FixYa.com
Tags:
Magic Chef 31100 Gas Kitchen Range
Magic chef oven (by 2 users)
posted by hotrodgregg on Jan 21, 2008
Oven burner at bottom does not work. The ignitor gets hot but no gas to light.
Broiler and range work.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by midoan, posted on Jun 05, 2008
I have a old (1995) magic chef gas (LP) stove. It takes beetween 4-5 minutes before the stove ingnites . It says in the manual that it is suppose to take beetween 30 - 90 seconds?? Is this dangerous and what should I do??
Best Solution
posted on Jan 21, 2008
FixYa! (100)
tech17
Rank:Guru Guru
Rating: 88%, 934 votes
change the bottom ignighter just because it glowes doesn't mean its getting hot enough to open the safety valve you should see two screws at the bottom of the floor of the oven cavity after removing the racks remove those and remove the floor then you will see a deflector shield remove that to get access to the ignighter take out the two screws and install the new ignightor and reassemble
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Kitchen Ranges problems?
Kitchen Ranges
Need instructions for a...
Need instructions for a... Answer This...
Kitchen Ranges
Hot plate wont alter heat,
Hot plate wont alter heat,... Answer This...
Kitchen Ranges
hi I have the weber
hi I have the weber summit... Answer This...
Electric oven takes to long to...
Magicchef drop in smooth top... Answer This...
Magic Chef super capacity...
The digital clock will not hold... Answer This...
Repair Service
Find Kitchen Range Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
