Question about LG (LRBC22522ST) Stainless Steel
Inability to adjust temp controls
I have an LRBC22522St refer that gives a Fresh Food temp display of 5,6,7 after running for about 24 hours, and cannot be adjusted on it displays these numbers.. It will reset if unplugged, but returns after 24 hours
    New Friend:
  • 60 Answers
5,6,7 is a fault code saying the defrost circuit is not working. The unit only goes into defrost about once a day so that explains why it works for a while then comes back.
Posted on Feb 05, 2008
How to set freezer on LG Bottom Freezer LRFD22850
Hello Fran Miller,
For OPENERS... (my opinion)
always start by setting you temperatures at mid range.
Owners manual... Page 16
Setting the controls 16 - 17 Adjusting control settings...
http://www.searspartsdirect.com/partsdirect/user-manuals/LRFD22850ST-LG-Parts-Refrigerator-Parts-manual
I get a little PUSHY about FOOD TEMERATURES...
(stored poorly there's no quicker way of poisoning ones self)...
I strongly recommend getting TAYLOR refrig/freezer
THERMOMETERS (like Amazon... cheap = $6 ea).
Let the refrigerator stabilize EMPTY 24 HOURS
Loaded with food (not recommended: 72 hours).
ADJUSTING CONTROL SETTINGS
Give the refrigerator time to cool down completely before adding food. It is best to wait 24 hours before you put food into the refrigerator. The mid-settings indicated in the previous section should be correct for normal household refrigerator usage. The controls are set correctly when milk or juice is as cold as you like and when ice cream is firm.
THERMOMETERS
Amazon com Taylor Refrigerator Thermometer 20 Deg To 80 Deg 3 1 4 3 3 4...
Hope I am helping
Carnac the Magnificent
Jul 11, 2017 | LG Refrigerators
The unit will not turn off on its own.
With all the extra running---are you getting frozen items in the fresh food section?? You have to understand that if the refrigerator was running all the time and for instance had a stuck on temperature control, you would be getting frozen items like lettuce, eggs, etc in the fresh food section. If that is not happening then the refrigerator needs to run until the cold control turns it off. Set both controls to the middle setting and let it run without playing with it for 24 hours and see if it turns off on its own. Frost free refrigerators average run times of 50% to 75% on time depending on how warm the room temperature actually is. If after 24 hours it is still running and some of your Fresh food is freezing then you do have a bad temp control.
Apr 15, 2015 | Refrigerators
Can't set the temp it blinks 0
If "0F 0F" appears on the display, the refrigerator is in DEMO MODE. To exit Demo Mode for controls on the outside of door, Press and Hold the Energy Saver and Adjust Freezer buttons at the same time for 3 seconds. To exit Demo Mode for controls inside the Fresh Food Compartment, Press and Hold the Ice Off and Freezer buttons at the same time for 3 seconds. You will hear a beep and "0F 0F" will no longer be displayed. Adjust Refrigerator and Freezer temperature to the desired settings. Allow 24 hours for temperatures to stabilize.
Feb 04, 2013 | Refrigerators
On our Samsung RS267 and 25.5 cu ft refrigerator, we have an "OF" light on both temperature readouts (freezer and refrig.). What does this mean and how can the problem be rectify so that we will...
here is a video explaining (for all models) what is to do ..
http://www.samsung.com/us/support/owners/topic/RSG257AARS/XAA
Aug 15, 2011 | Refrigerators
We just started our new Sharp refrigerator (type: SJ-PT690R) yesterday evening after five hours of delivery. We set the temperature of the freezer & refrigerator at (-18 & 5) respectively. It is...
The fresh food compartment should be set to approx. 35 -37 degrees. Setting the fresh food compartment to a temperature below freezing does not compute and will not display an illogical reading. Adjust your settings according to your users manual and wait 24 hrs. before making any other adjustments
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 10, 2017 | Refrigerators
Maytag MFF2258VEM French Door bottom freezer not cooling
Your model will and may take extensive diagnostics. You know there is no simple answer to this question and I will not guess. Do you have the sevice manual availible? I do if you need but from the length of your message it appears to me that you want and will need help. Let me know, Sea Breeze
Mar 12, 2010 | Refrigerators
Food in the fridge part keeps freezing even with setting at highest temp
if its at the highest setting, i.e., the largest number or letter, you have it at the COLDEST setting, and it will freeze in the refrigerated secion. Reset all controls to normal, which is the middle setting. so if your scale range is 1-9, middle setting would be 5, if scale is A-E, middle is C and so on.
