Intel D845GVSR Motherboard Logo
Posted on Dec 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tower will not power up
My gateway will not power up. I changed the power supply thinking it was bad but It stisll fails to start.Is there a way to check out my motherboard? It is a D845GVSR Motherboard. There is no visible signs of damage...Help
Tinner1997
JITENDER KUMAR
Level 2:
  • Expert 121 Answers
  • Posted on Dec 16, 2009
JITENDER KUMAR
Expert
Level 2:
Answers
121
Questions
0
Helped
29482
Points
279
I want to change out/upgrade the motherboard. What will fit into my existing tower?
Buy a new towercase that is compatible with the new motherboard. You may need a more powerful power supply which should come with a new tower case but check it does.
It will be hard to assess if the previous tower has a powerful enough compatible power supply and what size motherboard it is rated to hold..
2helpful
Gateway GM5472 won't boot no power
No power and won't boot suggest a power supply problem in the tower--it is listed as a desktop unit.
What is common on a lot of units (computer towers, TV sets, you name it) is the stand by power supply which is on 7/24 fails.
The most common reason is filter caps dry out because cheap ones and ones rated too low a voltage are used.
The beauty of this is if the power supply is removed and opened you will be able to SEE the bad ones.
I will attach a photo of bad caps--tops which should be perfectly flat are puffed up from a little to a lot and or brown material is seen at top and bottom of the cap.
I have fixed many towers (desktop units) and other equipment with this problem---most of them at first had to be turned on a few times to get them to come on--it gradually gets worse until it will not make it on.
If bad caps are found you can usually buy a replacement supply at a reasonable price or replace the puffed up caps (seen as many as 8 bad in one computer tower).
This answer is based on the information you provided in your question and the answer from personal experience.
SD TECH
4_25_2012_5_11_26_pm.jpg the two larger ones are bad for sure.
Moved my computer to another room and when starting up the monitor has no power. I tried changing cords and outlets and still no power. Is this the end of the line?
It may have been coincident. For a 4 years old monitor, the power supply may have failed.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Gateway monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Loud gateway 5310 desktop
its your power supply that making nosies, change it to a quiet one. or its you processor fan. if so you need to clean it from dust. also clean your power supply and if you are lucky the noises disappears.
3helpful
2answers
Gateway 310 X will not power on
Hi. this is a failed power supply. the power supply pack will have to be replaced. it located on the rear side of the tower in the upper corner. its where the power cord plugs into. replace the power pack and this will fix the issue at hand.
1helpful
2answers
Gateway e series desktop - power light is on but computer isn't.
i have the same problem i don't think its the power supply... my power see if your power supply has a "test button" on it and see if the fans work when you press that button
Gateway 505gr motherboard replacement
not powering up does not mean the mother board is bad , the power supply going bad is more likely to be the problem . But your tower is considered to be a mini tower ive got the same one that I replaced the mother board on . dont mess up and get the wrong size board , it will not fit!
Bad motherboard.gateway atx tower
whatever socket that is 454 soket mobo i think or befor ethat so old look on ebay for one that can take your chip how do u know mobos bad no power or im open for chat anytime also thx nick helpap
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
