Back to:
Tags:
Panasonic PV-GS39 Mini DV Digital Camcorder
BROKEN LCD (by 2 users)
posted by carlosp1 on Jan 21, 2008
I have a brioken LCD, just bought the part. How do I de isntakll old and install new? Help
Comment by carlosp1, posted on Jan 23, 2008
I took out all six visible screws and could not detach LCD. How do you replace the LCD?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by deprivedl, posted on Sep 08, 2008
I bought a GS39 miniDV on ebay and the LCD was completely cracked.. it looks like it is splattering from every corner. I want to buy a replacement, but I don't know where I can go to obtain it. I have looked online and found nothing. Please share some sources!
Best Solution
posted on Jul 03, 2008
Helpful (85)
danielnotdan
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
Hi.
Jeez! You posted this in January! I wonder if this is even still an issue for you.
Well, what you DON'T do is take out absolutely every screw you can see and then pull the damn thing apart, nearly rendering it useless -- like someone I know nearly did....
I can only help you as far as getting the LCD off/exposed. I dropped my camera the other day and discovered my cracked LCD screen.
You say you've taken all 6 screws out. That's good. There are two MAIN (sort of hidden) screws on the bottom of the LCD screen itself -- these hold the frame of the LCD to the shell into which the frame fits. If you look closely at the LCD screen, you'll see there's a plastic frame around it. This is actually sunken into an outer shell which encases it.
Turn the LCD screen around so that the glass faces outward and fold it flat against the camera -- LCD facing outward instead of inward (the silver Panasonic logo should be against the camera body). Now you have a flat surface to work with.
The whole LCD screen mechanism is sandwiched around the pivot point. I took two flat blade eyeglass screwdrivers (you know, the real small kind) and started prying at the pivot point. As you work one bigger flat blade into the pivot point and pry up, use the other screw driver to keep the plastic frame still pryed up in place while you reposition the other screwdriver, continuing to "walk" the screwdrivers carefully around the perimeter of the frame. It won't be too long before you'll see that just off of each corner of this plastic frame there are small tabs which should easily pry away from the plastic "Panasonic logo" shell.
The LCD then sort of pops out of the shell and dangles by a ribbon connector.
I don't have any clue where to go from there, tho. I haven't purchased a replacement screen yet.
May I ask: Where did you buy your replacement LCD from? Do you know how to reattach a new one?
I hope this helped.
Thanks in advance!
danmillen (at) hotmail (dot) com
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on BROKEN LCD:
I don't want to Accept this solution
Can you Help with these Camcorders problems?
I cannot see the object in the lens or in the lcd display....
Hi,  I'm on playback mode and I keep getting this...
i use panasonic pv-gs39 comcorder. when i connect my...
I know it's probably really simple but I just can't figure...
I have bought my new Panasonic Camcorder NV GS60 model,...
Loading problems.
Repair Service
Find Camcorder Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