After you reset controls, it will take 24 hours for temps to balance themselves out. Your food may take longer to thaw out, so dont go buy whether food is still frozen, instead place a thermometer in the center of the fresh food side. your fridge temp should be in the 35-40°F range. If after 24 hours your fridge section is still below 32, Then you do have a problem, but LG is not a simple unit to diagnose, impossible to do without inspection.
www.FixMyFridge.net
Mar 08, 2010 | LG LRSC26925 Side by Side Refrigerator
Kenmore refrigerator Freezer is cold but fresh food side is warm
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | Kenmore 57029 Side by Side Refrigerator
Refridgerater doesnt get cold enough.
Things to check.......Is the evaporator (freezer) fan motor running? If not you could have a bad motor
Do you see a build up of frost on the interior rear wall of the freezer? Problem in the defrost system. This includes the heater, terminator or control.
In addition a bad fresh food damper control or blocked return air duct could be restricting airflow into the fresh food compartment.
Ideal temps should be 0 to 10 above in the freezer and 36 to 42 in the fresh food compartment. This can be measured by submerging a thermometer in a cup of vegetable oil that has been in the freezer for 24 hours. The same can be done in the fresh food compartment where a cup of water will do the trick. Higher freezer temps could indicate a more serious problem in the sealed system.
Apr 28, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Westinghouse RJ532, 530 Litre, Frost Free Fridge/Freezer keeps stopping - if we move the little red dial in the fridge under the air temperature control it starts up again, goes for awhile and then stops....
If the refrigerator was tipped on back or side, even part way, it has to wit upright at least overnight, because of the freon flowing upward.
If you just moved in and it has been sitting and unplugged, then it may be low on freon.
Here are some tips
If you open the fresh food compartment of your fridge (the non-freezer compartment), you will most likely see two different controls. One refers to the refrigerator temperature and the other refers to the freezer. Different manufacturers use different wording, but the idea is the same.
The first thing you need to know in order to understand what these controls really do is that all the cold air in the entire refrigerator is made in the freezer compartment. A portion of that cold air is then blown into the fresh food compartment. How much cold air gets blown in is controlled by the "freezer" control, which is really just an air baffle that opens or closed to let more or less air into the fresh food compartment. The "refrigerator" control is actually a thermostat that feels the temperature inside the fresh food compartment and turns the compressor on and off according to the temperature that the thermostat feels.
Let’s run through an example. Suppose you decide that your ice cream isn’t hard enough. You adjust the "freezer" control to make your freezer colder. What you’re actually doing is restricting the amount of cold air that gets blown from the freezer into the fresh food compartment and so keeping more of the cold air in the freezer. As a result, the freezer will get colder but also the fresh food compartment will tend to get warmer because its cold air supply has been diminished. The "refrigerator" control (the thermostat) will feel this increase in temperature inside the fresh food compartment and will keep the compressor running longer in order to maintain the temperature setting on the "refrigerator" control. So, you can see that any change you make to one control will affect the other.
Many people then wonder, "Well, how do I know what the correct setting on the controls should be?" Since the temperature inside a refrigerator will vary according to lots of external factors such as frequency and duration of door openings, it is impossible to say where your controls should be set all the time in order to maintain a desired temperature in the freezer and fresh food compartments without knowing the actual temperature inside both compartments. For this reason, you should place two thermometers in your refrigerator: one in the fresh food compartment (the big one) and the other in your freezer. The controls should then be adjusted to achieve -10 to +10ºF in the freezer and between 36 and 38ºF in the fresh food compartment.
Keep in mind, too, that it takes 24 hours for any change in the controls to work through the system and reach steady state so don’t look for instantaneous changes in temperature when you make control setting changes. Knowing the actual temperature inside your refrigerator compartments is also a great way to save money on your power bill since you can adjust the controls to avoid running your compressor longer than needed to keep your food cold.
Mar 16, 2008 | Refrigerators
LG (LRBC22522ST) Stainless Steel Logo
144 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
