Question about Dell Latitude D600 Notebook
The hard drive isnt working
My computer will not recognize the hard drive any more. I do not know what the problem is... It was working fine until a little while ago.
  • hackingsucks Jan 21, 2008
    thanks the screw came out.
    New Friend:
  • 44 Answers
Um make sure your hard drive is seated correctly. It may have slid out!
Posted on Jan 21, 2008
Not recognize
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 06, 2011 | Western Digital 1TB My Passport Essential...
My computer does not recognise my Apollo portable HDD. The cable is fine, tested on another device...all good. Please help, I'm no wizkid on computers.
if you tested it on other computer and if its working fine then it means that your USB port isnt 2.0 if it is then right click on my computer and select manage. may be you selected the custom drive letter if u do so then it wont work until u change it back again. try it.
Feb 25, 2010 | Computers & Internet
My computer isnt recognizing it
You will need to install the drivers to your computer before the system will see the drive because of the "size" of the drive (1 TB) and the way the OS will need to "talk" to the drive in order to recognize the correct size and know how to place the files on the drive.
Jan 07, 2010 | Western Digital My Book Essential 1TB...
I have a 250GB Buffalo Turbo USB Hardrive. Until today it was working fine. Now suddenly it says USB Driver not recognized. Whats the problem?
Try to insert it to the other usb ports and see if it works fine. If it doesn't, then probably there is a problem with it. But try to insert other usb devices in the usb ports of your computer, if it does'nt recognize also then the problem is in your usb ports.
Oct 30, 2009 | Buffalo Technology 250GB MINISTATION TURBO...
Vista stops recognizing external hard drive
This doesn't sound like an OS issue. This appears to be more an issue of the connection to the hard drive. The USB cable likely isn't the culprit, nor the laptop USB inputs. If the drive was ever dropped or the cable gets removed and reattached often to the actual enclosure, you might be looking at a bad port on the enclosure. This isnt a lost cause. You can always buy a hard drive enclosure from newegg and move the drive from the IOMEGA to the new enclosure. You can get a new enclosure for $15. Just because the USB port is bad, it doesnt mean the data is gone and the hard drive cant be used.
Aug 26, 2009 | Iomega 33089 250 GB Hard Drive
My hard drive is making funny noises and isnt recognized
If you get it going, you should immediately store all the data on another drive
Aug 19, 2009 | Western Digital My Book Essential Edition...
ST-500 not recognized with Epson CX9400 printer
Printer is draining USB power resource. Add a powered USB hub and run drive off of that.
Jul 23, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Phillips external hard drive
There is a chance that the hard drive itself is at fault and the computer cannot recognize it try using it as a slave drive in computer. and use a recovery cd from boot to check it out
You could use thee ultimate boot cd (download) to check it
Aug 03, 2008 | Computers & Internet
My hard drive just stopped working all of a sudden
Search around on this site for MyBook 500GB problems. I've responded to a couple, but it amazes me that lots of people, including myself, has a failed unit. Mine lasted 1.5 yrs and failure is caused by burned chip pins on the drive controller. Seems likely to be a heat issue. More info about what I did; see my other posts.
Feb 18, 2008 | Western Digital 500GB My Book Pro-External...
Seagate external hard drive problem
Hello, Did you try to use this drive on another computer? Did you have the same problem? Did you try using a different cable? I would try these things first in order to determine if the problem is with the drive or with the computer. Good Luck! Dr. Know
Dec 23, 2007 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Dell Latitude D600 Notebook Logo
57 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
