Question about Microwave Ovens
Unit will not function
Hello, I went to use my microwave this afternoon, set the time went to activate, complete system went dark, no response of any kind. Checked to make sure cord was plugged in and that circuit had not tripped, negative on both counts. Unplugged and let it set for a bit, still no response. Any idea what may have happened and is there anyone that can repair these units in downstate Illinois.
If the light bulb is burnt out it may prevent it from working.
Posted on Jan 22, 2008
  • 397 Answers
Well how old is the unit? and if you do a local search you will find a service place with in your zip code....that will be the better solution for you....good luck and hope this works,,but its not something that is a pin point solution....
Microwave won't turn on and beeps flashing numbers
Some newer microwave models will not function UNTIL you set the CLOCK Function ... ok
There should be instructions in your microwave MANUAL to tell you how to do this; as it can vary widely between different brands and models.
Nov 23, 2013 | Frigidaire Microwave Ovens
My JennAir went completely dead. It is probably 13 years old. Should I replace or have someone try to fix it?
Hello -
I cannot give you instruction on how to remove the kit(?) surrounding your microwave.
I can provide you with information which may help you decide if arranging for an repair technician authorized to service your JennAir microwave is the best option compared to replacing it. I refer you to the information from Angie's List:
https://www.angieslist.com/articles/microwave-repair-and-what-it-costs.htm
Best wishes.
Jan 15, 2018 | Jenn-Air JMC8100 Microwave Oven
Forgot how to set clock on Morphy Richards P90D23AL-B7/H Microwave Oven
Iain's solution is great but one addition to it which threw me completely.... if changing your clock in the afternoon.... the time isn't using a 24hr clock, it's just a 12 hour one so if you are wondering why the time still won't set try using the 12hr clock instead
Oct 30, 2011 | DeLonghi P90D23ELT2AH Microwave Oven
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
Microwave activate but will not heat food all light and buttons work but will not heat up
Sorry to read about your problem, I hope this helps you out.
You can many different issue's
  1. Blown fuse in HV transformer primary circuit or HV fuse (if used).
  2. Bad connections (particularly to magnetron filament).
  3. Open thermal protector or thermal fuse.
  4. Open HV capacitor, HV diode, HV transformer, or magnetron filament.
  5. Shorted HV diode, HV capacitor (will blow a fuse), or magnetron.
  6. Damaged protective VDR from filament to chassis (not commonly used).
  7. Defective HV relay (not commonly used).
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
After using the oven, when I attempt to use the express function-it reports an error function #6
You have a keypad/control issue.
3 Thumbs - Helpful
Jan 04, 2011 | GE Advantium SCA2000B Microwave Oven
My ge profile spacemaker II microwave went dark, no lights of any kind and no sound or response when pressing any button. tried resetting the circuit breaker but no change
Did you check the internal fuse? Often when everything is dark the fuse that protects the microwave is blown. Take the old fuse to your local hardware store and they will have a replacement for you. Should cost less than $5.
Nov 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool gold accuwave microwave oven lost power afer running em
Hello Davisaroundt, we are sorry to hear about your Microwave not powering on. If you would like for us to schedule service for you, then can you please email your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 13, 2017 | Whirlpool Accuwave Microwave Oven
Microwave wont heat
look at the $2.00 door safety interlock switch(s) before you replace the very expensive (and hard and dangerous) magnetron.
Dec 23, 2009 | Kenmore 63252 Microwave Oven
Microwave activates and sounds fine (no unusual noises) but nothing is heated.
You could have a number of problems in this unit BUT let me WARN you of the extremly high voltage inside this unit first!.. Theres a capacitor and a diode connected together that holds a charge that could be open , Theres a magnatron or the magnatron thermal cutouts that could have went bad. Theres a relay on the control board that could have went bad so therefor the control board could be bad. The power transformer for the Hi voltage could have went bad but not likely unless you seen or smelled alot of smoke or oder before it went bad. Unfortantly, these days a good microwave, to have fixed, is about or almost 3/4 the price of a new one. Without troubleshooting the unit with a multi-meter your really shooting in the dark with what part is bad as it could also be a combination of parts bad that I described. If you think its worth it, take the thing in for an estimate, but I would highly advise against you doing it unless your famillar with the dangers and the high voltage points. Good Luck
Jun 14, 2006 | Frigidaire FMT144G1 Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
