Question about LG Flatron L1810B 18.1" LCD Monitor
Starting When I start the computer, screen goes on and then off. I had to turn off and on several times to make it running. any solution please? Thanks!
    New Friend:
  • 44 Answers
Make sure the power chord is seated correctly. Also check the cable that runs from your monitor to the computer make sure it is connected. If the problem still occurs you may wanna swap out cords to ensure it is not a problem with the cord. If that does not fix the problem then it is probably a problem with the monitor itself.
Posted on Jan 21, 2008
Acer aspire 6930 6941 won't boot
won't get the check disc option until it boots up and from your description is is a hard drive problem
take it in for a proper diagnosis
Apr 25, 2017 | Computers & Internet
Starts up then goes to a blue screen
This happens to old computers after time. Start your computer up several times, and if you still get a blue screen, try formatting your hard drive.
Jul 17, 2012 | Dell Latitude D610 Notebook
Hi i have a dell insperon 1501 and when i turn it on, it goes threw all the start up stuff. Then it gets to a screen that says configuring 3 of 3 updates and then it shuts off, restarts, and then does it...
Your system is maybe damaged.
To restore the file you want press F8 when it boots
Select fail safe mode with network prompt.
You should now be able to recover your file.
Good luck.
Mar 08, 2011 | Dell Inspiron 1501 Notebook
Upon booting, the screen goes snowy. Sort of like a tv with no cable connected. It will do this several times and finally will be ok. But, if I do not use the computer for a while it goes snowy again and...
Have you tried starting from the system disks that came with the computer? Put the disk into the computer and start up holding the C key down. Troubleshoot from there.
Nov 24, 2010 | Apple iMac G5 MA064LL/A Desktop
Need to bring computer back to factory settings Would like to bring my Aspire 9300 back to factory settings
Hi and welcome to FixYa!
This is an easy fix! To wipe it clean and make it run like new, while your computer is starting up, press Alt+F10 repeatedly. It will go to factory restore screen, which will ask you to confirm if you wish to completely restore it. Please be advised that if the computer goes to normal start up again, you must turn computer off and restart process as soon as it is starting up. I have done this to several Acers myself and it took me a few tries when i was 'new' to these steps. Also, please save any files or pics in email or upload them to a site if you wish to keep them. This will remove everything you have saved on your computer!
Please rate this solution if it was helpful!
KittyTech
Nov 14, 2010 | Acer Aspire 9300 Notebook
Too many! Where do I start.... 1. The Wifi connection does not work, although blutooth is on and the blue indicator light is illuminated. 2. When the pc is idle for some time, the screensaver does not...
This can happen when there is two problems.. One the computer might have been affected by virus.. Or the other thing might be the OS corrupted.. Try to get into safe mode and check if the system is working fine.. If it works well there try to do a system restore to a place wr it was working well.. If in safe mode also it doesnt work well then go ahead and reinstall the OS...
Sep 24, 2010 | Computers & Internet
The system powers up, I get the dell screen, then the screen goes blank and a cursor remains in the top left of the screen. The light left of the power button is green but the is no light on the power...
Tap F8 several times to see if the system will start in safe mode. If it does the problem is a software problem. Then try reloading windows. If by tapping f8 several times when u see the dell screen doesn't start the computer, your problem is hardware. Possibly a hard drive.
If you were a little bit handy and had another computer you could plug in another hard drive and see it the computer starts
Aug 13, 2009 | Dell Dimension 4700 PC Desktop
Monitor displays slowly after the computer starts.
try to turn off you screen saver just turn off power monitor to see monitor easy wake up after long time.if ok means windows screen saver have problem if still same look like is you monitor something wrong need to check
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
Cannot start Sony VAIO PCG-5J2L /Goes to black screen only
During start-up the computer will go to a black screen for awhile and then the pointer arrow will show alone, and then the system will come up.
If you think it's a hibernation problem, pull the ac plug and battery out for about 1 hour and then plug back in.
If this didn't work, then try the F8 Key and choose "Last Know Good Configuration".
Nov 30, 2008 | Sony VAIO PCG-K23 Notebook
Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
LG Flatron L1810B 18.1" LCD Monitor Logo
57 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
