Question about ASUS VIA Apollo Pro133A Chipset P3V4X Motherboard
P3V4X Processor Settings (for use with Intel 933EB Processor)
I need to know what is the correct setting for "System/PCI Frequency (Mhz)" (When CPU is set to [Manual]) when using the Intel 933EB Processor with the Asus P3V4X Motherboard.
A) 133/33.25?
OR-
B) 133/44.25?
Note: This setting is requested during BIOS setup (Advanced Menu, section 4.4.
Note 2: The Asus manual only shows the correct processor settings up to the 733 Mhz Intel Coppermine CPU.
Thanks.
Jesse
    Genius:
  • 1,067 Answers
A 1
Posted on Jan 21, 2008
Processor upgrade
WHERE IS THE QUESTION.
Feb 24, 2015 | Max Computers & Internet
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
I have a mainboard of model D845GVAD2------------------------AAC18931-104. It has already intall the Intel celeron processor of 1.8GHz. Now I want to upgrade my processor. So what high frequency processor...
The Intel® Desktop Board D845GVAD2 supports a single Pentium® 4 processor with a system bus frequency of 400 MHz or 533 MHz, or a single Celeron® processor with a system bus frequency of 400 MHz.
So you can install upto 3.06 GHz 533 MHz(cache memory) processor and also update the ram 2 GB 400 mhz.
Dont install Prescott processor.
Hope it will help you.
Dec 31, 2010 | Intel Desktop Board D845GVAD2 Motherboard
Motherboard p3v4x : during bootup i get a system
This error is usually caused by an incorrect setting of either bus speed or multiplier (or sometimes processor chip operating voltage). These could be set either by software ie in BIOS or by changing tiny switches mounted on the motherboard.
Have you consulted your motherboard manual?
Try here: http://www.motherboards.org/files/manuals/1/p3v4x-102.pdf
or try the ASUS website and look under support or the discussion forums.
This will help: http://support.asus.com/cpusupport/cpusupport.aspx
These freq and voltage settings are set under BIOS which is usually accessed by hitting the DELETE key on your keyboard after turning on your computer.
Sometimes a quick fix is to enter BIOS as per the above instruction and selecting LOAD BIOS DEFAULTS or something similar to that and then save and exit BIOS and allow the computer to reboot.. That may get you to the point of booting up without the improper freq comb error.
If you have no luck playing with the above info, shut down your computer and remove the left hand side cover on your computer box or tower, so you can access the inner workings of your computer.
Remove the cooling fan from your processor chip. It will be a large square or circular (black or silver colour).
Take a look at your processor chip. Note the part number printed on the chip, which is only visible after you remove the cooling fan. For example it may say for example SL52P or something else. It may also be an AMD chip.
Search the internet for its specifications ie search for SL52P.
For example, if it was a Pentium 3 chip running at 800 Mhz go to google and search for specs of P3 800 Mhz processor with the part number SL52P.
Google returns the following info (based on the example above) of:
http://processorfinder.intel.com/details.aspx?sSpec=SL52P
ie its a chip that runs at 800Mhz speed with the memory running at 133 Mhz (800 mhz processor speed obtained by having the multiplier set to 6 but actually means the memory is running at 133 MHZ but the processor running at 6 times the speed of the memory bus ie 133x6=800 MHZ (one of the settings you need to get right in your BIOS settings)
So if you had this chip, in BIOS you would select 133 bus speed, with the multiplier of 6 usually locked down on the processor physical internal wiring.
If your BIOS doesnt allow you to play with the processor and memory bus settings (commonly done to make the processor overclock to a faster speed) the other option is that you have the DIP switches on your motherboard set to the wrong settings. Again, refer to to your motherboard manual. The DIP switches are tiny plastic switch blocks on the motherboard with a row of (usually) white sliding switches.
Intel chip info: http://www.intel.com/p/en_US/support?iid=hdr-AP+support
http://processorfinder.intel.com/List.aspx?ParentRadio=All&ProcFam=483&SearchKey=
Also Try this: http://processorfinder.intel.com/Default.aspx
Cheers,
Steve (Melbourne, Australia)
May 09, 2010 | ASUS Computers & Internet
How to overclock Intel Pentium Dual Core E2140 1.6 GHz processor
The following link will tell you the very simple way to overclock this processor. Half way down the page you will find the header "OVERCLOCKING"
http://www.value-reviews.com/index.php?page=pentium-dual-core-e2140
"Since the architecture was designed for the 1066 MHz FSB, overclocking is as trivial as setting the FSB to 1066 MHz (266 MHz quad pumped).
...you instantly get a 2132 MHz CPU with little increase in temperature."
Dec 06, 2009 | Intel Computers & Internet
I need the motherboard manual for p4m266823x
I need driver VIA P4M266-823x, help me please!!!
Jun 10, 2009 | Computers & Internet
Highest processor for intel 810 Motherboard
i cannot give you a specific list of models but in general every pentium 3 cpu with a front side bus [FSB] frequency not greater then 133 mhz should work on that chipset. i also do not know where you could find a pentium 3 cpu for sale.
Feb 28, 2009 | Intel Refurbished DEC SYSTEM BOARD DESKPRO...
I have a 838gm gateway,Ive tried to install 4gb of ram ,when I install more than 2gb,it will not boot
Gateway's website says this motherboard will support 4GB of DDR333 or DDR400 memory. I would suggest testing each memory modules by plugging it into the board by itself, then rebooting. This way you can catch a bad DIMM that might be causing problems. If each one checks out then start adding one module at a time, rebooting after each one. If it still stops booting after you add a module, you probably have a bad system board, and only now that you are adding the extra memory are you finding that out. If that is the case, try contacting Gateway support. Maybe they would be kind enough to cover repair under warranty.
Nov 27, 2008 | Computers & Internet
IS DDR SDRAM IS DDR II RAM OR DDR
No. DDR replaced the SD in RAM so SDRAM and DDR RAM are two completely different things but each ram type has its own frequency hence you get SDRAM 100(mhz) and SDRAM 133(Mhz) just like you get DDR 1 RAM at 266(mhz) and 400(mhz) and DDR 2 RAM at 533(mhz) and 800(mhz). Therefore as you can see how these things differ, but if your mboard takes SDRAM that it can take and frequency of SDRAM but you must ensure that all the frequencies of all your RAM modules in all your slots correspond otherwise you will have problems, meaning that if you decide to use 133mhz RAM then all your RAM modules that you use must be the same. Let me know how you go. thanks
regards
Feb 06, 2008 | Intel D101GGC Motherboard
ASUS VIA Apollo Pro133A Chipset P3V4X Motherboard Logo
115 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
