Question about Frigidaire ATF6000ES Front Load Washer
Affinity front load washer
I own a front loading washer. Whenever its turned on it doesn't fill up the tub. The water doesn't turn on.
  • robert samples May 11, 2010
    first remove the hases from the washer check the screens at the warer valves to see if they are clogged then get a bucket and put the hoses in there and turn them on to see hoe strong the water is and let me know also is there power to the washer
My front load washer won't spin water out
Posted on Jan 22, 2008
Why does my frigidaire affinity smell
clean it by using 5 cups bleach fill soap cup put rest in tub wash in hot water long cycle run another or 2 after to make sure bleach is gone
Jun 07, 2014 | Frigidaire Affinity ATF7000E Front Load...
My washer has water in tub after the washing cycle
Hello Romy, approximately about how much water is left after the cycle? In this case, I would recommend reprogramming the washer by either unplugging it or flipping the household circuit breaker. It is important to wait ten minutes and then turn on the unit. If the issue persists, then more than likely the washer could possibly have a faulty fill water valve that is allowing water back in or not draining properly.
Jul 26, 2013 | Frigidaire Affinity ATF7000E Front Load...
FRIGIDARIE AFFINITY WILL NOT FILL UP WITH WATER ALLTHE WAY
Hello Carl Kjonaas - Is the house valve(s) fully turn on? Typically when water is not filling completely, the washer could possibly have a faulty switch that does not allow the valve inside to turn or a kinked fill hose. Other possibilities of more potential serious issues are water valve faults, faulty control board, pressure switch or wiring failure. If I was in your position, I will personally consult a professional to move forward accurately and assist with the repairs.
Feb 19, 2013 | Frigidaire Affinity ATF6000F Front Load...
My frigidaire affinity front load washer ATF6000FS1 wont fill with water
Hello hitman43 - Are the house valves turn on fully? Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Contact a professional to move forward accurately.
Jan 01, 2013 | Frigidaire Affinity ATF6000F Front Load...
Problem with water in tub of front load washer
Two possibilities here - bad valve, not closing completely when off or you have a bad control that is sending residual voltage to the valve when it is off. Contact a service technician.
Aug 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have a frigadare affinity front loading washer and when i try to start a wash cycle the door locks and just as its ready to start running water it shuts off and if i go right behind that and just hit the...
Typically washing machines have a swtich in them that is pressure actuated, has a tube that goes up the cavity ( inside the outer tub ) and uses the water height to determine to shut off the water. If this hose is broken or something is plugged in it, it could think that it already has water or that its not filling at all (as long as its already started the water). Other wise I would make sure the washer knows the door is latched with some sort of indicator, because if the machine thinks the door is still open it will not fill.
Jun 24, 2010 | Frigidaire Affinity ATF7000E Front Load...
Water level too low. clother wet. No water visible or suds. What is wrong.
Your expectations are based on top load washers.
Front load washers use only a very little water, and suds are an enemy. (HE soaps are designed to clean without suds. Suds are really for show and cause drag on the wash tub during spin.) If you start a load with no clothes, you will see that the water level never gets above a couple inches in the tub. That is the correct water level for front loading machines. PS. Because of the low water use, make sure you use very little soap. (one to two tablespoons per load only!)
Aug 12, 2009 | Frigidaire Affinity ATF7000E Front Load...
Water filling tub
You need a new cold inlet valve fitting.
Dec 08, 2008 | Kenmore 44042 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
301 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
