Question about Macally iShock Game Pad
Xp driver is there a driver for xp?
0 characters
1 Points
Windows 7 driver needed
If you have Windows 7 32-bit, the XP driver will probably work. has a copy. However most copies of Windows 7 are the x64 version. To check your OS version, click on Start and choose the Control Panel from the right hand column. Click on the System and Security link and then the System link. Read the version information. If it ends with x64, you aren't going to find a driver. You can try the compatibility mode with this driver but it often doesn't work for drivers. (Right click on the exe after downloading and choose properties. Go to the Compatibility tab and try setting it to Always Run in the compatibility mode with XP. Then right click again and choose Run As Administrator.) You may need to repeat this for the installed software as well; note the folder destination for the files.
If you have Win7 x64 and the compatibility mode fails, you would be better off upgrading to Windows 7 Pro and installing Virtual PC and XP mode. Then use the above driver in the XP virtual computer that is created. Alternatively, look into getting a new racing wheel controller that has a Windows 7 x64 driver.
This product was produced for systems with 16-bit and 32-bit versions of Windows. Since Microsoft requires digital signatures on x64 drivers, there would be significant costs to writing new drivers and getting them approved and signed. I'm not sure Game Elements is still in business.
I wish that I had better news for you.
Jan 16, 2014 | Game Elements HV-5 (GGE904) Wheel And...
I need the gamepad's driver for Windows XP.
Try that website to see if you can find a driver for XP. Honestly, if it is newer, you may NOT have compatibility directly and you may have to use XPAD or something similar to map the controller.
May 13, 2011 | Trust Predator GM-1520 GamePad
I have changed my operating system from XP home to Windows Home Premium. my Saitek AV8R-01 seems to be designed for XP. Can I intall a driver that will work with Windows 7
The driver for Windows 7 can be downloaded from here:
From the second drop-down menu to the right select Joysticks then select AV8R and then select your operating system.
You'll have 2 buttons with the driver and software. Click on each and save the driver to your computer then install them(driver first).
Hope it helps. AV8R AAV8R
Apr 26, 2011 | Saitek Aviator AV8R Joystick
Need driver for windows XP?
There are no drivers, you need to set up a custom game controller.
Mar 06, 2011 | Mouse Systems Bogeyman Racing Wheel...
Are there any drivers for the InterAct Pro Raider digital sv-251 joy stick to make it work with windows XP. I have the cd rom that came with the joy stick when I bought it new years ago, but it appears...
You can find the driver Version:120.905 here
Just click on the "Interact Bios Download" link and download should start.
The driver is meant for win95/98 but could also work for xp.
Jan 04, 2011 | InterAct Accessories InterAct RaiderPro...
Have older gravis joystick. computer won't recognize it. windows xp. ran device mngr and set the settings on the game i'm playing for joystick.
Hard to find Gravis Game controllers driver for XP system to download.
Please read the readme file before install.
Gravis Blackhawk Digital Joystick XP drivers:
Aug 28, 2010 | Gravis BlackHawk Joystick
Drivers Emach T5230
I solved this problem completely later that day.
Here's how:
From the Emachines site I downloaded and installed the file:
This dirver is for vista but it must also be for XP because it really worked well.
This can be found at
click on: customer care > product support and downloads.
Then select desktops, T-Series, and T5230.
By clicking the plus sign [+] next to downloads below you will see a list of drivers including:
Realtek High Definition Audio Driver
be sure to click on the Driver File Download (36.29 MB) and not just the readme file.
download this to your computer and run the self extracting install.
Then right click on the MyComputer icon (on your desktop or windows explorer) and choose Hardware tab and Device Manager to verify that the RealTek audio device is working properly.
You'll see the other broken devices there of course.
I went to and downloaded:
nvidia is easy to navigate. Just click on Download Drivers
The GeForce 6150SE video card driver
From Option 1 select GeForce, GeForce 6 Series, Windows XP and click the Search button. Then click download now. to save the file to your computer so you can click on it there to perform the driver install. This made a huge difference in the quality of my display.
nForce 430 chipset driver installers
From Option 1 select nForce, nForce 4 Series, GeForce 6150SE/nForce 430, driver, windows XP. Then click search followed by Download Now to save the file to your computer for installation.
This took care of everything but the generic PCI device.
For that, I hooked my legitimate copy of Windows XP to the internet using my newly functional RJ-45 network jack and an ethernet cable and let windows find the driver for me. Which it did seemlessly. No More Yellow questionmarks in the Device Manager!
That was mostly painless.
I noticed that some quicktime programs didn't like my nVidia driver so I created an alternate hardware profile to use the generic windows video driver and that solved that problem too.
I didn't have to open the case on the emachine and I still have the Vista install disk that came with it if I want to go back.
I'm impressed that my games work fine on XP home when the didn't on Vista. I expected it to be the other way arround.
Feb 19, 2008 | Microsoft FREE Sidewinder Gamepad...
Microsoft's Sidewinder Force Feedback Pro Driver
Sorry to report that there is no driver for this stick that will allow the feedback to work with Win XP. I wanted to cry when I first found this out. I've been searching since the mid 90's for a work around for this. We can send a man to the moon and back on less than 1 meg of ram. But someone can not get this stick to work properly with Win XP?
Dec 28, 2007 | Microsoft SideWinder Force Feedback Pro...
Macally iShock Game Pad Logo
43 people viewed this question
Top Macally PC Game Controllers Experts
steve morris
steve morris
Are you a Macally PC Game Controller Expert? Answer questions, earn points and help others
