Back to:
Tags:
Nikon Speedlight SB-600 TTL Flash
Sb 600 under exposure. (by 2 users)
posted by johnberry83 on Jan 21, 2008
hi, everything is underexposed with my sb 600. it flashes but only outputs a tiny amount of light. I have tried using it on two d80's and a d70 but im still having the same problem. It seems to work fine when i remove it from the hotshoe and fire it manually. I've also taken it into my local photographic shop but they hadn't come accross the problem before.
Comment by johnberry83, posted on Jan 22, 2008
Forgot to add that it works fine when i use it as a second wireless flash.
cheers,
john
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Mar 20, 2008
Hi , Even i have a similiar problem with my sb 600 when used with d70 s , i checked the settings with both the camera and flash but gave same results
Best Solution
posted on Jan 27, 2008
Thanks for Trying (70)
nsfbr
Rank:Wiz Wiz
Rating: 86%, 31 votes
You probably haven't changed the camera and/or flash back to TTL mode from wireless mode.  Make sure they are both set to TTL, not commander mode and you should be fine.  Note that the LCD on the flash will indicate which mode it is with a little graphic.  On the D70 you had to switch between TTL and Commander mode to set it up to work using the built in flash as the commander, so you just have to switch back.
Rating Locked! (?) johnberry83 has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on sb 600 under exposure.:
I don't want to Accept this solution
Can you Help with these Flashes problems?
Can you fix it? for how many $$$? steve
One day I turned on my flash and every few seconds it...
Hello everyvody: I had forgotten to take off the batteries...
lcd display on sb-600 flashing. tried the two button...
the foot that connects the flash to the camera has broken....
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
