echoing to the right). For all that remember analogue tv, it looks like the antenna should be moved. Would like some suggestions.
  • Anonymous Feb 02, 2008
    yea thats funny i bought a proview monitor from pc richards too it lasted one and a half years also.... think im gonna print this and bring it down to pc richards just to get a laugh at them
  • dustinplicis Feb 12, 2008
    I'm having the same "ghosting" line problem with my ProView FV926W. I was just reading a PDF that had same tabled information in it. The horizontal lines in the table can be seen faintly all the way to the right edge of the monitor. Did you find any resolution? I've only had this monitor for a year or so, and it's been great up until now.
I bought a proview monitor at pc richards looked nice price was nice BUT it only lasted 1 and a half years
Posted on Feb 01, 2008
I bought Same Monitor Dec. '06 and Jus last week It faded to black and then now doesn't power on. my protection plan sent me a new one that powered on for like 20 secs. So now I have another one coming. I also knows its not my PC cuz I'm using a monitor right now. I think Proview and Circuit City Sucks
Posted on Jan 29, 2008
Ghosting lines on a samsung LN40A630M1F
The TCON Board or the LCD panel is faulty. Can confirm only by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 16, 2016 | Samsung Televison & Video
I get ghost images. Is there a way to de-gaus an LCD monitor?
Sounds like it's either ghosting, or image persistance.
Ghosting on LCD monitors is usually caused by interference via the monitor cable. Try moving your monitor cable so that it doesn't pass near any other cables or electronic devices. If that helps, then position the cable away from the others perminantly or replace the cable with a "shielded" monitor cable.
Image persistance on an LCD can be caused by leaving it on with the same image for a very long time. The pixels don't exactly "burn-in" like on the old CRT monitors, but over time, they can develop a memory that causes them to change color slowly or incompletely. Prevention is best (turn the monitor off when not in use, or use a rotating screen saver.) But if it is already a problem, you do have a few options. You can turn it off for a long time, run a rotating screen saver for a long time, or display a solid white screen for a while. Another technique is to create a slideshow in the Windows screensaver with a solid white image and a solid black image (create them in MS Paint and save them where you can find them later.) Let it alternate between the white and black screens for a while and check to see improvements.
Jan 11, 2011 | Envision EN-7100e 17" Flat Panel LCD...
Ghosting of images and buzzing when on mostly white screen X2gen 19" monitor (HP/Vista )
Please bring the unit to an authorized service center as there's an internal electronic part/s of your monitor that is cold soldered / defective. regards
May 27, 2009 | X2Gen MG19VT 19" LCD Monitor
Proview 15" screen turns white
probably failure in the LCD controller IC in the lcd controller board. that no signal was sent out to the lcd driver ic thus you could only see white display. A replacement of LCD panel is the best solution. I suggest to bring it to an authorized service center. best regards
May 22, 2009 | Proview PL916S2 Monitor
Westinghouse LCM-22W2 has "ghosting"
Usually, LCD monitor ghosting appears when the cable isn't tight, the cable is faulty, or low quality. The cable should be less than 8-10 feet long. Try using a different monitor cable (they're mostly interchangable) and see if the problem goes away. I'd put my money on the cable or a loose cable connection.
May 13, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Feb 07, 2009 | Dell E207WFP LCD Monitor
Double Images / Shadows on the monitor screen
Hi..there,
Have you guys...try to open your OSD on your monitor and blanced the colors or adjust the WB (white blanced) settings....
Jun 30, 2008 | Gateway FPD2275W LCD Monitor
LCD display Proview
If the screen is pinkish chances are the panel is defective.Should follow-up with Company Proview and do some correspondence.
Samir
May 23, 2008 | Proview PL926WBi 19" LCD Monitor
Proview 19inch LCD MA982k model 900p
You are on the right track. Sometimes the ribbon cables will look fine but the wire inside the insulation is broken and will result in intermittant problems. Definately check the cable first and repair or replace. It is best to meter the cable while not connected to avoid false readings through other components. Should be a relatively easy repair.
Jan 03, 2008 | Proview PL926WBi 19" LCD Monitor
Beware this monitor! PL713s
Probably a good solution. 17" LCD's are pretty inexpensive these days and probably cost as much to diagnose and fix this one. You can purchase on-line as well. www.tigerdirect.com www.newegg.com Good luck
Aug 27, 2007 | Proview PL713S 17" Flat Panel LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
219 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
