Question about HP Pavilion Ze4805us Notebook
Heat Sink/Processor Fan
Fan keeps speeding up and runs for a long time before retunning to normal.
    Novelist:
  • 109 Answers
This doesn't neccesarily indicate a problem. Just to be sure, Check your systems temperatures in your notebooks BIOS.
Press F10 when the HP Invent logo shows up when you boot it.
Do not forget that a notebook generates a lot of heat. Since all internal components are literally packed. A notebook is fully filled with parts.
At what point does the fan return to normal? And at what point does it speed up?
Greetings,
DarkNeogen
Posted on Jan 24, 2008
Fan runs hard computer is slow hp compaq nc6000
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
- Shut down your computer at least two hour a day.
Hope these tips will help.
Jan 05, 2014 | HP Compaq 6735s Notebook
Tip
Computer or laptop turn off automatically after sometimes
this reason comes due to over heat of processor.
solution-
1. check the heat sink fan is running or not
2. chech is there paste between heatsink and processor.
after solving these problem if your problem exists.
then it may be due to slowly of the fan speed and the heat sink goes over heat.
so, open the stiker over fan then put 1 or 2 drops of oil in the hole. then run your fan by manually your hands if the fan goes ok then re install it.
now your problem is finished.
on Dec 23, 2009 | Computers & Internet
Computer hangs after startup
Dec 17, 2013 | EliteGroup K7VMM Motherboard
Fan dose not slow down
It seems that your system is overheating so follow these instructions first
- Make sure your dint restrict the speed of CPU fan
- Shut down your computer atleast two hour a day
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of overheating
Aug 27, 2013 | HP TouchSmart Computers & Internet
Just on normally but of 1,3,4,5 min automatic of
check the processors heat sink. if it is too hot then it is overheating.
buy a small amount of thermal paste. remove the heatsink together with fan from the processor. remove the gray or white color like grease. clean it then dry. put the thermal evenly unto heat sink and top of processor. put back heat sink and fan. then test run.
Aug 23, 2013 | MSI Computers & Internet
I HAVE AN ASUS MB WITH A DUAL CORE ATHLON PROCESSOR 4800+.SINCE THE PROCESSOR COOLING FAN WAS FIXED IN A BAD POSITION I REMOVED THE HEAT SINK, CLEANED IT, PUT HEAT SINK COMPOUND AND FIXED IT IN THE RIGHT...
Hi.
Even if a defective CPU may decide to overheat by itself the case would be quite unusual.The problem is usually caused by a defective fan or by a fan incorrectly installed. Be sure that the fan is starting and replace the fan.
As a first step try once again reinstalling the fan. This time measure the temperature using a software like SpeedFan.
If there is no change in temperature reading, try replacing the fan. A fan with damaged bearing may provide insufficient cooling resulting in overheating.
PS: be sure that problem is temperature and not system crashing. The temperature monitoring software will tell you.
Regards.
Ginko
Jul 08, 2011 | Computers & Internet
My dell optiplex gx 620 system fan run so fast and produse a lot of noise when i play games or downloading data from net
Open up the computer and clean the dust out of the fan and processor heat sink. If it is a temperature-controlled variable speed fan, it will probably not have to work so hard to keep the processor cool.
If it is a fixed-speed fan, it may be getting loud because the bearings are wearing out. Gently try to rock the fan blade unit - it should not have any wobble or slop in the bearings, and it should rotate easily.
If necessary, clean as much dust as you can out of the power supply without taking it apart.
Do not use a regular vacuum cleaner to **** dust off the motherboard. The high-velocity airflow may generate electrostatic charges that can damage the board. It's probably OK to vacuum out the heat sink if you hold the fan still to keep the vacuum cleaner from over-speeding it.
Apr 29, 2011 | Dell OptiPlex GX620 PC Desktop
Dell optiplex GX620 loud processor fan noise like a vaccum. I upgraded to windows 7 and also upgraded to 4gb of ram and a new hd video card as well as a 1tb hd. I bought 4 more gbs of ram but windows...
I don't think you can install 8gb of ram into that desktop. If the processor fan is too loud check it for dust or any other obstructions. If there aren't any try replacing the fan - it could be a bearing in the fan.
Mar 06, 2011 | Dell OptiPlex GX620 PC Desktop
My hp media center m7160n computer powers up, has a definite fan sound, normally the fan sound diminishes and the computer boots up. For the last several months, the high speed fan sound would not diminish...
How did you clean it?
The last one I worked on had the fins of the Heat sink totally blocked with dust. This will make the fan scream trying to push air thru the heat sink to cool the processor. If it isn't cooled it will shut down in short order.
You must BLOW it out. Use a pressurized air can. Better if you have a compressor with a nozzle.
The other issue may be the interface between the CPU and heat sink is defective. Heat sink moved or become loose.
Of course by this time the processor could be dead also.
May 17, 2010 | HP Computers & Internet
CPU FAN SPEED IN HP Compaq d530 Small Form Factor Desktop PC
The fan/heat sink on these models get plugged with dust very easily, use an air compressor or can of air to blow the dust out of the heat sink and fan. In extreme cases the thermal paste gets dried out and needs to be re-applied to properly cool the processor.
Dec 01, 2008 | HP Compaq d530 SFF PC Desktop
HP Pavilion Ze4805us Notebook Logo
59 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
