Can not run server through router
I have an linksys router set up, i want to play lock and open my server, the address i was give to open ports was http://192.168.0.1/
but it does not seem to work
  • scott_1966 Jan 21, 2008
    thanks this may work i will try
    regards
    scott
    New Friend:
  • 44 Answers
Click on start and go to run. Type in CMD... then type in Ipconfig /all
find out what the gateway is and that will be the correct address.
Posted on Jan 21, 2008
6ya staff
SOURCE:
MY LINKSYS WRT54G2 IS OK BUT CAN'T FIND SERVER.
The Linksys WRT54G2 is Cable/DSL router with 4 port switch. It has many features including a built-in DHCP server. By default, it's IP address is 192.168.1.1, username: blank and password: admin.
Plug in the Modem to the Linksys router's Internet / WAN port then plug your PC's to any of the 4 ports (1,2,3 & 4). The Linksys router once turned ON will automatically provide your PC with IP address starting with 192.168.1.xx (x means number from 100-149).
Make sure that known working ethernet cables are being used. Check your computer's IP adress by going to the command prompt. Start>RUN>type CMD then press Enter. Type IPCONFIG and check the IP address (e.g. 192.168.1.100). Check you PC's network adapter if you don't get an IP address from the Linksys router.
You may opt to reset the router by pressing the reset button at the back for 30 seconds if it fails to give out DHCP.
Cheers!
Angel
Jun 22, 2010 | Linksys WRT54G2 Wireless Router
Is wps54g wireless print router compatible with windows 7: how do I get it installed
Contrary to the on-line advice that I have found, the Linksys wireless print server WPS54G is compatible with Windows 7. It is the installation program that is not compatible. While not as bad as the early days of setting hardware dip switches, the print server must be installed manually. Following are the many steps that I took to install my WPS54G to work with Windows 7; lengthy, but worth it.
1. Connect your printer to the PC using a USB cable and USB port. Allow the printer to install. Print a test page. Even though you just installed the printer, check for an updated printer driver at the manufacturer's website. I did this late in the process before I could get the printer to work. It installed an HP universal driver.
2. Set the printer as the default.
3. If you do not know the IP address of your print server, access the router using your browser. See your manual for instructions. For a Linksys, type the default IP router address 192.168.1.1 into the browser address bar. If you have done this in the past, set up your router security. The default user name is left blank and the default password is admin.
4. Connect your print server to the PC using a USB cable and USB port.
5. On the router locate the DHCP Client Table and determine the IP address of the print server. You might have to refresh the table. The default is probably 192.168.1.78.
6. Access the print server using your browser and the IP address of the print server. The default user name is left blank and the default password is admin. Set up security to match the router, SSID, password, type of encryption, etc.
7. Go to "Devices and Printers" (from the start menu), on the default printer icon that you just installed, right click and open "Printer Properties." Click on the "Ports" tab.
8. Click on "Add Port." Select "Standard TCP/IP Port" and click on "New Port." Click "Next." Add the IP address of the print server (probably 192, 168.1.78) and call the port whatever you want. Click "Next."
9. After the port configures and you get the "Port Settings" tab (you can also get there by clicking on "Configure Port), change the protocol to "LPR" and click "LPS byte counting enabled." Use "p1" or P2" etc. for the "queue name."
10. Disconnect the print server from the USB port and let it sit for 30 seconds.
11. Disconnect the printer from the USB port.
Apr 06, 2010 | Linksys Wireless-G WPS54G Print Server
Linksys wrt160nl wireless router causing e-mail issues
Hmm... That sounds like a port forwarding issue. I take it that you using a POP3 e-mail client since you said your ISP e-mail server sends you your messages? I would suggest that you open up your linksys configuration (the webpage for the settings), click on the Applications & Gaming tab and Single Port Forwarding sub tab. Then, for the first row, select POP3 as Application Name, and your computer's IP Address as To IP Address, enabled it, and click save settings at the bottom. This should hopefully make it work.
Feb 23, 2010 | Linksys Wireless-G WRT54G Router
Open port 3306
Hi Friend,
Following are the steps as per u're problem:
1> By default ip address of all linksys router is 192.168.1.1.Open the internet browser & clear address bar at the top completely & type default gateway of yours computer which you are getting from router
2> Default username is blank & password is "admin".Otherwise give router password.Again if it is not working type default password which you usually give to your computers
3> Finally,you will be on router setup page;in top click on Applications & Gaming
4> Now click on port triggering,enter your desired port numbers & enable them --> Save Settings.
If u need technical help in order to do the above changes in router have a words with linksys technical suppoprt.
Dec 24, 2009 | Linksys (WRT54GC) Router
I can't open a port to show to my web site. This works only localy.
Look at this page from Linksys.
You can see that you want to go to "Application and Gaming", then to "Single Port Forwarding".
You want to setup your router like the first line:
HTTP [you can put here whatever you want] | External Port 80 | Internal Port 80 | Protocol TCP | IP Address [your web server's IP address] | Enabled [tick yes]
In the second line you write exactly the same except you replace Protocol "TCP" with "UDP".
Don't forget to enable both and to save the settings!
You should give your web server a static IP address (not via DHCP!), to ensure it is always the same.
If you have any more questions or something is not clear to you, just come back here and leave a comment - I'm happy to help.
Jul 02, 2009 | Linksys WAG200G Router
How to create a port on my router
please follow the steps are given below,
1.Type 192.168.1.1 on your browser's address bar. You will see a login dialog box .
2.Type your username & password and login to device.
