Question about ADC Kentrox SS-315 Home Equalizer
Can I still used this equipment
I bought an ADC Stereo Frequency Equalizer model SS-315x in the late 1980's. I just bought a Sony Multi Channel AV Receiver model STR-DG510.
Can I still use this equalizer with this new receiver or is the SS-315x too outdated?.
No tape in/out connections on this receiver compared to my old Yamaha Amp/Pre-amp.
Jerome Mcdaniel
  • 1,512 Answers
Hi Jerome
You will need either a pre-in pre-out connection on the amp to use, A vcr in/out loop can be used in lieu of a "tape" loop. Or alternatively you can put the EQ in line with the bit of gear you want to EQ. In this day and age, of "many more than stereo" systems, a 2 channel EQ has much less application. Although this seems to "outdate" a piece of gear, most stuff from yesteryear still sounds great, so why stop using it. Good Luck and happy listening. A "FixYa" rating from you would help my profile. I am happy to answer any questions you may still have, put them in here and I shall get back to you.
Posted on Feb 11, 2008
How do I hook up my bose 901s to this unit?
Well the basic connection of the speakers would be the same as another stereo speaker pair. Wire the left and right speakers to the L/R Front Surround speakers on the Denon.
With the 901's I am assuming that there is an external equalizer supplied by Bose. Typically this EQ is installed in a tape loop on the receiver/amp so that it is ahead of the power amplifier that drives the speakers. This EQ needs to be there to attempt to get reasonable frequency response from a speaker that has only 4" drivers. I'm not sure I see any reasonable way to make the EQ work with the Denon AV receiver. You'd likely be better off using the Bose speakers in a dedicated 2-channel stereo and getting a set of speakers for the AV usage.
Apr 16, 2016 | Denon Avr 3805 7.1 Channel Audio Video...
Manual download for adc ss-110 equalizer
Try these links
Feb 05, 2012 | Audio Players & Recorders
Hello,i recently purchased a graphic equalizer on ebay to work in conjuction with a tape deck, two turntables,two cd players,two mics and a mixer.The model of the unit is a ADC SS-115,i got it home...
I admire your desire to make a nice piece of classic gear whole again but the cost of simply replacing it with a fully functional one is probably less.
Having owned an old Sound Shaper with mechanical sliders I can tell you that you will eventually start to encounter noisy contacts and slider that will drive you crazy. I only used mine for recording and eventually I could never trust the sliders to move without inducing noise. I eventually got an ADC SS-525X with all electronic sliders, Real Time Analyzer/EQ display, 4 curve memories, remote control and life is good.
Surf over to eBay and look around.
There's one SS-525X with no mention of the Remote or calibration mic (which I have but never used anyway). The display lights up in that bright Fluorescent Blue....
Sep 15, 2011 | Audio Players & Recorders
Hi, I just purchased a used set of 901s with the original active equalizer. they are both series VI and were bought together. Unfortunately, the man misplaced the installation instructions for the...
If no Amp is used, connect jacks ( Left, Right) from your receiver output to Bose equalizer Input ( L, R) where it says Amplifier. Then also under where it says Amplifier, connect jacks from Output to your speakers. This would require the type of speaker wires that are RCA (plug in, red and white) on one end bare wire on the other to the speakers.
I don't know what the output is on your Kenwood, but if it's low watts, an amp is much better to crank those Bose. It's a different connect with an amp. Go L &R from the receiver to Equalizer as before, then from equalizer to amp Input where it says Tuner. then hook bare speaker wires to back of amp to Bose speakers.
You should have full use of Bose controls. The Monitor button is for an extra component that can be hooked up on the back, right side of equalizer.
Jul 15, 2009 | Bose 901 VI Main / Stereo Speaker
Yamaha RX-797 iPod Integration
I have a question first... are the 901's amplified by a separate amp as they should be in a multi-channel (non-stereo) setup?
Better yet read the following then decide if you have iy set up right to begin with. If so, I'd just treat the Ipod or Mac as auxilliary inputs on the receiver. :
I wrote most of this for a different receiver, but if you account for minor differences to your receiver this will work just fine.
There's good news and bad news. The bad news you need a separate amp because a multichannel receiver with Bose 901's attached as recommended for a standard stereo receiver will only sound right in STEREO on stereo analog material. The other speakers around the room are not designed to receive its Active Equalization and if you engage your Tape Monitor you will NOT BE ABLE TO HEAR DIGITAL sources at all. Tape Monitor is for analog stereo material only and on modern AV receivers it disables any digital inputs so you really can't use the Tape Monitor circuit or attached devices for modern digital sources. However, you can still employ the various DSP options to spread 2-channel analog source material around the room. I do.
The good news. I have a setup similar to what you want to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Attach the 901's to the new amp, set its volume to Max and run through your receiver's speaker level setup.
Write off the Tape Out as an input if you use it to extract the Front L&R channels. DO NOT monitor it or you'll chop the 901's out of the signal path AND kill any digital source audio in the receiver.
Jul 02, 2009 | Yamaha MX-D1 2-Channel Amplifier
SEQ-711 connection to sony STR D350Z
You can use the VCR audio connections for a stereo analog processor
Many people want to use an EQ with their modern multi-channel Digital Sound Processing gear but at best an analog 2-channel EQ (or any other processor) will only work with analog stereo sources. On most receivers, simply selecting the Tape Monitor disables all digital inputs. However, most DSP can still be employed with analog source material and a 2-channel processor with varying degrees of aesthetic pleasantness. Beauty is indeed in the ear of the beholder.
If that works for you, go for it. I do it, but I fully understand the limitations.
Mar 15, 2009 | Sony SEQ-711 Home Equalizer
I have an ADC equalizer model # SS-100SL i'm
record out-------equalizer in-------equalizer out------tape in
Mar 01, 2009 | Audio Players & Recorders
398 people viewed this question
Top ADC Kentrox Audio Players & Recorders Experts
Are you an ADC Kentrox Audio Player and Recorder Expert? Answer questions, earn points and help others
