Toshiba rear projection tv
The tv was in perfect working order. I switched the tv off from the sockets and put it back on, the power light came on yet i couldnt turn the tv on with any remote. I lost my original remote control and bought a remote for all tvs in which you have to put a code in. The remote worked well but sudenly stopped working. I changed the batteries but still nothing. Then i bought an original remote still i couldnt get the tv to come on. please help
  • 8,617 Answers
Will the tv power up with the power button on the TV control panel? If so its your remote sensor inside the TV. Let me know your model number.
Posted on Jan 22, 2008
Sharp Aquos LC45GX6U & TU-GD10U. The unit doesn't power up, and has a red blinking light from the moment you plug it in. The unit works fine in service mode.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sep 27, 2015 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
My akura TV has switched itself off and every time I try to put it back on the blue light just flashes
Sounds silly, unplug the tv and any appliances in the same socket connected to the tv, plug the tv in on its own and just hold the power button for an extra second or two if this works, leave the tv on and plug the applications back in
Dec 30, 2014 | Televison & Video
My onix 40" Fhd LCD tv has power going in (red
In order to ensure, it is not caused by the input device, connect a DVD player and see. Also look for any loose contacts in power outlet, RC jack, cable and socket. Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, I suggest it is better to refer it to a qualified service technician, since the back cover has to be opened for investigation/rectification.
Aug 21, 2012 | Televison & Video
HI, i Have a 42" lg3000 lcd tv when I switch the
Hello, I have exactly the same problem with the exact same TV, white screen for about 15 minutes and than image appears perfect as if nothing happened. I have asked an ebayer which sells TV parts and he suggested it could be a main board or tcon board. I am quiet hesitant to fix my tv, but if the tcon board would fix it, i'd go for it. Did You manage to solve the problem yet?
Mar 29, 2011 | LG Televison & Video
42PF9630A 42 in. Plasma Television: hi there, I have a phillips 42 inch plasma flat...
This is because the power switch operated the socket that your TV is plugged into. Unplug it and plug it in another socket that is not operated by a switch. Appliances should not be plugged into a socket operated by a switch because of the inconsistency of power to the socket. Lights are about the only thing that should be plugged in.
Dec 23, 2017 | Philips 42PF9630A 42 in. Plasma Television
Wont come on
Instead of just unplugging the TV, perform a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If the TV still won't turn on, then it appears something is wrong with it's mainboard since the TV is still receiving power because the standby light is still coming on.  The cost of fixing an older TV's mainboard could be costly or impossible if the part is discontinued.
Mar 25, 2009 | Beko 324250WN 28" TV
Toshiba tv will not turn on
I have a toshiba tv and it will not turn on. There is a flashing green light that comes on, but there is no picture or sound.
Oct 31, 2008 | Toshiba DVD Recorder AND Series2 TiVo...
TV won't turn back on
Dan27 = Recheck model # ........
lulu jr. = Slow to charge capacitor in relay / regulator power supply.......Model # , please !
Nov 06, 2007 | Televison & Video
Will not power up after changing the case
I found this on ebay after a lot of searching forums and other sites, and it worked for me!
"If you are one of the unlucky ones, LIKE me, you may find after taking it apart,and then putting it all back into the new case, that when you power up, bottom screen flashes, and nothing... DONT panic.. I did.. tried looking for help on the web and couldnt find any. It just means you, like me havent pushed one of the Ribbon cables fully in... took me a while to work it out, just unclip the ribbon cable again, and with both fingers gently push it all the way in, you will feel it slide into the socket more than it did before. "
Good luck Duca
Sep 14, 2007 | Nintendo DS Console
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