3.A web page will appear , you can go to security section & select virtual servers.
4.From virtual servers section you can create port you want either TCP or UDP.
best regards,
Krishan
May 09, 2009 | U.S. Robotics (USR5450) 802.11g/b Wireless...
Change NAT to open
Ok kids... all you hve to do is log in to your belkin 54g at http://192.168.2.1
Find out what ip address your xbox is using and then Click on the DMZportion of your settings on the left hand side of the page.
Enter the xbox's ip address and click the enable box.
Click apply.
Your NAT will now be OPEN!
Cheers!
Mar 24, 2008 | Linksys WRT54GL Wireless-G 54Mbps...
Port Forwarding
Port forwarding is a method that allows you to run a server behind the router. Port Forwarding opens a specific port to a computer behind the router, allowing all Incoming Traffic on that port to be sent directly to that server. It should be used to setup servers behind the router, typically Port Triggering (Answer ID 344) is a better choice for non server applications (Such as instant messengers and game servers). Below is an example of how to setup Port Forwarding. For our example we will be setting an FTP Server and a Mail Server that uses SMTP and POP3. FTP uses ports: 20 and 21 SMTP uses port: 25 POP3 uses port: 110 Getting Started 1. You must set a static IP address on the server. If you're unsure of how to do this please go to Answer ID 534 for information on setting a static IP address in Windows. 2. Once the static IP address has been assigned please go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 3. Once "Internet Explorer" opens, please type http://192.168.1.1into the "Address Bar" and click GO 4. The "Enter Network Password" window will appear. Skip user name and type admin (admin is the default password) as the password, and click OK 5. This will bring up the routers "Setup" section. Look under "Domain Name" and check what version of the firmware you're using. 6. You will need to click on the Advanced tab to the very right. Once the "Advanced" tab comes up please go to the Forwarding tab. Firmware prior to 1.32 This will not work with firmware prior to 1.32
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Port Forwarding
Port forwarding is a method that allows you to run a server behind the router. Port Forwarding opens a specific port to a computer behind the router, allowing all Incoming Traffic on that port to be sent directly to that server. It should be used to setup servers behind the router, typically Port Triggering (Answer ID 344) is a better choice for non server applications (Such as instant messengers and game servers). Below is an example of how to setup Port Forwarding. For our example we will be setting an FTP Server and a Mail Server that uses SMTP and POP3. FTP uses ports: 20 and 21 SMTP uses port: 25 POP3 uses port: 110 Getting Started 1. You must set a static IP address on the server. If you're unsure of how to do this please go to Answer ID 534 for information on setting a static IP address in Windows. 2. Once the static IP address has been assigned please go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 3. Once "Internet Explorer" opens, please type http://192.168.1.1into the "Address Bar" and click GO 4. The "Enter Network Password" window will appear. Skip user name and type admin (admin is the default password) as the password, and click OK 5. This will bring up the routers "Setup" section. Look under "Domain Name" and check what version of the firmware you're using. 6. You will need to click on the Advanced tab to the very right. Once the "Advanced" tab comes up please go to the Forwarding tab. Firmware prior to 1.32 This will not work with firmware prior to 1.32 Firmware between 1.32 and 1.36 Service Port Range 20 ~ 21 25 ~ 25 110 ~ 110 IP Address 192.168.1.3 192.168.1.3 192.168.1.3 Firmware after 1.36 up to 1.40m Service Port Range 20 ~ 21 25 ~ 25 110 ~ 110 Protocol Both Both Both IP Address 192.168.1.3 192.168.1.3 192.168.1.3 Firmware after 1.40m Customized Application FTP SMTP POP3 Service Port Range 20 ~ 21 25 ~ 25 110 ~ 110 Protocol Both Both TCP IP Address 192.168.1.3 192.168.1.3 192.168.1.3 Finishing up Click Apply, then Continue Restart your computer
Setting up a PPtP server behind a WRT51AB Router
You?ll need to setup Port Forwarding to set up a PPtP tunnel behind a Linksys router. Please follow these instructions to setup the router to forwarding incoming PPtP traffic to your PPtP server: Getting Started 1. You must set a static IP address on the server. If you're unsure of how to do this please go to our Answer ID 534 for information on setting a static IP address in Windows. 2. Once the static IP address has been assigned please go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 3. Once "Internet Explorer" opens, please type http://192.168.1.1into the "Address Bar" and click GO 4. The "Enter Network Password" window will appear. Skip user name and type admin (admin is the default password) as the password, and click OK. 5. This will bring up the routers "Setup" section. Look under "Domain Name" and check what version of the firmware you're using. 6. You will need to click on the Advanced tab to the very right. Once the "Advanced" tab comes up please go to the Forwarding tab. Firmware prior to 1.32 This will not work with firmware prior to 1.32 Firmware between 1.32 and 1.36 Service Port Range 47 ~ 47 1723 ~ 1723 IP Address 192.168.1.3 192.168.1.3 Firmware after 1.36 up to 1.40m Service Port Range 47 ~ 47 1723 ~ 1723 Protocol Both Both IP Address 192.168.1.3 192.168.1.3 Firmware after 1.40m Customized Application VPN VPN Service Port Range 47 ~ 47 1723 ~ 1723 Protocol Both Both IP Address 192.168.1.3 192.168.1.3 Finishing up Click Apply, then Continue. Restart your computer
Feb 16, 2006 | Linksys WRT51AB Wireless Router
Open Questions:
Computers & Internet Logo
76 people viewed this question
Ekse
Marvin
Marvin
