Question about Hotpoint Aquarius WF000 Front Load Washer
Wf000 Programme selected and machine starts. After abount 30 seconds the Energy Saver Light and Rinse Hold light continually flash along with the on/off button.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 27 Answers
Whare the option buttons are if you number them 1 to 5 from top to bottom if led 2 and 4 are flaching this is a time out draining and you will need to check your waste hose for twists traps and kinks also check Filter if there is a user servicable one on the applionce and check plumbing. This is a comman fault and if you get hotpoint out to it even if it is only a day old they will charge for the call out as it is classed as user error or faulty instalation this works on all WF,WD & WT modles with 5 option buttons on the left habnd side the applionces with digital displays will show F-05 insted but it all means the same
Posted on Feb 22, 2008
6ya staff
SOURCE:
Error codes On/off rinse hold & TIME SAVER LIGHTS FLASHING
For error codes and what they mean go to www.selfix-uk.co.uk
Jul 21, 2011 | Hotpoint Aquarius WF000 Front Load Washer
On/off rinse hold & TIME SAVER LIGHTS FLASHING WON'T DO CYCLE
For error code definitions on Hotpoint, Creda and Indesit machines use this link
Mar 18, 2010 | Hotpoint Aquarius WF000 Front Load Washer
When i put it on a wash cycle it starts then all of a sudden the power light flashes rapidly and the rinse hold light flashes steady
Fault code F02 meaning Motor jammed / tacho detached: check motor
& module connections.. on the motor plug check that a wire hasn't become dislodged or broken...
Dec 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Machine fills and drains at the same time.
Check the height of the drain hose and make sure the drain hose is higher than 30 inches from the ground. If your drain hose drains into the floor you may need to purchase a siphon break to stop the problem
Apr 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
On and off light and energy save and reduces creases lights flash
Hi Snarey, it sound like your door lock has passed away, you will need to make sure the appliance is unpluged, empty the water out of the drum, and check the vacuum switch which opperates the lock.
Mar 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
Flashing on/off switch flashing energy saver light
I had the same problem with our hotpoint aquarius WT540P , I contacted EMW electronics who told me it was most likley the Computer board. They supply reworked replacedment boards on an exchange basis. I installed the replacement and the machine's been washing away merrily since. Here's a link to there web site. http://www.emwelec.co.uk/ .
Regards.
Nigel
Apr 22, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Flashing power light and rinse hold light
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 24, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aqaurius WF000 - Flashing Energy save and on/off switch
check your pump for any blockages it may not be pumping out fast enough the tomer only gives the pump a certain amount of time to pump all the water out if has got some blockage than clean out and this should sort the problem out always check pockets if this is no help let me know and ill let u know what else it could be m8
May 15, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
110 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
